Can anyone recommend a not too expensive 2.1 speaker setup? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 10-29-2013, 10:11 AM - Thread Starter
ArnoVanKessel's Avatar
Hello avsforum,
This is my first thread so if I break any rules I'm sorry.
But let me get on with it.
I'm planing to buy a 2.1 audio system.
The budget I have is about 200-250 euro.
I had something picked out:
http://www.pioneerelectronics.com/PUSA/Home/Speakers/Home+Theater+Speakers/SP-BS22-LR
http://www.pioneerelectronics.com/PUSA/Home/Speakers/Subwoofers/SW-8MK2
And maybe a cheap receiver.
But I'm not sure it's a good setup,
So my question is: should I go with these or pick something else?
Also: I already have a high quality sound card, do I still need a receiver for good sound?
Thank you for helping, I'm quite a noob at this :confused:
Sincerely,
Arno van Kessel.
EDIT: This system would be in a small room and be used mainly for music and a few movies.
ArnoVanKessel is offline
post #2 of 5 Old 10-29-2013, 10:37 AM
Liberty76's Avatar
Speakers: http://shop.emotiva.com/collections/speakers/products/xrm61 $250
If you need a receiver for TV/Movies and such:
http://usa.denon.com/us/product/pages/productdetail.aspx?catalog=denonna_us&pcatid=avsolutions(denonna)&catid=avreceivers(denonna)&pid=avre300(denonna) $350
If you are primarily using your 2.1 for primarily music:
Preamp: http://shop.emotiva.com/collections/processors/products/xda2 $300
Amp: http://shop.emotiva.com/collections/amplifiers/products/upa200 $300
Sub: http://www.hsuresearch.com/products/stf-2.html $329
I know I am quite a bit above your budget! BUT, it would be worth it!
You get what you pay for!
Liberty76 is offline
post #3 of 5 Old 10-29-2013, 02:14 PM - Thread Starter
Well, I'm afraid that it is not only above my budget, but also above the amount of money I own...
Also, since I just have a standard consumer audio card, I doubt it will make much use of such a setup.
So sorry, I would love to follow your advice but if it's not under at least 300 euro I can't even consider it.
But thank you very much for your help nonetheless.
Sincerly,
Arno Van Kessel.
post #4 of 5 Old 10-29-2013, 03:39 PM
JerryLove's Avatar
Liked: 79
Inexpensive bookshelf mains with consistently high reviews.
Pioneer (odd they don't sell a variant there)
Infinity Primus 163
Behringer 2030p
Don't know what to recommend for a sub. Good + inexpensive rarely = globally available there.
You should be able to find a used B&W sub inexpensive on the used market. That's I use on my PC.
JerryLove is offline
post #5 of 5 Old 10-29-2013, 07:28 PM
charmerci's Avatar
Quoted: 310 Post(s)
Liked: 196
I don't think that you can get a receiver, sub and speakers (well, anything decent) for that amount. Do you have electronics re-sale shops? (You are from the Netherlands?) Since I've lived in France for a while, I know a few of the available brands. I would suggest a used Denon receiver and then Wharfdale Diamond or Focal speakers. For that amount, I think you would be better off getting better quality speakers and forgetting about the sub for now.
charmerci is offline
Reply Speakers
