Crossover recommendations for Klipsch speaker/sub combo - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 11-09-2013, 01:14 PM - Thread Starter
seanbryan's Avatar
Quoted: 245 Post(s)
Liked: 160
I have the following Klipsch speakers:
Sub:RW-12d
L&R towers: RF-82ii
center: RC-42ii
Using the Denon AVR-2313
Initially, audessy set the towers to "large" and their range to "full" with the "small" center channel having a crossover of 80HZ
I thought the low frequency sounded very weak with these settings, so I changed the towers to small and the crossovers are now at 40HZ
Bass is now much more pronounced. I also experimented with setting the sub to "punch" instead of "flat", but I haven't run audessy again after making that change.
Considering this receiver, speaker, and sub combination, does this sound reasonable or can someone provide guidance on different crossover/sub/receiver settings?
I know "a little" about video, but I'm totally in the dark when it comes to audio, so some advice would be appreciated.
seanbryan is offline
post #2 of 7 Old 11-09-2013, 08:05 PM
Elihawk's Avatar
Quoted: 1013 Post(s)
Liked: 854
I would set the crossover at 80hz. Those speakers are not capable of playing down to 40hz (+/- 3db)!
pokekevin likes this.
Set up #1: EMP e5ti, e5Ci, and EMP e5Bi surrounds, Outlaw LFM1 Plus sub, EMP 10i10i sub
Set up #2: Def Tech SM450, CLR2002, SLS Qline surrounds and Klipsch 12wD sub
Set up #3: Philharmonics- BMR in a 2.0 system, music only
Elihawk is offline
post #3 of 7 Old 11-09-2013, 10:32 PM
pokekevin's Avatar
Liked: 102
+1
pokekevin is offline
post #4 of 7 Old 11-09-2013, 11:41 PM - Thread Starter
seanbryan's Avatar
Quoted: 245 Post(s)
Liked: 160
Thanks for the info.
I'll set the crossovers for the RF-82ii's to 80 then.
post #5 of 7 Old 11-10-2013, 08:17 AM
Elihawk's Avatar
Liked: 854
Your subwoofer is much more suited to playing the 40-80hz freq, so your sound quality should improve.
Elihawk is offline
post #6 of 7 Old 11-10-2013, 08:29 AM
zieglj01's Avatar
Quoted: 938 Post(s)
Liked: 846
Sub:RW-12d
L&R towers: RF-82ii
center: RC-42ii
Here are some measurements of the RF-82ii speakers
http://www.hometheaterhifi.com/surround-sound-speaker-systems/surround-sound-speaker-systems-reviews/klipsch-51-reference-ii-speaker-system-for-the-home-theater/page-4-the-klipsch-reference-ii-5-1-home-theater-speaker-system-on-the-bench.html
psgcdn likes this.
__________________________________________
Who AM I
Speakers > Snell K7, EOS 150SP
Receiver > Tascam PAR-200
zieglj01 is offline
post #7 of 7 Old 11-10-2013, 01:50 PM - Thread Starter
seanbryan's Avatar
Quoted: 245 Post(s)
Liked: 160
Thanks again.
Being a "sound dunce", I assumed Audessy would have selected the most appropriate settings and crossover levels. But it was clear that it didn't sound right after running it for the new RF-82's I added.
Much better now!
Reply Speakers
Klipsch Rw 12d 12 Subwoofer Each , Klipsch Rf 82 Ii Reference Series Floorstanding Loudspeaker Black , Klipsch Rc 42 Ii Reference Series Center Channel Loudspeaker Black Each , Denon Avr 2313ci Receiver
