height speakers - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 11-03-2013, 08:05 AM - Thread Starter
Brad Sutliff's Avatar
Right now I have heights set up. They never have very much sound running through them. Some rain maybe an explosion or plane flying by. So how important is it that they be high quality speakers. Right now I'm using aony sb1000's. Which are crap. But they do the job. By using them am I missing out on something? Is it worthwhile to upgrade these at some point?
Onkyo TXSR607, Mythos 8 Center, Studio Monitor 350's, Klipsch S-10 surrounds, Bic F12 sub
Epson Home Cinema 8100 Projector
Brad Sutliff is offline
post #2 of 3 Old 11-03-2013, 08:39 AM
jevans64's Avatar
Quoted: 187 Post(s)
Liked: 145
Only time I notice my height speakers is when I play Expendables 2 or Dredd since those were specifically mixed for 11.1. There is a DTS Neo:X Sound Check on those discs if you have them. It can probably be found on the DTS website as well.
My height speakers are the DefTech SM 55 running from the AVR, which can't keep up with the rest of my speakers at higher volume levels.
The SS-B1000 should do pretty good, at least on paper, with the other speakers in your system. You'd probably have to step up your entire system to go with better height speakers. My only suggestion on that would be SM 450's up front, CLR 2002 for center, the rest SM 350's, and an external amp to help out the Onkyo.
Denon AVR X7200WA, Emotiva XPR-5, Emotiva XPA-7, Sony XBR 75" 850C, Oppo UDP-203, Roku Ultra.
DefTech BP7000SC (L/R), CLR3000 (C), SM55 (FH), UIW BPZ/A (SB), UIW 75 (TM).
JBL L7 (Sur), EoSone RSR 350 (RH).
PC 2.1 setup. Emotiva Stealth 6, SVS SB16-Ultra sub, Emotiva DC-1 DAC.
jevans64 is offline
post #3 of 3 Old 11-03-2013, 08:56 AM - Thread Starter
Okay thanks for the response jevans. Sounds like you have a pretty awesome system!
Reply Speakers
