KEF Q900 driving issues - AVS Forum | Home Theater Discussions And Reviews
 1Likes
post #1 of 117 Old 10-29-2013, 09:52 AM - Thread Starter
jer181's Avatar
Quoted: 75 Post(s)
Hello,
Can anyone provide feed back on the KEF Q900's. I have them hooked up to an Pioneer Elite SC67 and I am not really amazed by the sound of them... I know they are a way better speaker than what I am hearing. Any suggestions of setup, placement, or any other insight you can give me would be fantastic.
jer181 is offline
post #2 of 117 Old 10-29-2013, 10:01 AM
Transmaniacon's Avatar
Quoted: 1581 Post(s)
Liked: 1381
What exactly do you think you should be hearing instead? Is the bass thin or something? You could experiment with placement, try moving them farther apart or closer, toeing them in more or less, moving them away from back and side walls. If you have a lot of hard surfaces in your room, you coud be hearing reflections, try putting a rug down or blankets on the rear wall to see if you can diagnose an issue. And as always, check your wiring and polarity.
Samsung PN60F5300 | Denon AVR-1713 | EMP E55Ti | EMP E56Ci | EMP E5Bi | Outlaw Ultra-X12
Transmaniacon is offline
post #3 of 117 Old 10-29-2013, 11:08 AM - Thread Starter
jer181's Avatar
Quoted: 75 Post(s)
Yes the bass is fairly thin. I expected to feel more low end and mid's with those speakers. I want to be able to have clearly separated and full sounding "tom's" during a Neil Peart drum solo!!! They sounded great in store...
Thanks for the tips, I will play around with placement and whatnot. I have triple check the polarity and everything looks good. Single wired, knob turning as such and wired into LF.
jer181 is offline
post #4 of 117 Old 10-29-2013, 11:13 AM - Thread Starter
jer181's Avatar
Quoted: 75 Post(s)
If I go up and listen to them and touch them, most of the sound is coming from the top end. Bottom speakers are barley vibrating....
Duleepa Lakmal likes this.
jer181 is offline
post #5 of 117 Old 10-29-2013, 11:15 AM
Liked: 1381
In your reciever, are they set as "Small" or "Large"? If you are just running them in stereo make sure they are set to "Large" so they play full range.
post #6 of 117 Old 10-29-2013, 11:18 AM - Thread Starter
jer181's Avatar
Quoted: 75 Post(s)
Every other thread I posted in people keep telling me to run them as small. I currently just have the 2 speakers hooked up and a 85W old pioneer sub. Won't switching to large take all the bass out of the sub and make it not work?
Do you only switch to small speakers if you have a 5.1 or more? As to my understanding the small vs large is just a bass management feature.
jer181 is offline
post #7 of 117 Old 10-29-2013, 11:29 AM
Liked: 1381
It all depends on how capable that sub is. My guess is that Pioneer sub probably can't keep up with the KEFs hence the thin bass. You could try setting a lower crossover to engage the KEF woofers more, but I would probably unplug the sub and run the towers full range.
Small versus large just tells the receiver to either send the full range signal to the speakers, or apply a crossover. If/when you upgrade your sub, you will probably want to change them to small and set a crossover, or just run MCACC on your Pioneer.
post #8 of 117 Old 10-29-2013, 12:39 PM - Thread Starter
jer181's Avatar
Quoted: 75 Post(s)
Even if I take the sub out of the equation, shouldn't I have more low end with those speakers? what good is having all those speakers if they barely do anything. Any idea of whatcross over I should set it at, I think its at 80 right now.
Thanks for the info, I hope it will help.
jer181 is offline
post #9 of 117 Old 10-29-2013, 01:04 PM
Kini62's Avatar
Quoted: 1675 Post(s)
Liked: 1502
Lose the sub. Your Kefs should easily outperform that tiny sub. Set the AVR to no sub and your speakers will automatically be set to large/full range and then see how it sounds.
Def Tech SC8000
Harman Kardon AVR 1600
PS3, Apple TV, Sharp 70" Qattron
Kini62 is offline
post #10 of 117 Old 10-29-2013, 01:38 PM - Thread Starter
jer181's Avatar
Quoted: 75 Post(s)
Seem's like everyone is giving a different opinion on this matter. I will try, won't hurt. Also I am going to try bi-wiring/amping with my SC-67. Many people on this site swear it does nothing, but everyone on a dedicated KEF Forum on another site say's it makes a world of difference, due to the fact that the switch for single blows donkey balls.
At this point I am open to all and every suggestion. Thanks and keep em coming.
jer181 is offline
post #11 of 117 Old 10-29-2013, 02:18 PM
Bill Fitzmaurice's Avatar
Liked: 5626
Only if you send them bass content, which you do not if the AVR is set to small.
None, if you're using subs for the lows. If everything below 80Hz is going to the subs then all you need from the mains is response down to 80Hz or so, ie., bookshelves.
They are correct. The only value to passive bi-amping is as a marketing tool, so that potential buyers who don't know that it doesn't do anything won't buy something else instead if it's not offered.
Bill Fitzmaurice is offline
post #12 of 117 Old 10-29-2013, 02:22 PM - Thread Starter
jer181's Avatar
Quoted: 75 Post(s)
Do you think I will have to re-run the MCACC setting again?
jer181 is offline
post #13 of 117 Old 10-29-2013, 05:37 PM
Kini62's Avatar
Liked: 1502
I wouldn't. At least not right away. Put in direct or pure direct or whatever Pioneer calls it so it bypasses all EQ and see how they sound unmolested by someone else's idea of what your speakers should sound like in a room they never have been in. wink.gif
Seriously, it shouldn't be difficult. It's two speakers in a room. Either going to work or it's not. I'm sure you don't have endless placement options so just go for it and see what happens.
Def Tech SC8000
Kini62 is offline
post #14 of 117 Old 10-29-2013, 05:44 PM
Liked: 1381
Just unplug the sub and set the speakers to large. As has been mentioned, just try it in direct mode now and see if things sound better. Don't bother bi-amping, that is not the issue hear. The Pioneer sub is holding you back because as Bill mentioned with a crossover, you negate much of the benefit of having towers.
post #15 of 117 Old 10-30-2013, 12:14 PM - Thread Starter
jer181's Avatar
Quoted: 75 Post(s)
When I first hooked them up they were set to large and no sub and still no low end at all. Sure its not that cross over switch having them singled wired? Many people on the AV Forum site under the KEF forum have said they have switch to single wire to bi-wiring/bi-amping and seen great improvements.
jer181 is offline
post #16 of 117 Old 10-30-2013, 12:23 PM
Liked: 1381
http://www.6moons.com/audioreviews/kef2/1.html
See the image there, you want to turn the dials counterclockwise all the way so that they operate in single wire mode. Bi-wiring and bi-amping are not the same thing.
post #17 of 117 Old 10-30-2013, 12:26 PM
Liked: 1381
I am not familiar with the Pioneer speaker setup, but is there a bass option? IIRC my old Yamaha had an option to send bass to a subwoofer or to the mains, in addition to the small/large setting. You also could try running MCACC and see what it does for you. Leave the sub unplugged and see what it sets the speakers at, I have a feeling it has to be a setting somewhere.
post #18 of 117 Old 10-30-2013, 12:36 PM - Thread Starter
jer181's Avatar
Quoted: 75 Post(s)
Yes that is what I have done. Single wired and no yellow showing. But because I have some many used terminals on my SC-67, wouldn't the bi-amping be worth a try at least and see if it makes any difference? Unless I don't have the knob turned enough to that one side, but it is finger tight.
jer181 is offline
post #19 of 117 Old 10-30-2013, 02:46 PM
Liked: 5626
Bypass the switch with jumpers connecting the top to the bottom connectors. That's what the switch does anyway. And no matter what the schlockmeisters call it your rig is not capable of bi-amping. What it is capable of is paralleling power amps, which doesn't do anything worthwhile.
post #20 of 117 Old 10-30-2013, 03:51 PM - Thread Starter
jer181's Avatar
Quoted: 75 Post(s)
how do I go about doing that?( connect speaker wire from the top to the bottom?) So you are saying that I can't bi-amp with all my extra unused amp's on my SC-67?
jer181 is offline
post #21 of 117 Old 10-30-2013, 07:11 PM
Liked: 5626
That's right.
Does it have a built in electronic crossover that sends lows to one set of amps and highs to another, with adjustable frequency to match that which your speakers require? Only then is it bi-amping. Otherwise it's just running amps in parallel, which does nothing.
post #22 of 117 Old 10-30-2013, 07:39 PM
tuleyoil's Avatar
tuleyoil is offline
post #23 of 117 Old 10-31-2013, 11:04 AM - Thread Starter
jer181's Avatar
Quoted: 75 Post(s)
That's right.
Not a clue if it has that or not....
jer181 is offline
post #24 of 117 Old 10-31-2013, 12:33 PM
Liked: 5626
If it does it would be in the owners manual. Even if it does the advantages would be totally realized only if the passive crossovers in the speaker were bypassed or removed. The claimed advantage of passive bi-amping is more power, therefore higher output. The problem is that more power does not allow speakers to go louder, more voltage swing does. Voltage swing using parallel amps is the same as that of one. The added power of using parallel amps allows a bit more current headroom, but not enough to be audible.
post #25 of 117 Old 10-31-2013, 12:40 PM - Thread Starter
jer181's Avatar
Quoted: 75 Post(s)
Isn't that the reason the KEF Q900 has a switch in the back. Don't you just unsrew it and that is the same as removing the cross over? It seems though everyone I have talked to that has these speakers has bi-amped them and said it made a huge audible difference. I know I can get more out of these speakers..... Tell me how to do that then.
jer181 is offline
post #26 of 117 Old 10-31-2013, 05:09 PM
Liked: 5626
Isn't that the reason the KEF Q900 has a switch in the back. Don't you just unsrew it and that is the same as removing the cross over? .
No. All the switch does is to take the place of the jumpers that everyone else uses.
If there was no such thing as Placebo Effect there wouldn't be a name for it. rolleyes.gif
post #27 of 117 Old 11-01-2013, 04:58 AM
Liked: 1381
I would question your amplification, but being a Pioneer Elite receiver, that should not be an issue at all. Did you try running MCACC without the sub plugged in?
post #28 of 117 Old 11-01-2013, 09:11 AM - Thread Starter
jer181's Avatar
Quoted: 75 Post(s)
Yes that is how I first had to hooked up.
jer181 is offline
post #29 of 117 Old 11-01-2013, 09:44 AM
Liked: 1381
I'm not sure if there is an issue or perhaps your expectations are too high? You might as well try bi-amping them, nothing else to lose I suppose.
post #30 of 117 Old 11-01-2013, 10:03 AM
RicardoJoa's Avatar
Quoted: 23 Post(s)
Liked: 24
Maybe you are having too much expectactions from those triple 8's woofers. I hope you know two of those are actually passive radiators.
RicardoJoa is offline
Reply Speakers
Kef Q900bl Black Floorstanding Speaker Each , Pioneer Elite Sc 67 9 2 Channel Thx Select 2 Plus A V Receiver
