NEWBIE Upgrading speakers on my 6.1 setup. Where to start???????!!! HELP!!! :) - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 11-17-2013, 01:11 AM - Thread Starter
323Anaya's Avatar
My current set up
6.1
AVR :Marantz sr5300
Front L/R :Jensen jhs 1533 (floorstanding)
Polk Audio
Center :Cs10
Surround L/R :RM6000
Rear (center channel RM6000)
B&W
Sub :ASW675
straight to the point , any advice would help on which direction should I start upgrading/replacing my current speaker set up. should I start with the front left and right, center, surround left and right, the rear back, sub or the receiver? And if not asking too much a couple of speaker recommendation. Room wise,,.. Medium size "cubed" room
323Anaya is offline
post #2 of 8 Old 11-17-2013, 07:22 AM
zieglj01's Avatar
Quoted: 938 Post(s)
Liked: 846
I would start with the front 3 speakers
If you want a recommendation, then present a budget.
__________________________________________
Who AM I
Speakers > Snell K7, EOS 150SP
Receiver > Tascam PAR-200
zieglj01 is offline
post #3 of 8 Old 11-17-2013, 10:06 AM - Thread Starter
323Anaya's Avatar
Anything under $400 for all 3 would be good... If possible?
323Anaya is offline
post #4 of 8 Old 11-17-2013, 10:16 AM
zieglj01's Avatar
Quoted: 938 Post(s)
Liked: 846
Cambridge Audio S70 - sold by the each
http://www.accessories4less.com/make-a-store/item/CAMBS70OAK/CAMBRIDGE-AUDIO-S70-5-3-way-Floorstanding-Speakers-Each-Dark-Oak/1.html
Cambridge S50 center
http://www.accessories4less.com/make-a-store/item/CAMBS50OAK/CAMBRIDGE-AUDIO-S50-4-3-Way-Center-Channel-Speaker-Dark-Oak/1.html
Who AM I
zieglj01 is offline
post #5 of 8 Old 11-17-2013, 11:07 AM - Thread Starter
323Anaya's Avatar
I'll look into them thanks a lot !
323Anaya is offline
post #6 of 8 Old 11-17-2013, 01:57 PM
sdg4vfx's Avatar
Quoted: 81 Post(s)
Liked: 140
sdg4vfx is offline
post #7 of 8 Old 11-17-2013, 05:54 PM - Thread Starter
323Anaya's Avatar
So I just looked around and found some Polk Monitor 70 s for about the same price, any opinion?
323Anaya is offline
post #8 of 8 Old 11-17-2013, 06:05 PM
zieglj01's Avatar
Quoted: 938 Post(s)
Liked: 846
Not my preference - however, they will be better than your Jensen speakers.
Who AM I
zieglj01 is offline
Reply Speakers
