how to hook up Bose Cubes - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 10-31-2013, 11:27 AM - Thread Starter
dboyd44's Avatar
Do Bose Cubes need to be connected through the accustimas sub woofer or can I connect then direct to receiver.
dboyd44 is offline
post #2 of 4 Old 10-31-2013, 04:02 PM
ermghoti's Avatar
Quoted: 57 Post(s)
Liked: 84
To the best of my knowledge, you could run an AVR's speaker outs to the satellite speakers without ill effects on anything. I don't think Bose publishes much information about the specifications of their components, I wouldn't imagine they are particularly low impedance though.
ermghoti is offline
post #3 of 4 Old 10-31-2013, 04:07 PM - Thread Starter
dboyd44's Avatar
thanks I have them now for surronds. They work but the 2 I have for rears are through the bose sub woofer and they appear to have stronger base. trying to use as a 7.1 bose bass module is 5.1
dboyd44 is offline
post #4 of 4 Old 10-31-2013, 04:35 PM
Elihawk's Avatar
Quoted: 1313 Post(s)
Liked: 1144
Bass and Bose cubes, uttered in the same sentence, represents an oxymoron!
Set up #1: EMP e5Ti, e5Ci, and EMP e5Bi surrounds, Outlaw LFM1 Plus sub, SVS NSD SB12 sub, Marantz Slimeline 1504 AV receiver
Set up #2: Def Tech SM450, CLR2002, SLS Qline surrounds and EMPtek10i10i sub, Denon 1910 AV receiver
Set up #3: Philharmonics- BMR in a 2.0 system, music only, Yamaha RXV-363 AV receiver
Elihawk is offline
Reply Speakers
