Best, fairly efficient, & Decent, in wall speakers for home audio paired with Speakercraft MZC-66 (Polk, BIC America, Def Tech, Klipsch) - AVS Forum | Home Theater Discussions And Reviews
View Poll Results: Which In wall Speakers do you recommend?
Polk Audio RC85i 1 16.67%
Polk Audio 265RT 3 50.00%
Klipsch R-2502 1 16.67%
BIC America FH8-W 0 0%
Definitive Technology UIW 65 0 0%
Other (Please include your recommendation in the comment section) 1 16.67%
Multiple Choice Poll. Voters: 6. You may not vote on this poll
post #1 of 2 Old 11-05-2013, 08:32 AM - Thread Starter
BtrSound's Avatar
I just bought a Speakercraft MZC 66 (http://www.speakercraft.com/products/total-control/multi-zone-controllers?page=shop.product_details&flypage=flypage_sc.tpl&product_id=211&category_id=28). For those of you that are not familiar with it, it is a whole home audio amplifier with 12 channels for 6 zones and 6 sources. I am looking for some fairly decent in wall speakers for whole home audio. I do not expect it to absolutely rock out, but I do want to be able to listen to it fairly loud throughout the entire house.
Challenge:
Speakercraft MZC 66 only has 30 watts per channle but is 4Ohm stable if necessary. I have been told that it is a fairly heafty 30 wats due to voltage, but I am not sure what exactly that means.
Due to the low wattage, I feel that it is important that the speakers are fairly efficient
Due to the use for general whole house audio, i want them to have good dispersion and not too much directionality (This makes me hesitant to buy horn tweeter speakers, but I have never had any so would like opinions on them if someone has had experience.
There will be two speakers in each zone spaced fairly far apart to help disburse the sound.
Speakers I am considering (Indoor & Garage @ 2 per zone):
Polk Audio RC85i:
Tweeter: 1"
Mid/Woofer: 8"
Total Frequency Response: 30Hz - 20kHz
Recommended Amplifier Power: 20 - 100 watts per channel
Efficiency: 90 dB
Nominal Impedance: 8 ohms
Polk Audio 265RT
Tweeter: 1"
Mid/Woofer: 2 x 6.5"
Total Frequency Response: 30Hz-27kHz
Efficiency: 91 dB
Product Weight (each): 8.1 pounds
Klipsch R-2502
Tweeter: 1"
Mid/Woofer: 2 x 5.25"
Total Frequency Response: 47 Hz - 20 kHz
Efficiency: 91 dB
BIC America FH8-W
Tweeter: 6 1/4 Horn
Mid/Woofer: 8"
Total Frequency Response: 35-23 kHz
Recommended Amplifier Power: 20 - 175 watts per channel
Efficiency: 94 dB
Tweeter: 1"
Mid/Woofer: 6.5"
Total Frequency Response: 28 Hz - 30 kHz
Efficiency: 90 dB
I am more than open for other options as well. if anyone has any of these and can provide some feedback, I would greatly appreciate it. I know very little about in wall speakers except that they do not compare to floorstanding or even bookshelf.
BtrSound is offline
post #2 of 2 Old 11-05-2013, 11:47 AM - Thread Starter
BtrSound's Avatar
I have noticed that there is not typically much assistance on in wall speakers on this forum. Does anyone have experience with them? I have three home theater setups (Two with full sixed 7.2 speakers and one with a 5.1 box set). This is simply for accessory music in a whole house system.
BtrSound is offline
Reply Speakers
Polk Audio Rc85i 2 Way In Wall Speakers Pair White , Polk Audio 265rt Ea 3 Way In Wall Speaker , Definitive Technology Uiw 65 Pair Rectangular Two Way Loudspeaker
