Novice question about powered subwoofers - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 11-11-2013, 02:37 AM - Thread Starter
Panda House's Avatar
Hi guys, I currently have a Polk Audio PSW10 I picked up on clearance from Best Buy for $51.29. Needless to say I need a subwoofer with a little more oomph. I know I can't afford high end and I'm browsing e-Bay as we speak and my local Craigslist but do you guys have any thoughts on a specific one? I'm looking to spend $200 max and I don't care if it's used or not. I found a 10 inch 55watt Klipsch for $169.99, It's a KSW10 or something along those lines.
Pioneer SC1522K|Mirage Omni 60 Center | Mirage Omni 260 Mains | Mirage Omni FX front heights|
Mirage Omni 60 Side Surrounds| Mirage Omni 60 Rear Surrounds| SVS SB1000
Panda House is offline
post #2 of 7 Old 11-11-2013, 05:25 AM
jproy13's Avatar
Liked: 26
Click me! smile.gif Tons of great information in there.
jproy13 is offline
post #3 of 7 Old 11-11-2013, 11:31 AM
afrogt's Avatar
Quoted: 1054 Post(s)
Liked: 756
A BIC F12 subwoofer will be better than the 55 watt Klipsch KSW-10 sub for $13 more.
http://www.amazon.com/BIC-America-F12-475-Watt-Subwoofer/dp/B0015A8Y5M
The list that was provided above will also be helpful.
Afro GT
afrogt is offline
post #4 of 7 Old 11-11-2013, 01:05 PM
zieglj01's Avatar
Quoted: 938 Post(s)
Liked: 846
The JBL pretty much measures according to specs - I would put it on a short list
http://www.newegg.com/Product/Product.aspx?Item=N82E16882665157
__________________________________________
Who AM I
Speakers > Snell K7, EOS 150SP
Receiver > Tascam PAR-200
zieglj01 is offline
post #5 of 7 Old 11-11-2013, 06:25 PM
swim33's Avatar
Are you looking to use it for music or movies?
-Ben
swim33 is offline
post #6 of 7 Old 11-11-2013, 06:28 PM - Thread Starter
Movies and gaming.
post #7 of 7 Old 11-11-2013, 07:17 PM
swim33's Avatar
Check out the JBL ES250P. The JBL ES subwoofers perform well for movies and can handle some music too. I would take a look at one of those on amazon for $199. Excellent deal for under 200.
-Ben
swim33 is offline
Reply Speakers
Polk Audio Psw10 10 Inch Monitor Series Powered Subwoofer Single Black , Klipsch Ksw 10 10 Inch 225 Watt Subwoofer , Bic America F12 12 Inch 475 Watt Front Firing Powered Subwoofer
