High-end speaker wire - where to purchase sub 1ft speaker wire - AVS Forum | Home Theater Discussions And Reviews
post #1 of 16 Old 10-19-2013, 12:38 AM - Thread Starter
Project H's Avatar
I'm looking for higher-end speaker wire that looks something like the ones shown in the link below. I have some exposed speaker wire for rear bookshelf speakers because of their wall mounts and wanted something that looks nicer. One end is with banana plugs to go into the wall plate the other just needs to connect to the terminals on the speakers. I'm guessing I can just cut the other end of the speaker wire or get some without banana plugs.
I dont want to break the bank but would like to know which ones you call recommend and fit the bill. I dont have the time to DIY as I just had a baby.
http://www.amazon.com/Emotiva-USS-2-Speaker-Cable/dp/B00DMI2FJG/ref=pd_sim_sbs_e_1
Project H is offline
post #2 of 16 Old 10-19-2013, 06:52 AM
jdcrox's Avatar
Quoted: 78 Post(s)
Liked: 102
Really, since they will not change the sound even one iota, just pick the cheapest good-looking speaker cables you find. Those you linked seem like a good buy for short money.
jdcrox is offline
post #3 of 16 Old 10-19-2013, 07:00 AM
Phil17108's Avatar
Quoted: 207 Post(s)
Liked: 108
You want speaker cables that look like the one you linked to, get one and cut it and make up 2 of what you want.
Phil17108 is offline
post #4 of 16 Old 10-20-2013, 07:39 PM - Thread Starter
Project H's Avatar
aside from these what are some other nice looking cables out there?
post #5 of 16 Old 10-20-2013, 08:19 PM
magogian's Avatar
magogian is offline
post #6 of 16 Old 10-20-2013, 09:08 PM
Elihawk's Avatar
Quoted: 1014 Post(s)
Liked: 857
Comedian are everywhere! The best looking cable is HIDDEN cable! But as pointed out, expensive cable sound exactly the same as cheap cable!
Set up #1: EMP e5ti, e5Ci, and EMP e5Bi surrounds, Outlaw LFM1 Plus sub, EMP 10i10i sub
Set up #2: Def Tech SM450, CLR2002, SLS Qline surrounds and Klipsch 12wD sub
Set up #3: Philharmonics- BMR in a 2.0 system, music only
Elihawk is online now
post #7 of 16 Old 10-20-2013, 09:21 PM
rcohen's Avatar
Quoted: 1208 Post(s)
Liked: 518
Originally Posted by magogian View Post
I highly recommend these: http://www.amazon.com/AudioQuest-K2-Terminated-Speaker-Cable/dp/B000J36XR2
Lots of good reviews!
rcohen is offline
post #8 of 16 Old 10-20-2013, 10:39 PM
67jason's Avatar
Quoted: 79 Post(s)
Liked: 802
http://www.avsforum.com/t/1301573/have-a-look-at-these-beauties-how-to-make-your-own-high-end-cables/0_100
I don't need snobs to tell me how to think, thank you!
67jason is offline
post #9 of 16 Old 10-21-2013, 08:09 AM - Thread Starter
Project H's Avatar
i just had a newborn and dont have the cycles to go the DIY route...
anyone know if 1ft jumper speaker cables are essentially the same as regular speaker cables. I'm guessing it says jumper due to the short length and intended purpose of patching connections with the use of wall plates.
any other suggestions on 1ft cool looking cables?
post #10 of 16 Old 10-21-2013, 09:28 AM
dharel's Avatar
Liked: 33
Speaker wire, is wire, is wire, is wire...
In other words, there's no need to go crazy.
Get some tech flex, speaker wire and a set a banana plugs and you should be good to go. If you want to get a little fancy, follow the DIY speaker cable thread posted above.
dharel is offline
post #11 of 16 Old 10-21-2013, 10:18 AM
jdcrox's Avatar
Quoted: 78 Post(s)
Liked: 102
The OP has now stated twice that he has no time nor interest in going the DIY route. I know it is simple, but all of our perception is different.
jdcrox is offline
post #12 of 16 Old 10-21-2013, 10:23 AM
afrogt's Avatar
Quoted: 1053 Post(s)
Liked: 755
Congrats on the new baby but it takes 5-10 minutes max to add banana plugs to speaker wire.
Buy this 3 ft speaker wire with banana plugs
http://sewelldirect.com/Silverback-Speaker-Wire-by-Sewell-Enhanced-Loud-Oxygen-Free-Pure-Copper-259-Strand-Count-3-ft-Terminated.asp
Cut it to 18" or 12" whatever you need. Add more banana plugs to the end you cut. They're very easy to install.
http://sewelldirect.com/Sewell-Silverback-Banana-Plugs-Dual-Screw-Lock-2-pair.asp
That's it. Takes less time than it does to go back and forth on this thread.
Afro GT
afrogt is offline
post #13 of 16 Old 10-21-2013, 01:52 PM
psgcdn's Avatar
Quoted: 206 Post(s)
Liked: 307
Heck, buy the 3 ft speaker wire with banana plugs, cut it in half, strip, and screw on the wire to the speaker connectors. Your little one won't be able to pull them out of the speaker someday.
psgcdn is offline
post #14 of 16 Old 10-21-2013, 03:27 PM
airgas1998's Avatar
Quoted: 101 Post(s)
Liked: 147
since it has dual-quad geometry it's worth every penny.
Habit Forming....Wallet Burning Hobby....55" Oled Lg B6p 55" Samsung B8500 Fald Channel Master Dvr+ Onkyo RZ900 avr Samsung K8500 UBR player Svs Ultra Towers/Center, Svs Satellite Surrounds Svs Pb-13 Ultra Sub
airgas1998 is offline
post #15 of 16 Old 10-21-2013, 03:41 PM
Elihawk's Avatar
Liked: 857
dual-quad geometry !? It would be worth every penny if someone could explain what that is and how this speaker wire has it!
post #16 of 16 Old 10-21-2013, 04:13 PM
dharel's Avatar
Liked: 33
OK, my bad. I'll admit that I do realize what the OP has stated, and perhaps offered an ill advised suggestion. What do you suggest, that differs from the advice already given by myself and others?
dharel is offline
Reply Speakers
