need some help for an audiophile newbie... - AVS Forum | Home Theater Discussions And Reviews
post #1 of 14 Old 10-16-2013, 08:28 AM - Thread Starter
Apokai's Avatar
Hey guys,
Yes. An OTHER newbie on the forum. I spent 2 days searching and reading, trying to do my duty. And guess what? Totally lost.
1st - My receiver blew up (a cheap one, I don't even dare to tell what it was). So, I need a new one.
2nd - Over all the advices I received and read, most people told me to choose a speaker set based on my personal appreciation of the quality of the music. That's logical, That's true.
2 years ago, I went to a listening room at FutureShop and was blown away by Klipsch RF82 (800). Again, a month ago, I went back, asked the guy to run all the speakers, closed my eyes and listen. They was Martin Logan, Polk and Klipsch RF62 and RF82. Again, I was blown away by them.
Here's my problem. I need a new receiver NOW.
Klipsch RF82 are asking for a 150W RMS. Most receiver got around 65 to 90W (for a price range of 200 to 400$). I found that people suggest that the receiver and speaker run around the same W per channel. So, in order to buy the Klipsch eventually, I found that a 90W per channel receiver might not be enough to drive them.
Yesterday, the Sony STR-DN1040 went at a special price tag of 499$. It has a 165W per channel so I said "Bingo, that's the one".
But Klipsch's got 2 pairs of connector (for preouts as I understood). Receiver with Preouts are more the double of my budget. So, is the SONY enough to power them? And what happens if I hook it up with, i.e. Energy Classic II which is a 100W RMS max. Is it too powerful then?
But again, logically speaking, I was blown out at FutureShop with prob. a very standard receiver, but connected with preouts (as the vendor was switching speakers set with a red push button - So again, logically, should be a performance lost here).
Yeah, I saw your other threads. Emotiva amps... W-O-W. That is so great. XPA-2, perfect for stereo. My Klipsh would run like a Ferrari on a german highway, I know. But, sorry guys, I don't have that kind of money. I would like to though, but don't have. A got a cheap receiver, blown away that I have to replace and trying to get a decent (possible?) one to eventually have Klipsch RF82 on it.
Other solution, go to a specialized music store, not some BestBuy store. But I know it would be like driving a lamborghini and going back after on Jetta. I would never be satisfied again.
A friend told me to look for used stuff. Too scared to be fooled by experience users.
My head is spinning off actually. So much questions.
So, I will take any advices. Most important for now, what about the SONY 1040 for the future use of Klipsch RF-82? Budget wise, it is around 500$ for the receiver and around 1K$ for Klipsch (will wait for boxing day, they usually go as 499$ each).
Thx!
Apokai is offline
post #2 of 14 Old 10-16-2013, 10:27 AM
Kini62's Avatar
Quoted: 1415 Post(s)
Liked: 1301
Any decent AVR will have enough power (for most people in most normal size rooms). Buy the one that has the features you want at a price you like.
Def Tech SC8000
Harman Kardon AVR 1600
PS3, Apple TV, Sharp 70" Qattron
Kini62 is offline
post #3 of 14 Old 10-16-2013, 10:38 AM
Audiophile2k's Avatar
Liked: 46
Speakers themselves don't have "watts", they only have power recommendations based on how much power they can take. So there is no need to find an amp with the maximum watts a speaker can take. As for your speaker choice, if you like the Klipsch sound you can save a lot of money by going with Bic products. They sound very similar and are based on the same design principles. http://www.acousticsounddesign.com/brand/index.cfm?bid=67
Audiophile2k is offline
post #4 of 14 Old 10-16-2013, 10:54 AM
afrogt's Avatar
Quoted: 1053 Post(s)
Liked: 755
The two sets of speakers terminals are for biamping or biwiring which is not necessary at all. In most cases it has dubious value. Just use one set of terminals and leave the connecting brackets in place.
doubt you'll even need to turn up the volume loud enough to push 165W channel. Also doubt that Sony receiver puts out 165W when driving 5-7 speakers.
Were you planning to use the Take Classics as main or surround speakers?
Afro GT
afrogt is offline
post #5 of 14 Old 10-16-2013, 10:57 AM
simp1yamazn's Avatar
Quoted: 109 Post(s)
Liked: 77
No one should recommend you buy a receiver with the same watts that the speakers list on their spec sheets. It won't hurt, but realistically speaking, those number have little to no value. The watt ratings, as previously mentioned, just tell you how much sustained power they can handle. During TV watching, most will not use more than 1 watt of power. Considering how efficient Klipsch speakers are, there is no reason to get hung up on how much power your receiver has.
For power, to get a very small increase in volume (3 db which is just about where people start to be able to discern a small difference in volume) require you double the power. the most powerful receivers on the market will give you almost nothing over an entry level receiver in terms of volume potential. That means going from your 90w receiver to your 160w receiver will give you less than 3db difference. Also keep in mind that power ratings for receivers are all overblown anyway.
The klipsch speakers do not have inputs for use with pre-outs from a receiver. They have two sets of binding posts for passive bi-amping (which is really nothing more than a waste of speaker wire). if you end up getting the klipsch, just use appropriate speaker wire to one set of binding posts and be done with it.
Again, power will not be an issue especially considering the speakers you are considering. A mid-level receiver will likely be able to create enough volume to make your ears scream for mercy.
The big thing you should (in my opinion) be looking at when considering a receiver is which room correction it comes with. People's opinions vary, but in my personal experience Audyssey has given me the best results.
simp1yamazn is offline
post #6 of 14 Old 10-16-2013, 11:37 AM
psgcdn's Avatar
Quoted: 206 Post(s)
Liked: 307
Good advice all around.
Whatever you do, don't buy your speaker wire from Futureshop! Try monoprice in the US, or infinitecables.com or http://www.cablesonsale.ca in Canada.
Receivers tend to be a lot cheaper in the US than in Canada as well, BTW. I usually order them from the US.
psgcdn is offline
post #7 of 14 Old 10-16-2013, 11:57 AM
lovinthehd's Avatar
Quoted: 4588 Post(s)
Liked: 4775
As to your question about using your Takes in the meantime, with whatever receiver you get, they'll be fine as long as you don't turn the volume up so much as to overdrive the amp into distortion and potentially damage your speakers. Just use some common sense and you'll be fine with any speakers.
lovinthehd is offline
post #8 of 14 Old 10-16-2013, 12:05 PM
Mike Garrett's Avatar
Quoted: 5575 Post(s)
Liked: 3553
Hey guys,
Thx!
That AVR has 100 watts per channel with 2 channels driven, not 165. 100 watts should be fine with the Klipsch speakers. If you would like speaker pricing, give us a call.
mjgarrett100@gmail.com
Mike Garrett is offline
post #9 of 14 Old 10-18-2013, 02:18 PM - Thread Starter
Apokai's Avatar
Thx for the advice. Actually, my Klipsch RF82 are at 499$ (around 40% off) which is the same price (Until October 24).
Apokai is offline
post #10 of 14 Old 10-18-2013, 02:19 PM - Thread Starter
Apokai's Avatar
Thx, good to know.
The Classics are mainly for movies. My Klipsch will be for music (main stereo).
Apokai is offline
post #11 of 14 Old 10-18-2013, 02:30 PM - Thread Starter
Apokai's Avatar
Understood, crystal clear. Thx!
Except for the 12, 14, 16 wire gauge, is there really a quality in the wire? I'm not talking about more than 25 feets of cable.
So, I should select an AVr based on the sound quality and features?
I also read that there's good mobile apps to evaluate (or verify the automatic setup).
Apokai is offline
post #12 of 14 Old 10-18-2013, 02:37 PM - Thread Starter
Apokai's Avatar
Klipsch are currently on sale now (Which I though would be more in boxing days...). Anyway, as an entry level, a SONY HTR-DN1040 (499$ CND) + Klipsch (399$ CND each), I think it is pretty reasonable, no? Any final advices before I bought them? (I still have a 30 days for returns... )
Anyway. MANY thk for your help and quick advices on this. For an other newbie... wink.gif
F.
Apokai is offline
post #13 of 14 Old 10-18-2013, 02:58 PM
cel4145's Avatar
Quoted: 2658 Post(s)
Liked: 2989
Seems like a good setup, especially given Canadian prices on audio equipment smile.gif
Living room HT: Energy RC-50, Ascend Sierra Horizon w/RAAL, Ascend Sierra 1, PSB Imagine XA | PSA V1500 and CHT SS 18.1 | Denon X4200W | modified Dayton SA1000
Other rooms: CBM-170 SE | SVS SB-1000 | Audio-GD NFB-11 | Parasound Zamp | JBL LSR305
Headphone & Portable AKG K7XX | NAD HP50 | AKG K550 | Soundmagic E50 & E80 | DX50 | E12 | X1
cel4145 is online now
post #14 of 14 Old 10-18-2013, 04:34 PM
Liked: 46
Don't worry about the wiring...it will all sound the same. Same for the amp stage on receivers. Where they will differ is in the preamp stage processing for the room correction and setup. The general consensus is that Audyssey does the best job, but they are all fairly competent and depending on your taste you might prefer one of the others. The Yamaha system seems to roll of the high end a little more than the others, and I've heard the Pioneer has a few of its own quirks. I haven't seen many on the forums comment on DCAC (Digital Cinema Auto Calibration) that the Sony uses, but I have read a couple of online reviews that have said it does a good job with setup and equalization.
Reply Speakers
