Northeast Loudspeaker GTG 'HT Heavyweights' January 18th - Page 31 - AVS Forum | Home Theater Discussions And Reviews
 1Likes
post #901 of 1056 Old 01-18-2014, 01:13 PM
Sibuna's Avatar
Quoted: 373 Post(s)
Liked: 429
its Andrews AT screen, its not actually curved it just looks like that because we leaned it against the wall
Sibuna is offline
post #902 of 1056 Old 01-18-2014, 01:45 PM
raynist's Avatar
Quoted: 1256 Post(s)
Liked: 1196
Thanks. What brand? It looks like the full wall, that is what I am hoping to do, looks easy to remove.
JTR (3 215 RT, 5 212HTR, 2 Growlers, 4 S2's)
PSA (4 Triax's, 3 210T's)
Behringer (4 B1200 Midbass Modules)
raynist is online now
post #903 of 1056 Old 01-18-2014, 02:09 PM
nater1's Avatar
Diy seymor xd if I remember correctly.
nater1 is offline
post #904 of 1056 Old 01-18-2014, 02:32 PM
MX48's Avatar
Quoted: 69 Post(s)
Liked: 40
Yes they are. I have built 3 of them, use a French cleat to hang it. This last one is a little more work tho at 200" diagonal.
Moto
MX48 is offline
post #905 of 1056 Old 01-18-2014, 02:40 PM
raynist's Avatar
Liked: 1196
Moto
Do you have a build thread? Are they easy to do? How expensive?
post #906 of 1056 Old 01-18-2014, 02:51 PM
rush2049's Avatar
Quoted: 83 Post(s)
Liked: 100
Just listened to speaker "A"
Everyone was kicked out and the crew are switching to speaker "B"
For reference before I get too fuzzy.
Channel left is level matched to 75db. Using avr test level. Dito for channel right.
Sub 1 is level matched to 77dB ditto for sub 2. Combined 80dB.
The sweeps are captured at -15 all content played back at -10
Dbuudo07 and Reddig like this.
rush2049 is offline
post #907 of 1056 Old 01-18-2014, 03:11 PM
nater1's Avatar
Any listening to the coaxial speakers during the break? Any thoughts on those?
nater1 is offline
post #908 of 1056 Old 01-18-2014, 03:15 PM
MX48's Avatar
Quoted: 69 Post(s)
Liked: 40
No build threads. Instructions are on the Seymour website
http://www.seymourav.com/articles/DIYFixedFrame.pdf
Here are some tips tho:
-I am a minimalist so I didn't do any of the miter cuts.
-Don't use those metal corner brackets unless you get some super strong ones. They will bend the first time you try to pick up your screen (ask me how I know smile.gif). I just put pieces of 1x3's across the corners and they hold perfectly. I have taken down my 200" screen dozens of times alone and really put some stress on it and it has held up wonderfully, a tribute to the strength of the 1x3's, not my carpentry skills.
-If you have the skill and patience use the grommets/rubber bands. I don't have either so used staples on all three.
-I had my first one angle cut. The next 2 were too big to do it but I have never seen any moire in over 4000 hours of viewing. But I have had JVC projectors which are not supposed to be sensitive to it. YMMV.
-Definitely use the triple velvet around the frame, it is awesome. I also use it on my walls and ceiling around my screen. Makes it a black hole when the lites are off. My room has no lite coming in.
They are so cheap to build is one of the reasons I did 3. At less than $150 (at that time) it was easy to go up in size. My 200" cost about $250. I built a new room so went with the max size I could.
Hope this helps.
Moto
asoofi1 likes this.
MX48 is offline
post #909 of 1056 Old 01-18-2014, 03:31 PM
nater1's Avatar
I helped a friend build his screen, and mx48 is dead on about the corner brackets sucking. Also, follow the stretching plan exactly, we tried it twice thinking we were smarter, and both times got bad wrinkles. We then tried it the "right" way, and it worked perfectly the first try.
nater1 is offline
post #910 of 1056 Old 01-18-2014, 03:45 PM
Sibuna's Avatar
Quoted: 373 Post(s)
Liked: 429
Sibuna is offline
post #911 of 1056 Old 01-18-2014, 03:50 PM
popalock's Avatar
Quoted: 1232 Post(s)
Liked: 1712
If I was a speakon, I'd totally insert myself in anyone of offerings!
Gorilla83 likes this.
popalock is offline
post #912 of 1056 Old 01-18-2014, 03:51 PM
raynist's Avatar
Liked: 1196
Hope this helps.
Moto
If you all take the screen down again can someone snap a picture of the back/bracing? In the link I see the frame they made. Is the black area under Andrews screen AT material also? Looks like it is all one piece.
post #913 of 1056 Old 01-18-2014, 03:55 PM
nater1's Avatar
Look for gorillas thread on his screen, I seem to remember it being excellent
nater1 is offline
post #914 of 1056 Old 01-18-2014, 04:03 PM
mhrischuk's Avatar
Quoted: 63 Post(s)
Liked: 87
See My System Here
Processor: Emotiva XMC-1
R/C/L Amps... (3) Emotiva XPR-1's (1750w x 3 = 5250w)
Surround Amps: Emotiva XPA-5 G2 (200 x 4 = 800w) not using 5th
Zone 2: Emotiva Mini-X a-100 driving 2 Boston Acoustics Voyager 70's
10050 watts total power.
mhrischuk is offline
post #915 of 1056 Old 01-18-2014, 04:06 PM
popalock's Avatar
Liked: 1712
Glory hole FTW!
popalock is offline
post #916 of 1056 Old 01-18-2014, 04:14 PM
Sibuna's Avatar
Quoted: 373 Post(s)
Liked: 429
a bunch of people have biggest difference i noticed in my limited time with them is that the V8 is ~3db down on the high end. this can be changed with a resistor swap on the crossover if one desires. I happen to like it IMO the others are really bright
Sibuna is offline
post #917 of 1056 Old 01-18-2014, 04:21 PM
Archaea's Avatar
Quoted: 2841 Post(s)
Liked: 2420
Speaker B is rocking! I'm really enjoying this one!
Archaea is online now
post #918 of 1056 Old 01-18-2014, 04:30 PM
coolgeek's Avatar
Quoted: 616 Post(s)
Liked: 278
That's the DIYSOUNDGROUP v8 volt?
What else are on offering?
coolgeek is offline
post #919 of 1056 Old 01-18-2014, 04:31 PM
Sibuna's Avatar
Quoted: 373 Post(s)
Liked: 429
Sibuna is offline
post #920 of 1056 Old 01-18-2014, 04:53 PM
Sibuna's Avatar
Quoted: 373 Post(s)
Liked: 429
Sibuna is offline
post #921 of 1056 Old 01-18-2014, 04:55 PM
raynist's Avatar
Liked: 1196
Are you mounting that sub to the garbage can for a cheap cylinder sub? smile.gif
post #922 of 1056 Old 01-18-2014, 05:01 PM
Sibuna's Avatar
Quoted: 373 Post(s)
Liked: 429
there have been many ideas on what to do with that 24 inch monster
Sibuna is offline
post #923 of 1056 Old 01-18-2014, 05:36 PM
jbrown15's Avatar
Quoted: 2523 Post(s)
Liked: 1993
JTR S8
beast audios Beyma Coaxial
I'm really hoping to hear the feed back on how Beast's Beyma coaxial's compare to the S8's.
jbrown15 is offline
post #924 of 1056 Old 01-18-2014, 05:40 PM
coolgeek's Avatar
Quoted: 616 Post(s)
Liked: 278
Me too... honest opinions...
coolgeek is offline
post #925 of 1056 Old 01-18-2014, 05:41 PM
coolgeek's Avatar
Quoted: 616 Post(s)
Liked: 278
What driver is this???? Man, it's huge...
I was considering buying a 24 inch sub from AliBaba once and now not sure if it'll be any good...
coolgeek is offline
post #926 of 1056 Old 01-18-2014, 05:43 PM
Sibuna's Avatar
Quoted: 373 Post(s)
Liked: 429
Sibuna is offline
post #927 of 1056 Old 01-18-2014, 05:45 PM
coolgeek's Avatar
Quoted: 616 Post(s)
Liked: 278
its the stereo integrity 24"
Once you have made something out of it, please post your thoughts... 24 inch subs might just be the next big thing...biggrin.gif
coolgeek is offline
post #928 of 1056 Old 01-18-2014, 06:15 PM
Sibuna's Avatar
Quoted: 373 Post(s)
Liked: 429
im not sure we will make anything out of it, there was talk of running to home depto to get stuff to make a IB out of rillas bathroom, but i dont think thats gonna happen
Sibuna is offline
post #929 of 1056 Old 01-18-2014, 06:39 PM
craig john's Avatar
Quoted: 513 Post(s)
Liked: 718
Can someone there ask Carp or Archea to call me. They have my number.
Craig
Lombardi said it:
Perfection is not attainable, but if we chase perfection we can catch excellence."
My System
craig john is offline
post #930 of 1056 Old 01-18-2014, 06:40 PM
Ryansboston's Avatar
Quoted: 102 Post(s)
Liked: 122
LOL... finally an answer to the question; how many beer-fueled AV enthusiasts does it take to come up with the idea of making an IB on the fly out of someone's bathroom?
All joking aside, the location of the bathroom is perfect for one biggrin.gif So jealous, wish I could be there again with you guys! I'll have a few choice beers in honor of the GTG haha...
Buy my awesome gear so I can buy more awesome gear! ...please...
FS: JTR 215RTs/ 215RM for sale in MA (Willing to ship)
Ryansboston is online now
Reply Speakers
Jtr Noesis 212ht 212ht Lp , Jtr , Seaton Sound Catalyst 12c , Seaton Sound
