Using math to figure out how loud my speakers would be? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 11-10-2013, 05:29 PM - Thread Starter
Harry Muscle's Avatar
Over the last few days I've been trying to determine whether my proposed 50W receiver (Marantz NR1603 or similar) would be powerful enough to drive the Pioneer SP-FS52 tower speakers I'm hoping to get. The majority of the answers seemed to have been yes, maybe, and no ... so I'm still trying to figure things out and I decided to turn to my good friend math to solve the problem.
However, since I'm not an acoustic expert I wanted to get feedback on this to make sure I'm not making some stupid assumptions or mistakes.
So here goes the math:
The speakers have a 87db sensitivity at 2.83V and are 6ohms. That means that they produce 87db at 1m when being driven with 1.33W (2.83V @ 6ohms = 0.47amps | 2.83V * 0.47amps = 1.33W). Doing some wonderful logarithmic math we see that going from 1.33W to 50W increases our sound output by 15.75db to 102.75db. However, that's at 1 meter away. I will be sitting 8 feet away or 2.43 meters. Again doing some math we figure out that this increase in distance will drop our db by 7.7db to 95db. Now assuming the exact same sound is being played by both left and right speakers we add 3db to the total volume bringing us to 98db.
So in the end I know that if I put 50W of power into these speakers I will get 98db from them at my sitting distance. Does all this make sense?
Harry
Harry Muscle is offline
post #2 of 7 Old 11-10-2013, 05:33 PM
pokekevin's Avatar
Quoted: 18 Post(s)
Liked: 102
http://myhometheater.homestead.com/splcalculator.html ?
pokekevin is offline
post #3 of 7 Old 11-10-2013, 05:48 PM
Mike Garrett's Avatar
Quoted: 7097 Post(s)
Liked: 4797
Harry
If you want clean sound, then I would subtract 3 db, so you are not running the AVR at it's limit. Power compression may rob you a little bit, but not much, since you are now talking about only 25 watts out of the AVR.
mjgarrett100@gmail.com
Mike Garrett is offline
post #4 of 7 Old 11-10-2013, 06:07 PM
olletsoc's Avatar
Liked: 39
you also need to consider that that 50W max output is at 8ohm. at 6 ohm it is rated for a max of 80W
olletsoc is offline
post #5 of 7 Old 11-10-2013, 06:36 PM
AcuDefTechGuy's Avatar
Quoted: 175 Post(s)
Liked: 262
87dB/2.83v/m, 2.43m, 47 watts into 8 ohms & 62 watts into 6 ohms will produce 96dB per one speaker or 99dB per 2 speakers.
The $300 Denon 1612/1613 can output 118.5 WPC into 8 ohms x 2Ch, 141.5 WPC x 2 Ch into 4 ohms.
74 watts/8 ohms & 98 watts/6 ohms will produce 98dB/1 speaker or 101dB/2 speakers.
If the speaker is all or mainly 8 ohms, then 118 watts into 8 ohms could produce 100dB/1 speaker or 103dB/2 speakers.
AcuDefTechGuy is offline
post #6 of 7 Old 11-10-2013, 07:28 PM
Bill Fitzmaurice's Avatar
Liked: 5687
Almost. First off, you want 6dB of headroom, so a realistic figure of how much power you'll be delivering is 12.5w. If you really need 50w continuous output you want at least a 200w/ch amp. That takes you down to 93dB, but in practical terms that's probably plenty. However, there are two errors in your calcs. The inverse square rule applies in an anechoic space. In a room you can figure a 3 to 4dB loss per doubling of distance from the source will be closer to the actual. And two speakers driven with the same voltage level produce 6dB more than one.
Bill Fitzmaurice is offline
post #7 of 7 Old 08-24-2014, 09:28 AM
Okv
Okv's Avatar
Quoted: 116 Post(s)
Liked: 109
http://www.kvalsvoll.com/Articles/Au...culatorspl.htm
This will calculate all you want to know about spl and power for loudspeakers.
Just keep in mind that even though the calculator is theoretically correct, the usability of the calculations will depend on the accuracy of the input data, meaning, if the specified sensitivity for a speaker is off, then the calculated spl will also be wrong.
Acoustic properties of the room and speaker radiation will also be approximate.
If you dimension for spl as measured with ordinary spl meters, you should add at least 15-20dB from a dB(C) value, because peaks will be significantly louder than the average.
EDIT: Did not notice the date, this is a very old thread..
Okv is offline
Reply Speakers
Marantz Nr1603 Slim Line Av Receiver , Pioneer Andrew Jones Sp Fs52 Flr Stand Loudspeaker
