Help: Best crossover setting? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 10-30-2013, 02:22 PM - Thread Starter
Maikel400's Avatar
Hello,
I'm looking for the best crossover for my HT.
Onkyo 626
Speaker Specs:
http://www.klipsch.com/quintet-home-theater-system-2012/details#specs
Subwoofer Specs:
http://www.klipsch.com/sw-110-subwoofer/details#specs
Settings:
Front:            120Hz
Center:          120Hz
Surround:       120Hz
LPF on LFE : 120Hz
What would be the best setting?
Maikel400 is offline
post #2 of 8 Old 10-30-2013, 03:07 PM
mogorf's Avatar
Quoted: 1059 Post(s)
Liked: 613
Hi and welcome to AVS,
First you should run Audyssey. Then check how the AVR set the crossovers for each speaker. Set each crossover to 80 Hz if they are lower, but leave them "as is" if higher.
LPF on LFE @120 Hz is OK.
mogorf is online now
post #3 of 8 Old 10-30-2013, 03:28 PM
Kini62's Avatar
Quoted: 1415 Post(s)
Liked: 1302
With those quintets, 120hz would be the lowest I would go. 150 is probably more appropriate.
Def Tech SC8000
Harman Kardon AVR 1600
PS3, Apple TV, Sharp 70" Qattron
Kini62 is online now
post #4 of 8 Old 10-30-2013, 05:08 PM - Thread Starter
Maikel400's Avatar
But my sub is going to 120Hz ?
post #5 of 8 Old 10-30-2013, 05:30 PM
mogorf's Avatar
Liked: 613
Your Onkyo 626 is a modern AVR. That means it has a Bass Management system inside. What does that mean?
The subwoofer output sums up two input signals.
1. The LFE (Low Frequency Effect) signal carried by the .1 channel,
2. The bass signals redirected from all speakers below the crossover point provided the speakers are set to "small" in the AVR.
The LFE channel's LPF (Low Pass Filter) should not be set to anything else than 120 Hz. That's the max. frequency that is recorded into the .1 channel.
The 80 Hz crossover recommendation is based on scientific experiments that have shown that the human ear practically looses its directionality clues at around and below that frequency, therefore it is best to let the subwoofer (aka Big Brother) take care of bass which needs a lot of energy/power to produce the required SPL (Sound Pressure Level).
There's a good read on the subject "Small vs. Large". Worth reading. smile.gif
post #6 of 8 Old 10-31-2013, 12:47 AM - Thread Starter
Maikel400's Avatar
So i run audyssey it sets my speakers to
front 80
center 100
surround 100
Wont it hurt my speakers because they only going till 110hz?
post #7 of 8 Old 10-31-2013, 12:56 AM
67jason's Avatar
Quoted: 79 Post(s)
Liked: 802
front 80
center 100
surround 100
manufacturers ratings on spec sheets vs what speakers do in your room are two different things. you can experiment with higher crossovers to see if it sounds audibly better to you, but is really not necessary based on what the auto-cal and your receiver put them at.
I don't need snobs to tell me how to think, thank you!
67jason is offline
post #8 of 8 Old 10-31-2013, 04:49 AM - Thread Starter
Maikel400's Avatar
So with those settings i will be good
Reply Speakers
