In wall speakers and boundary control - AVS Forum | Home Theater Discussions And Reviews
Old 11-11-2013, 07:05 PM - Thread Starter
bissonnette7's Avatar
Thanks in advance for all of the help as always. Looking to buy in wall speakers for the L and R of this living room. TV will be lifted up slightly to allow for a new center channel. Real questions are twofold:
1. Wife would prefer placement at or below the level of the furniture, ideally midway between floor and top of cabinet. Obviously not ideal, but with boundary control and Audyssey/MCACC, how much would performance be compromised by placing lower versus placing behind or slightly to side of lamps? Space between window and door jamb to furniture is 14" on both sides.
2. Budget is reasonable but not out of this world. Ceiling is sloped and opens up to catwalk. We were looking at the Monitor Audio WT280 IDC as well as the Atlantic Technology ITWS 10 LCR. Open to other suggestions, but needs to be an inwall solution. Could do an inwall center but current plan was a horizontal center channel bookshelf. Not a huge deal, but consider the back surrounds (likely circular and in wall important as well). Receiver is a Pioneer 1522K. This is more for music and some tv/movies
EDIT: we are painting the walls closer to a neutral white and scrubbing off the "stucco effect"
bissonnette7 is offline
Old 11-11-2013, 08:01 PM
Hookedonc4's Avatar
Quoted: 26 Post(s)
That is a very nice look you have in your home. Checkout some of the different options.
Look at some of the cut sheets.
We just picked up the SPL-39LCR-AL for our sitting room.
http://www.jamesloudspeaker.com/products/Speakers/sound-bars
Denon X4000, SC-91, VSX-51,VSX-81 Pioneer Elites and Denon 1611
James loudspeaker inwalls main and future theater
Control4
Other speaker zones DefTech, Polk, Russound, Boston Acoustics
Hookedonc4 is online now
Old 11-12-2013, 08:58 PM - Thread Starter
Thanks Hookedonc4...did you all look at any in wall options? The James website also indicates your choice is OOS..is it discontinued?
Old 11-12-2013, 09:16 PM
Hookedonc4's Avatar
Quoted: 26 Post(s)
They custom make to your dimensions if you are talking about the SPL-39-LCR.
We have James inwall.
Control4
Pioneer Sc 1522k 9 2 Channel Av Receiver , In Wall Speakers
