Can I use JBL CS6100BG speakers with a Yamaha RX-A3010 - AVS Forum | Home Theater Discussions And Reviews
Old 10-22-2013, 03:33 PM - Thread Starter
Chad Hurd's Avatar
As the title says?
I'm buying a Yamaha RX-A3010 and am looking for new speakers.
I want to keep the speakers small, as the towers I have now take up too much space in the living room. I was thinking of JBL-CS6100BGs, but want to make sure they will work with this receiver.
Chad Hurd is offline
Old 10-22-2013, 03:53 PM
afrogt's Avatar
Quoted: 1056 Post(s)
Liked: 757
They'll work fine with the Yamaha 3010 receiver but that's a lot of receiver to drive those satellites. Unless you like the feature set of the 3010 you might be able to get away with a lesser receiver.
Afro GT
afrogt is offline
Old 10-22-2013, 03:55 PM
walterappleby's Avatar
Quoted: 25 Post(s)
Liked: 77
Originally Posted by Chad Hurd View Post
As the title says?
Just curious how you ended up looking at/choosing that receiver and those speakers... they don't really appear to be in the same league with each other.
walterappleby is offline
Old 10-22-2013, 03:57 PM - Thread Starter
Chad Hurd's Avatar
I'm getting the receiver from my boss for cheap...it's sitting on a shelf not being used.
And my current speakers are form a kenwood package I bought about 15 years ago. The sub is blown, and the towers, while good, are just too big.
The speakers aren't a long term investment, they'll probably go downstairs when I purchase better ones down the road.
Old 10-22-2013, 05:18 PM
Elihawk's Avatar
Quoted: 1016 Post(s)
Liked: 860
3-5 years from now, your speakers will still sound the same and your receiver will be dated!
Set up #1: EMP e5ti, e5Ci, and EMP e5Bi surrounds, Outlaw LFM1 Plus sub, EMP 10i10i sub
Set up #2: Def Tech SM450, CLR2002, SLS Qline surrounds and Klipsch 12wD sub
Set up #3: Philharmonics- BMR in a 2.0 system, music only
Elihawk is online now
Old 10-23-2013, 07:57 AM - Thread Starter
Chad Hurd's Avatar
Right. I plan to move the speakers downstairs and I'll likely upgrade to in wall/ceiling speakers in the future for this and future systems in the living room.
Yamaha Rx A3010 Receiver
