Help with speaker size setting - AVS Forum | Home Theater Discussions And Reviews
post #1 of 12 Old 10-21-2013, 07:39 PM - Thread Starter
Panda House's Avatar
Just picked up some Infinity Reference 2000.6's for mains, 2000.3's for rears and a Video 1 for a center. Should I set my speaker setting on my receiver to large or leave it at small? I've read someone THX said you should always leave it at small and have an 80hz crossover, but I'm not sure. I have a Yamaha HT5730 if that helps. I know it's low end, reciever is my next upgrade. This is my first home theater build and all together with a Yamaha YST SW-216 subwoofer I'm up to $180 for everything. Which last time I checked would have bought me a plastic Samsung HTIB that can't produce half the sound of one of these Infinites.
Pioneer SC1522K|Mirage Omni 60 Center | Mirage Omni 260 Mains | Mirage Omni FX front heights|
Mirage Omni 60 Side Surrounds| Mirage Omni 60 Rear Surrounds| SVS SB1000
Panda House is offline
post #2 of 12 Old 10-21-2013, 07:41 PM
grasshoppers's Avatar
Quoted: 802 Post(s)
Liked: 506
When using a sub- set to small!
lespurgeon and Panda House like this.
Anthem MRX-300-Outlaw Audio M2200
Rythmik F12 subs
Paradigm Signature S6,C1,S1
Harman Kardon DMC1000 (music)
Assassin HTPC (movies)
grasshoppers is offline
post #3 of 12 Old 10-21-2013, 07:47 PM - Thread Starter
Thank you! If I was to set it to large and still keep the bass going to the sub (My crossover is 90hz I believe), would I just be wasting power?
post #4 of 12 Old 10-21-2013, 07:56 PM
Quoted: 802 Post(s)
Liked: 506
Not sure, you can give it a try. Your speakers will play
Cleaner and louder when set to small and perhaps an
80hz x-over. Bass below 80 will be sent to the sub, your
Amp will have MORE power to send to the speakers
Because it is not using watts to produce bass notes.
Your speakers will play cleaner and louder because they
Don't have to play low bass notes.
Panda House likes this.
Rythmik F12 subs
post #5 of 12 Old 10-21-2013, 07:58 PM - Thread Starter
That was the best explanation of this setting I've ever heard in my life. Well done Grasshopper.
post #6 of 12 Old 10-21-2013, 08:13 PM
Quoted: 802 Post(s)
Liked: 506
It's confusing, my first 5.1 AVR I set speakers to large
Rythmik F12 subs
post #7 of 12 Old 10-22-2013, 11:09 AM
Elihawk's Avatar
Quoted: 1014 Post(s)
Liked: 856
If you want you main speakers to handle the bass (ie no sub) you set them to large...
Set up #1: EMP e5ti, e5Ci, and EMP e5Bi surrounds, Outlaw LFM1 Plus sub, EMP 10i10i sub
Set up #2: Def Tech SM450, CLR2002, SLS Qline surrounds and Klipsch 12wD sub
Set up #3: Philharmonics- BMR in a 2.0 system, music only
Elihawk is offline
post #8 of 12 Old 10-22-2013, 11:29 AM - Thread Starter
I was just looking through my receiver settings and I can set my bass to "Both" meaning front and subwoofer. However when I do I feel like the sub doesn't hit as hard, is this because instead of my front speakers sending signals below 80hz to the sub they're trying to reproduce the bass and only my rears and center are sending an LFE signal to the sub than? Just trying to wrap my head around this.
post #9 of 12 Old 10-22-2013, 05:15 PM
Elihawk's Avatar
Liked: 856
Your subwoofer is the speaker most capable of producing the under 80hz sounds...
Elihawk is offline
post #10 of 12 Old 10-22-2013, 05:38 PM
lovinthehd's Avatar
Quoted: 4588 Post(s)
Liked: 4775
Likely more just because your front speakers simply aren't capable of reproducing those lower frequencies than anything else. When set to "both" I don't know if the sub actually gets less bass/lfe signal than when not set to "both", though I suppose that's possible; the manual really doesn't have a lot to go on here, but the manual implies you should get the lfe/bass to the sub plus whatever your fronts can provide....
Now just wait until you get a sub that can really produce those lower frequencies as compared to the YST216....
lovinthehd is offline
post #11 of 12 Old 10-22-2013, 06:37 PM
duc135's Avatar
Quoted: 154 Post(s)
Liked: 219
This is most likely due to the subs being out of phase with the main speakers and is causing cancellation of the bass frequencies. When you have multiple sources of the same frequencies playing they will either compliment each other (in phase) and increase the volume of those frequencies or they will be destructive (out of phase) and reduce the the volume of those frequencies.
duc135 is offline
post #12 of 12 Old 10-22-2013, 06:44 PM
lovinthehd's Avatar
Liked: 4775
Good point, I assumed he had checked that already.
Reply Speakers
