Matching fronts and centers with Audyssey - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 11-05-2013, 03:57 PM - Thread Starter
jmystikcfl's Avatar
I was previously torn between getting stands for my front speakers to bring them up to ear level or biting the bullet and getting a set of matching towers. Well, thanks to an excessive amount of OT this week and last I've decided to get a new set of fronts (and take the GF on a Disney cruise, but that's beside the point.) My front and rear speakers are Infinity Primus 150's (I thought I had 160's, but happened to notice the model number on the back them this morning) with the Primus C25 center channel.
Conventional logic says that your fronts and center should be from the same brand, same series. I understand that the similar materials and builds will yield a similar quality of sound and will be complimentary. But with the advent of technologies like Audyssey MultiEQ is that still true? Audyssey's web site says that the MultiEQ XT sets individual EQ settings for each channel. Is that enough to overcome sound differences inherent in different speaker makes/models?
jmystikcfl is offline
post #2 of 3 Old 11-05-2013, 04:02 PM
zieglj01's Avatar
Quoted: 1675 Post(s)
Liked: 1569
EQ will not timbre match your speakers
From Bluray forum
http://forum.blu-ray.com/showpost.php?s=4a34e79cefb300a01646d348b036e99c&p=4278584&postcount=3
__________________________________________
Who AM I
Speakers -- Snell K7 > Canton GLS 2 > Boston VS240
Receiver -- Integra 50.2
zieglj01 is online now
post #3 of 3 Old 11-06-2013, 04:55 PM - Thread Starter
jmystikcfl's Avatar
That's a good point that I hadn't considered. Okay, looks like I'll be trying to source a pair of P363's in the near future. Really wish there were a Fry's around here.
Reply Speakers
Infinity Primus Two Way Pc251 Speaker
