B&W ASW608 driven by Marantz AV7701 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 11-07-2013, 07:26 AM - Thread Starter
anoutsos's Avatar
Quoted: 51 Post(s)
Hi all,
I would like some help with the set-up of my B&W ASW608 sub, which is connected to the AV7701 Marantz Prepro (via a forked RCA-to-2RCA cable --- since the sub has two RCA inputs). Every guide I've read recommends that before running the Audyssey set-up I should set the volume(line) of the sub half-way up. However, even setting it to 40% it starts to hum and sounds like it is being overdriven (the volume of the hum increases proportionally to the line-volume setting). In the end, I set the volume to 20% and on top of that Audyssey calibrated to –7.5dB. This is the setting I am using now.
So, is the Marantz too powerful for the ASW608? Is there danger of destroying my sub? I have recently had the sub's faulty amp replaced (it is known to burn out after a few years), and that cost me a lot of money.
Aris.
anoutsos is offline
post #2 of 2 Old 11-07-2013, 01:48 PM
Selden Ball's Avatar
Quoted: 3503 Post(s)
Liked: 1770
Setting the sub's gain control at the half-way point is just the starting point. You have to check the trim level that Audyssey set its subwoofer output to. If it's pegged at -12dB, then you need to turn the sub's gain control even further. (Audyssey turned down its subwoofer output as far as it could but the subwoofer was still too loud.) Then run Audyssey again. While checking the trim levels, you only need to calibrate using the first microphone position. You don't need to run all eight positions until you're satisfied that the speaker trims are all OK.
If you haven't already, please take the time to read the Audyssey 101/FAQ at http://www.avsforum.com/t/795421/official-audyssey-thread-faq-in-post-51779/51750#post_21782993 It answers your subwoofer gain question as well as many others. The instructions in the pre/pro's manual are woefully inadequate.
Selden
Selden Ball is offline
Reply Speakers
Marantz Av7701 Audio Video Preamp Processor
