Any experiences with Magnepan speakers in a music listening setup? - AVS Forum | Home Theater Discussions And Reviews
Old 11-10-2013, 10:47 PM - Thread Starter
grigorianvlad's Avatar
Quoted: 120 Post(s)
Liked: 611
I am considering replacing my Polk LSi-9s fronts
with Magnepan Super MMGs.
IS this going to be a worthwhile upgrade? I am not looking for lots of punchy bass to rattle the house. I have a sub for that. Just the two front speakers that will produce a more detailed, transparent and midrange-clean musical sound.
Here is my setup:
AVR - Pioneer Elite VSX-53
Power Amp - EMotiva XPA-3
Sub - Sunfire HRS-10 (1,000W)
The room is medium to small size opening on the right side into a very large atrium with steps to the upper floor on the other side. The room has a problem with bass (the way around, I think )
So, these current LSI-9s are plenty for me. I listen to music at -40 to -30 (out of the -80 to +10 AVR volume range)
Who has experience with these Magnepan Super MMGs? Particularly, in settings similar to mine with a similar gear?
Thanks a lot, everybody.
DAC: Wyred4Sound DAC1LE || Processor: Marantz AV8801 11.2 Ch || Power Amps: Audio Research VS110 (100W tube) || Emotiva XPR-2 (600W), Emotiva XPA-5 Gen 2 & UPA-500 (200W/80W) || L/R Speakers: Eminent LFT-8b , Magnepan 2.7, Center : Polk LSiM-704C, Sur: Polk LSiM-703 || Sub 1: Rythmik F25 (800W). Sub 2: Sunfire True Signature TS-EQ12 (2,700W) || Cables: MIT terminator 2 Biwire, 4, Exp; Cardas Crosslink || Power: Panamax M5300 || HP: HifiMan HE560
grigorianvlad is offline
Old 11-11-2013, 12:07 PM
DonH50's Avatar
Quoted: 1800 Post(s)
Liked: 1336
There is a Magnepan thread. I have a similar system driving older Maggies but no experience with your Polk's and have not heard the MMG. The sound and setup is different enough that you should really try to hear a system.
Magnepan thread: http://www.avsforum.com/t/1086093/the-official-magnepan-owners-thread/2970#post_23900610
"After silence, that which best expresses the inexpressible, is music" - Aldous Huxley
DonH50 is offline
Old 11-14-2013, 11:26 AM - Thread Starter
Quoted: 120 Post(s)
Liked: 611
Thanks. I will post there. I have so many questions that will hopefully be answered.
Polk Audio Lsi9 Bookshelf Speakers Pair Ebony , Pioneer Elite Vsx 53 Av Network Receiver 7 1 Channel 3d , Emotiva Xpa 3 Amplifier
