Klipsch F-30 - Page 2 - AVS Forum | Home Theater Discussions And Reviews
post #31 of 38 Old 12-07-2013, 04:38 AM
Robbiey60's Avatar
Quoted: 450 Post(s)
Liked: 553
Originally Posted by fwh27713 View Post
Would you get a better center channel to go with the F-30's?  Or just stick with the C-20, so they match?
Get the best center you can possibly afford, even if its different. I used to run rc62ii between my f30s, great combo. I now run rc64ii between rf82ii, even better combo.
(2)RF-83 (1)RC-64ii (2)RF-82ii (2)RC-62ii
(2)Exodus audio tempest-x 15" subs in 200l sealed enclosures
Onkyo 705 pre/pro and rear surrounds
DSPeaker Antimode 8033 sub eq Behringer EP4000 subs
NAD C275BEE mains
AMC 2N100-3 surrounds and center
Robbiey60 is offline
post #32 of 38 Old 12-07-2013, 04:43 AM
Robbiey60's Avatar
Quoted: 450 Post(s)
Liked: 553
Originally Posted by baloo_btru View Post
If your use is HT, I would try to get a very high quality center. I upgraded from RC-52 to RC-62 and never regretted it. So much important audio is going through there that I would try to get the best matching center available.
+1. Get the best center you can afford. Bigger is better
NAD C275BEE mains
post #33 of 38 Old 12-07-2013, 05:18 PM
dimanata2007's Avatar
To me the reference line is much better. I had a chance to compare the rf82s to the f-20s side by side and everything is so much better. That Ti horn is a lot better than that cheaper driver.
RF-82 and F-20 belongs to two very different leagues and price difference is huge. would you compare merc E550 for 90K and camry LE for  22K?
I own pair of F-3 and very familiar with F-2. F-3 producing much heavies and more life like sound. as far as I know they changed design a bit but didn't touch internals so F-30 should sound far superior to F-20 too.
F-30 are very good speakers considering their sound, look and price and at $200 a pc they are simply increadable front speakers.
Robbiey60 likes this.
Pioneer VSX-819H
Samsung BD-C6500
Samsung 46" LCD
Klipsch F-3
Klipsch RC-62II
Klipsch SS-1
Klipsch RSW-10d
BIC F-12
dimanata2007 is offline
post #34 of 38 Old 12-07-2013, 05:24 PM
I use my F-3 with RC-62II to me and a few more ppl who own much more expensive HT they sound very good and timbre difference is not an issue.
C-2 is a pretty weak center for F-30 anyway, you better go bigger.
Pioneer VSX-819H
Samsung BD-C6500
Samsung 46" LCD
Klipsch F-3
Klipsch RC-62II
Klipsch SS-1
Klipsch RSW-10d
BIC F-12
post #35 of 38 Old 12-07-2013, 08:21 PM
Robbiey60's Avatar
Quoted: 450 Post(s)
Liked: 553
That was my original front sound stage. They do sound great together, and any mismatch in sound was negligible. And what is wrong with having a better center anyways? Is arguably the most important speaker in home theater
NAD C275BEE mains
post #36 of 38 Old 12-07-2013, 08:22 PM
Robbiey60's Avatar
Quoted: 450 Post(s)
Liked: 553
Sorry I run f30 but from what iv read they are very similar to f3
NAD C275BEE mains
post #37 of 38 Old 12-07-2013, 08:24 PM
Robbiey60's Avatar
Quoted: 450 Post(s)
Liked: 553
The 2 8" woofers when driven with a good amp are killer!
NAD C275BEE mains
post #38 of 38 Old 12-07-2013, 10:18 PM - Thread Starter
fwh27713's Avatar
I originally purchased a Klipsch Synergy C-20 and returned it. It was made of plastic and did sound inferior relative to the F-30s. I purchased a RC-500 and a pair of RS-400s from Crutchfield. I am happy with the sound and they sound well matched to my novice ear.
Now I just need to upgrade my subwoofer! Anyone have any recommendations to of with my setup?
fwh27713 is offline
Reply Speakers
