Please critique my choices for new setup - AVS Forum | Home Theater Discussions And Reviews
Old 11-09-2013, 07:36 AM - Thread Starter
deltwalrus's Avatar
After a few weeks of research, I think I've settled on the speakers and receiver for my newly-finished basement rec room. Please have a look and critique.
Room size is 19x20x8. I'd like to stay around this total price range for this setup, but my budget is somewhat flexible (probably +/- $200).
Receiver: Denon AVR-X1000
Front: BIC America Venturi DV64
Center: BIC America DV-62CLRS
Rear: BIC America Venturi DV62si
Sub: BIC PL-200 Acoustech
I think these will sound great, but my main concern is towers vs. bookshelves for the fronts. Is this too much? I've never bought towers before and these come highly recommended.
It's been a while since I've bought speakers, when we moved into this house 8 years ago I received a Bose Acoustimass 6 set as a housewarming gift to put into the living room. High WAF for an area that everyone sees, and semi-OK sound, and the price was right. But now I want something better for my basement, and the wife is more open to towers.
Thank you in advance for your input!
__________________________
Too tired to think of a witty sig.
deltwalrus is offline
Old 11-09-2013, 09:29 AM
cel4145's Avatar
Quoted: 2658 Post(s)
Liked: 2990
Just as an alternative to consider in roughly the same price range, Newegg has gotten back in stock the Polk Monitor 60. Last week, they were on sale for $99 each. Wouldn't be surprised if they are on sale again in the next few weeks (Newegg often put these on sale when in stock). Not saying that they are necessarily better, but another popular choice on AVS in that budget range.
As for the sub, (a) there is no reason to match the sub brand with the speakers and (b) that's a big space, and the PL-200 might be underwhelming at high volumes. I would suggest putting any additional budget toward dual PL-200s or dual of something equivalent.
Living room HT: Energy RC-50, Ascend Sierra Horizon w/RAAL, Ascend Sierra 1, PSB Imagine XA | PSA V1500 and CHT SS 18.1 | Denon X4200W | modified Dayton SA1000
Other rooms: CBM-170 SE | SVS SB-1000 | Audio-GD NFB-11 | Parasound Zamp | JBL LSR305
Headphone & Portable AKG K7XX | NAD HP50 | AKG K550 | Soundmagic E50 & E80 | DX50 | E12 | X1
cel4145 is offline
Old 11-09-2013, 02:53 PM
GTZ
GTZ's Avatar
Quoted: 14 Post(s)
X2. That's alot of cubic feet and IMHO 2 subs will give you a much better listening experience.
GTZ is offline
Old 11-09-2013, 03:22 PM - Thread Starter
deltwalrus's Avatar
Agree with both points, this happened to be a well-rated sub in my price range. I may start with the one and add a second if I feel the need.
Out of curiosity, what single sub would fill that space well without breaking the bank, if that's possible?
Thanks for the feedback, both of you.
Old 11-09-2013, 03:49 PM
Kini62's Avatar
Quoted: 1415 Post(s)
Liked: 1301
PA 150 it doesn't have much below 30hz. But above that it rivals many $1000 subs for output.
Def Tech SC8000
Harman Kardon AVR 1600
PS3, Apple TV, Sharp 70" Qattron
Kini62 is offline
Old 11-09-2013, 06:17 PM
Hopinater's Avatar
Quoted: 1783 Post(s)
Liked: 4393
I can't say I know very much about your choice of speakers but here are some general thoughts to keep in mind when putting together a system.
1. Towers over bookshelves for L and R channels. That's not to say that there are not good bookshelves out there because there are plenty of them. But over all if there is a set of towers in the same line as the bookshelves I would normally look seriously at the towers if your space allows (but there exceptions to every rule).
2. Get the best center channel you can that is timbre matched to the L and R channels. Those three channels together account for most of the sound in the movies you watch.
3. Get the best AVR you can afford with what you have left after you find the best speakers you can afford (edited). This will future proof you (or at the very least it will usually buy you a little more time before upgraditis infects you).
4. Get the best subwoofer for your money. In my opinion this means looking at the id companies (SVS, PSA, HSU, Rythmik, and Outlaw). They are by far the best bang for your buck.
You have 3000+ cu ft in your rec room, that's a good size space to pressurize for adequate bass. I would suggest looking at the offerings of the companies listed above. Especially since people are pointing you to going dual subs due to the space you have. You might find a single sub from PSA, HSU, Rythmik or SVS would provide more bass than dual BIC subs. Don't hesitate to email any of those ID companies and ask for help. They have great customer service.
That being said, dual subs tend to be better than a single sub in any room for smoothing out the bass across the listening positions. So if possible, I suggest going dual subs from one of these id companies. However, there is a limit to every budget so you have to weigh every choice against your budget. That's the challenging part of putting together any system. Good luck and have fun with it.
Subwoofers: dual PSA V3600's with a PSA XV15se nearfield
Speakers: PSA MTM-210T L/R - PSA MTM-210 Center- PSA 110sr Surrounds
Denon X4200 - Sony BDP-S5200 - Panamax M4300 - Direct TV - Apple TV - Xbox360
Hopinater is offline
Old 11-09-2013, 08:00 PM
Elihawk's Avatar
Quoted: 1016 Post(s)
Liked: 860
I agree, except on one point. Get the cheapest Avr that has the power and features you need. A great Avr and crappy speakers will sound like crap. Spend as much of your budget on speakers and sub as possible. In 3-5 years, your Avr may well be obsolete...
Hopinater likes this.
Set up #1: EMP e5ti, e5Ci, and EMP e5Bi surrounds, Outlaw LFM1 Plus sub, EMP 10i10i sub
Set up #2: Def Tech SM450, CLR2002, SLS Qline surrounds and Klipsch 12wD sub
Set up #3: Philharmonics- BMR in a 2.0 system, music only
Elihawk is offline
Old 11-09-2013, 08:20 PM
Hopinater's Avatar
Liked: 4393
Good point and I agree, I should have stated "the best AVR you can afford with what you have left after you find the best speakers you can afford". I think I may edit my list to say that. Thanks for the crucial catch.
