Speakers for a condo-sized stereo setup - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 11-05-2013, 12:34 PM - Thread Starter
jbchi's Avatar
I'm currently running a pair of Paradigm Atom bookshelves off of a Marantz NR1402 AVR.  The setup works, but it is obviously anemic on the low end.  When I bought them I thought I'd eventually end up with a sub to fix that.  I was wrong.  I don't have a great place to stick one, and given the fact that I have people living below me I've come to accept that I'll just never be able to play music exceptionally loud or low.
That said, I'd like to move to a setup that goes a lot lower.  Most orchestral music bottoms out by 40hz, so I'd like to aim near that if possible.  Home theater is secondary to music.  I'm not looking to shake the room (quite the opposite), but I'd like to hear as much of the music as possible.  As for genres: orchestral, jazz, blues, bluegrass, modern indie, and pretty much anything that isn't heavy metal, rap, or electronic/dance.
To start, I want to restrict the search to bookshelf speakers -- we have a rather 'spirited' cat and I'm not sure if he could resist floorstanders that looks so much like a 36"+ tall, cloth-covered scratching posts. (side note: amazingly, my fiancee would prefer floorstanders to bookshelves on stands).  They are going to sit closer to the wall than is ideal, probably no more than a foot from the wall to the back of the speaker, at best.
They should be reasonably attractive and need a front grill.  Nice, matching stands would be good.
The normal listening volume will be far under reference.  Even with the little Atoms (~90dB sensitivity) I have now, the AVR is rarely set above -30dB.  That means the speakers need to sound good at low volumes.
Lets set a budget of $2000, not including new amplification if that's needed.  Obviously I don't need to spend all of it.
jbchi is offline
post #2 of 8 Old 11-05-2013, 04:52 PM
JerryLove's Avatar
Liked: 79
There are a number of excellent bookshelves in that range. Some that I'd recommend include:
http://salksound.com/songsurround%20overview%20-%20pricing.htm
http://philharmonicaudio.com/folio-me/html/Phil%20Pages/philharmonitor.html
Do consider strongly using a sub + bookshelf set rather than trying to accomplish everything with the bookshelves. Even an inexpensive sub is likely better than none, and if push came to shove, you could get a down-firing sub and cover all sides with carpet (to protect from cat).
JerryLove is offline
post #3 of 8 Old 11-05-2013, 05:23 PM
zieglj01's Avatar
Quoted: 938 Post(s)
Liked: 846
It will not take a whole lot to beat the Paradigm Atoms - and it is a stretch for them to hit 90 db sensitivity
Put Monitor Audio RX2 on your list - under $1000 > 3 color choices
http://www.audioadvisor.com/Monitor-Audio-Silver-RX-2-2-way-Compact-Loudspeakers/productinfo/MRSRX2/#.UnmJ2vmTj58
__________________________________________
Who AM I
Speakers > Snell K7, EOS 150SP
Receiver > Tascam PAR-200
zieglj01 is offline
post #4 of 8 Old 11-05-2013, 05:31 PM
sonic debauchery's Avatar
Quoted: 59 Post(s)
Liked: 58
Ever thought of the goldenear AON 3's this will give you plenty of low end and is only 14 inches tall. I have heard them and they will blow you away.
A 5 channel system would be wicked.
sonic debauchery is offline
post #5 of 8 Old 11-05-2013, 05:58 PM - Thread Starter
jbchi's Avatar
Thanks for the input so far.  The RX2s were on the list and I had briefly looked at the Aon 3s.  The Salk and Philharmonic are new entries.  The initial list was:
Paradigm Studio 20
Focal Chorus 807w or 807v
Monitor Audio RX2
ProAc 100/110
Ascend Accoustics Sierra 1
Dynaudio Excite x12 or x16
And I know most anything is going to top the Atoms.  They were a good investment to get through the last few years of a PhD, but now that I'm employed it is time to upgrade.
jbchi is offline
post #6 of 8 Old 11-06-2013, 04:54 PM - Thread Starter
jbchi's Avatar
My bigger dilemma is that upgradeitus has hit and I know I'm moving sometime next year.  We're planning to buy a place, so I can do whatever with the space (still small).  I actually just came across a pair of Paradigm Studio 20 v.2s for < $400.  I'm sure they aren't as the more recent v5s, but I think it would still be an upgrade from the Atoms.  And, I don't need to worry about where they will fit in the new place (I figure I can sell them for not a great loss on that).
jbchi is offline
post #7 of 8 Old 11-06-2013, 07:02 PM
JerryLove's Avatar
Liked: 79
Check audiogon or ebay. I suspect you can get v3 or possibly v4 20s for $400ish
post #8 of 8 Old 11-06-2013, 07:53 PM - Thread Starter
jbchi's Avatar
They are listed on AudiogoN, and the seller is local.  I might be able to bargain down a little.  Am I correct in assuming the 20 v2s should be all around better than the Atoms (v6 or 7)?
jbchi is offline
Reply Speakers
Marantz Nr1402 Av Receiver , Paradigm Reference Studio 20
