DENON AVR-X4000 with B&W CM9 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 10-21-2013, 03:22 PM - Thread Starter
tjensen's Avatar
I am considering purchasing the Denon AVR-X4000 receiver and a couple of B&W CM9, but I am unsure if the receiver can power the CM9's (I have heard they are very power hungry).
I like the Denon feature set and it is around my budget. The long term plan is to invest in the full CM series for a full 5.1 setup, but my initial setup would be the receiver and the two speakers. The setup would be used for bluray movies and Spotify music streaming.
Any comments and suggestions would be appreciated.
Thanks! :-)
Panasonic G20 50"
Panasonic DMP-BDT500
Logitech Z-5500 5.1 surround
tjensen is offline
post #2 of 8 Old 10-21-2013, 03:51 PM
GIEGAR's Avatar
Quoted: 706 Post(s)
Liked: 1220
The X4000 is a very good AVR. Unless you have an unusually long listening distance &/or listen at extreme SPL's, it will be fine powering the CM9's.
To relieve the AVR of power sapping low frequency amplification duties, and contribute the most to your listening experience, your next purchase in your upgrade path should be a sub (or two).
Welcome to AVS!
tjensen likes this.
GIEGAR is offline
post #3 of 8 Old 10-21-2013, 05:08 PM
drewTT's Avatar
Quoted: 574 Post(s)
Liked: 601
I power a pair of CM9s with a Harman Kardon receiver and it is plenty loud.
LG OLED65E6 | Marantz AV8802A | Marantz MM8077 | Panasonic DMP-UB900 | PS Audio PerfectWave P3 | B&W CM9 | B&W CM5 | Dual JL Audio Fathom f112
Maingear Drift Z170 GTX 1080 HTPC | BDI Mirage 8227 | Logitech Harmony Elite | Synology DS916+ | TEAC UD-503 | Focal Solo6 Be | Vizio P50-C1
drewTT is online now
post #4 of 8 Old 10-22-2013, 01:29 PM - Thread Starter
tjensen's Avatar
Thanks! - I will see if I can get a demo unit or something :)
tjensen is offline
post #5 of 8 Old 10-22-2013, 02:15 PM
SubSolar's Avatar
Quoted: 119 Post(s)
Liked: 40
It's plenty of receiver for the speakers. I'm running the previous model, Denon 3313. Was using CM9's in the front with CMC2. Have since sold the CMC2 and moved the CM9's in the back for surrounds. Also running 4 ohm MartinLogan Theos and Stage in the front and no problems. Basically doing the worst things you can to a receiver, running 4 ohm electrostats that dip down to under 1 ohm, running different speaker ohm ratings with the 8 ohm CM9's and never a peep of complaint from the Denon.
Samsung 85" 4K, Dolby Atmos 7.1.4 with MartinLogan Theos, Stage, Motion 15, EM-R, Seaton Submersive F2, Denon AVR-X5200W
SubSolar is offline
post #6 of 8 Old 10-23-2013, 01:37 AM - Thread Starter
tjensen's Avatar
I am actually based in Denmark, so the import tax would kill me :) But thanks for the suggestion!
tjensen is offline
post #7 of 8 Old 10-24-2013, 09:31 AM
AcuDefTechGuy's Avatar
Quoted: 175 Post(s)
Liked: 262
My Denon 3312 (similar to X4000) powers my B&W 802D2 just fine in 2.0 mode. It can output 225 Watts per channel x 2 CH into 4 ohms.
These speakers are a lot easier to drive than internet hearsay (or dealers who want to rip you off) suggests.
Don't lose any sleep over it.
AcuDefTechGuy is offline
post #8 of 8 Old 10-27-2013, 03:25 PM - Thread Starter
tjensen's Avatar
After listening to various speaker combinations, I ended up purchasing the following:
2x CM5
1x CMC2
1x ASW 10CM subwoofer
1x Denon AVR-X4000
which I will combine with my old speakers for a 7.1 surround setup. It will be delivered wednesday! :D
tjensen is offline
Reply Speakers
