Please Enlighten Me... - AVS Forum | Home Theater Discussions And Reviews
Old 10-19-2013, 07:10 PM - Thread Starter
vailvon's Avatar
I have a B&W CM9 powered by Anthem MRX 700. I was in a condo before and my set up was a little bit cramp (pic below). When I moved to a bigger place, I noticed the volume is louder compared when I was in a condo, like 5 db louder. The condo had an 8 foot ceiling and the new place is at least twice as high. I also sit further away (about 2 - 3 feet) in the new place.
Old Set Up
New Set Up
How could that be, shouldn't it be the other way around?
vailvon is offline
Old 10-19-2013, 07:45 PM
sivadselim's Avatar
Quoted: 162 Post(s)
Liked: 154
Ah, yes, the well-known Tidy Cat Effect.
Audiophile2k likes this.
"All men are frauds. The only difference between them is that some admit it. I myself deny it."
sivadselim is offline
Old 10-19-2013, 07:54 PM - Thread Starter
vailvon's Avatar
What do you mean by that?
vailvon is offline
Old 10-19-2013, 07:56 PM - Thread Starter
vailvon's Avatar
That's not a cat litter box. My wife just put it there because I still have some audio and video cables on the floor.
vailvon is offline
Old 10-19-2013, 08:17 PM
sivadselim's Avatar
Quoted: 162 Post(s)
Liked: 154
Old 10-19-2013, 08:18 PM
Bill Fitzmaurice's Avatar
Liked: 4631
When I moved to a bigger place, I noticed the volume is louder compared when I was in a condo, like 5 db louder..How could that be, shouldn't it be the other way around?
Not necessarily. Looking at the picture the mains are spread a lot further apart in the new room, and that can result in both actual and perceived increases in SPL.
Bill Fitzmaurice is online now
Old 10-19-2013, 08:20 PM
Geoff4RFC's Avatar
Quoted: 317 Post(s)
Liked: 1573
I recognize that basket, use to have an assorted size of them.
Could be the increased width in your front stage?
Also, just an observation (killer speakers btw), have you considered bringing them forward so nothing crosses their plane, and toeing them in just a tad? This may improve imaging.
Spinning the rear tire at 150mph while at 3/4 lean angle will put wrinkles in your seat
Set up:
Integra 70.4--Oppo 103--LG50"Plasma--Emotiva: XPA-3, XPA-2 x 2--PolkAudio: RTiA9 x 4--CSiA6--FXiA6 x 4--Epik: Empire x 2--XBOX 360--Furez 10awg homemade cables
Geoff4RFC is offline
Old 10-19-2013, 09:22 PM - Thread Starter
vailvon's Avatar
You are probably right. Now, the speakers can 'breathe' and soundstage is a bit bigger as well.
vailvon is offline
Old 10-19-2013, 09:25 PM - Thread Starter
vailvon's Avatar
Yes, this is the biggest size of them all.
I will try to toe them in a bit and see if it will make a difference. Thanks.
vailvon is offline
Old 10-19-2013, 09:48 PM
craig john's Avatar
Quoted: 513 Post(s)
Liked: 718
Is that 5 dB a "measured" 5 dB, or a "perceived" 5 dB? If "measured", how did you measure it?
Is your system properly calibrated? Was it calibrated in your previous space?
Craig
Lombardi said it:
Perfection is not attainable, but if we chase perfection we can catch excellence."
My System
craig john is offline
Old 10-20-2013, 07:26 AM
Liked: 4631
From a technical standpoint there are two factors. One, the closer the speakers are to each other the worse the phase induced cancellations of each others output. Spreading them therefore increases the actual SPL. The second factor is psycho-acoustic. The closer the speakers are to each other the more you will perceive them as a single source, the wider apart the more they'll be heard as separate sources. The latter sounds louder, even if the actual SPL at the LP is unchanged.
JerryLove likes this.
Old 10-20-2013, 08:35 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1238
If you put the same amount of furniture, etc. in a larger room, the larger room will be more reverberant and therefore seem to be louder, all other things being equal.
Not only is the ceiling twice as high (doubling the volume for an equal floor plan), but it appears that the room is at least about half again as wide. If you sit further away, that is probably because the room is longer.
You are now talking maybe 4 times the volume.
The comment about the obviously wider spacing of the speakers creating a more spacious and therefore louder image would also seem to apply.
arnyk is offline
Old 10-20-2013, 08:39 AM - Thread Starter
vailvon's Avatar
Craig
Although I got an SPL meter, I didn't measure it at the old place. But I have DVD's that I really know well and use it to test the system, my volume was set to -30 at the old house. Using that same movie, I can only go -35 and my wife starts yelling at me for being too loud and feel the same way too.
Yes, I use ARC before and re-calibrated it again after moving.
vailvon is offline
Old 10-20-2013, 08:43 AM - Thread Starter
vailvon's Avatar
I also noticed the soundstage seems bigger/wider. I get a little bit of echo/reverb which makes the sound better, to me at least. It's a feeling of listening to 'live music'.
vailvon is offline
Old 10-20-2013, 07:07 PM
charmerci's Avatar
Quoted: 310 Post(s)
Liked: 195
Is the new place more reflective? (Fewer/no rugs carpets/thinner drapes, fewer bookshelves etc.?)
Plus now you have the sub with the speakers.
To the left in the old place, it looks like there is an open space. Instead of going there, much of the sound in the new place is directed towards you.
Shorter/new cabling? A bit of oxidation on the connections can cause a bit of signal loss.
Maybe a bit of everything.
charmerci is online now
Bowers Wilkins Cm9 Floor Standing Speakers
