BP10's or BP8020ST - AVS Forum | Home Theater Discussions And Reviews
Old 11-07-2013, 06:22 AM - Thread Starter
Bluesrx's Avatar
What would be a better front speaker pair to build with the BP-10 or the 8020.  I have the opportunity to buy either pair new for about $500 and want to act fast.  this is for a smaller setup in the living room for movies and some music.
Thanks in advance,
Bluesrx is offline
Old 11-07-2013, 09:29 AM
Kini62's Avatar
Quoted: 1414 Post(s)
Liked: 1296
That's a really good price. I would go for the 8020s since it has the newer drivers and would be easier to get a matching center.
Def Tech SC8000
Harman Kardon AVR 1600
PS3, Apple TV, Sharp 70" Qattron
Kini62 is offline
Old 11-09-2013, 05:40 AM
Martycool007's Avatar
Quoted: 280 Post(s)
Liked: 176
That would be crazy to go with the 9020's as the BP-10's are a much much better speaker in every category! The BP-10 has larger, 6&1/2" mid-range drivers and a larger cabinet. That means that it will likely have more output throughout the midrange frequencies, and also extend lower, making it easier to integrate a subwoofer. I have personally spent sometime with both the BP-10 & the 8020, and the BP-10 is better in every category.
Martycool007 is offline
Old 11-09-2013, 08:35 AM
Kini62's Avatar
Liked: 1296
The bp10 will not play lower than the 8020. Plus the 8020 has the newer drivers that have a better and clearer mid range.
Plus with the powered woofer they don't require nearly as much power.
No reason at all to go with the older discontinued model unless it was significantly cheaper.
Def Tech SC8000
Kini62 is offline
Old 02-21-2014, 06:38 PM
DahleMilsather's Avatar
I agree with Marty. I bought a set of BP10s in '95, and I should have never let them go. They are not the best speakers I've ever heard, but they are uniquely wonderful, and they're easily the best Definitive ever made. (I'm talking about the BP10, with the soft dome tweeter. That was a sweet, detailed tweeter. The AL one was awful. Awful.)
For some years I sold Definitive, right alongside Polk and Paradigm, and other stuff priced in the high 5 figures. IMHO, when DT started using AL tweeters, metal grilles, and subwoofers EVERYWHERE, they stopped making anything good. Perhaps things have changed since 2001, IDK.
The thing with bipolar speakers is, it's all about placement. I spent hours, and days, tweaking the placement of these (as I do with any speaker), and when you get them where they belong, man you'll know it. These things have good bass going WAY down - probably not to 20, but they're powerful way below where a couple 6.5" cones have any right to be. I never missed having a sub when I had these. It is true that a powered sub takes a big load off your amp. But consider that when I first bought the BP10s, I was running an entry level JVC receiver (rated at 80wpc), and it could make 'em LOUD with ease. Those things are easier to drive than . . . ahh. . . I got nothin'. . . your father's Oldsmobile, maybe. The point is, they are very sensitive and efficient. Just keep tweaking the placement until they sing to you.
Integrated subs.
The thing with subs is, it's all about placement. And, not surprisingly, the best place for your sub usually will not be the best place for your mains. Finding the ideal spot for a sub is so complex that, for most of us, the only way to do it is through the application of a few rules of thumb, and then LOTS of mundane experimentation. I'm talking, get a 25' patch cord, put on a Garrison Kiellor cd, then slowly crawl around the room, listening. Then, move the sub just a little, or turn it 90*, or move it 15' that way. And crawl around the room again. What I'm saying is, your sub probably does not belong where your mains are. And even if it did, do you really want all that reverberation physically connected to your other drivers? A good sub makes the whole house shake. No cabinet can honestly isolate that from drivers mounted 2' away.
Kini does make a good point about the newer speakers being easier to match to a center. But you can find a way to do it. You could buy a Porsche, and drive it without a hood ornament until you find one. Or you could buy a LeCar, because you already know where to get those stylin' door stickers. Your choice. (Of course, the choice really is yours. I merely offer my gentle opinion.)  :)
DahleMilsather is offline
Definitive Technology Bp 8020st Ea Bipolar Tower With Built In Powered Subwoofer Each , Definitive Technology Bp10 Tower Loudspeaker Single Black
