What speaker mount to use for surround sound speakers and bookshelf speakers - AVS Forum | Home Theater Discussions And Reviews
Old 11-10-2013, 07:38 PM - Thread Starter
gan222's Avatar
I would like to hang them in a 40% angle from the wall (not from the ceiling)
gan222 is offline
Old 11-11-2013, 11:36 AM
afrogt's Avatar
Quoted: 1053 Post(s)
Liked: 755
Possibly the Pinpoint wall mounts...
http://www.amazon.com/Pinpoint-AM-40B-Clamping-Bookshelf-Speaker/dp/B002UV03MW
you didn't mention what speakers you have.
Afro GT
afrogt is online now
Old 11-11-2013, 11:57 AM - Thread Starter
gan222's Avatar
I am planning to buy klipsch rs 42 II and rb 51 II speakers
The rs 41 has a trapezoid shape (surround speakers)
The mount you recommend can tilt only 18degrees
I would like a 45 degree angle tilt of the speakers when hanging from the wall.
Thanks for your reply
gan222 is offline
Old 11-11-2013, 12:09 PM
tezster's Avatar
Quoted: 410 Post(s)
Liked: 282
Are you tilting the RS 42 speakers as well? I think these are typically mounted flush against a wall - how high on the wall will they be?
tezster is offline
Old 11-11-2013, 04:00 PM - Thread Starter
gan222's Avatar
Walls are 9 feet high.
So I was thinking that the speakers has to be angled towards where I sit on the sofa so that I receive the sound correctly from the speakers.
Is this a wrong assumption?
Should the speakers be only placed at ear height so that they are not angled down?
Any pointers are appreciated
gan222 is offline
Klipsch Rf 42 Ii Reference Series Floorstanding Loudspeaker , Klipsch Rb 51 Ii Reference Series Ii Bookshelf Loudspeakers Black
