"Soundstage Issue" - AVS Forum | Home Theater Discussions And Reviews
Old 11-14-2013, 05:35 PM - Thread Starter
Jim Golden's Avatar
I have a 100" diagonal screen and am using B&W CM5's and a CMC across the front. I'm using a 200 watt per channel amplifier in a room that's 17' * 21' with a vaulted ceiling. I'm also using 2- HSU ULS-15 subwoofers in the room.
I like the sound of my system when listing to two channel music (using the 2 CM 5's and ULS-15's), but I'm not satisfied with the soundstage (across the front) while watching movies. What should I do…
A. Replace the two CM5's with CM9's or CM10's?
B. Replace the CMC with a CMC2?
C. Both A and B?
I have "in-wall" B&W surrounds in the side and rear walls, so I'd kind of like to stick with the B&W brand.
Jim Golden is offline
Old 11-15-2013, 04:29 AM
FMW
FMW's Avatar
Quoted: 1652 Post(s)
Liked: 1681
None of the above. Soundstage is created in production and is adjusted by speaker placement and room correction and treatment. Changing speaker models won't have any impact on that unless there is a noticeable difference in tweeter dispersion. Another option would be to listen to movies using whichever processor mode you use for listening to music.
FMW is offline
Old 11-15-2013, 05:01 AM
Transmaniacon's Avatar
Quoted: 1530 Post(s)
Liked: 1319
You may try spreading out your fronts more, can you give us an idea of how everything is laid out, dimensions, etc.
Samsung PN60F5300 | Denon AVR-1713 | EMP E55Ti | EMP E56Ci | EMP E5Bi | Outlaw Ultra-X12
Transmaniacon is offline
Old 11-15-2013, 10:07 AM
ousooner2's Avatar
Quoted: 259 Post(s)
Liked: 149
Pictures would be helpful. What issues are you having specifically?
Panny 65st60 / Denon X1000 / EMP e55ti / EMP e56ci / EMP e5bi / (2) e1010i
Selling 1 e1010i sub: http://www.avsforum.com/forum/209-au...al-10-sub.html
ousooner2 is offline
Hsu Research Uls 15 Subwoofer
