Help newbie choosing PC speakers - budget $1000 - $1500 - what's the best bang for buck? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 11-17-2013, 06:15 PM - Thread Starter
speaktome's Avatar
Hi guys, I've been reading forums and with all the information I've begun to get a bit overwhealmed and confused (e.g. active monitors / bookshelf speakers / seperate dac / amp) so have decided to seek specific advice.  Will try to be as detailed and concise as possible.
Situation: Seeking speaker upgrade for desktop in large bedroom . Best I can get for the money.
Budget: $1000 - but will go higher if need be (I am in Australia).
Usage: 50% movies, 40% music, 10% games.
Computer specs: ASRock Extreme 6 motherboard, Asus Xonar DX soundcard; plenty of RAM, plenty of desk space.
Your help and advice is greatly appreciated.
speaktome is offline
post #2 of 4 Old 11-17-2013, 09:07 PM
jevans64's Avatar
Quoted: 187 Post(s)
Liked: 145
I'd probably go with a set of active speakers and just " audio out " from the Xonar. Probably no need for a processor or DAC since that sound card already has a decent DAC. Brands to look at are KRK ( Rokit ), Behringer ( Truth ), Adam Audio ( A5x, A7x, A8x ), and Genelec. Speakers with drivers under 7" will probably need a sub-woofer for movies with the usual brands being SVS, HSU, and PSA. I highly recommend the Emotiva Airmotiv or Stealth line of active monitors, but they are hard to come by for folks in Oz.
My 2-channel PC-only setup consists of Airmotiv 5 with SVS SB-1000 sub and a DC-1 DAC because my only other option is on-board RealTek audio.
KRK or Behringer plus SVS SB-1000 is certainly doable under $1000 but Adam and Genelec will cost you more.
Denon AVR X7200WA, Emotiva XPR-5, Emotiva XPA-7, Sony XBR 75" 850C, Oppo UDP-203, Roku Ultra.
DefTech BP7000SC (L/R), CLR3000 (C), SM55 (FH), UIW BPZ/A (SB), UIW 75 (TM).
JBL L7 (Sur), EoSone RSR 350 (RH).
PC 2.1 setup. Emotiva Stealth 6, SVS SB16-Ultra sub, Emotiva DC-1 DAC.
jevans64 is online now
post #3 of 4 Old 11-27-2013, 03:46 PM - Thread Starter
speaktome's Avatar
Thanks so much for the help guys. You helped to clear things up for me. Giegar, I was just about to pull the trigger on the Rokits you linked to above but at the last minute I found a set of JBL LSR4328P 8" Active Monitors on sale for $1200 and went for them.
For the time being I'll be running them off my Xonar DG soundcard.
Good or bad decision? I don't know. It was more than I budgeted for and perhaps the Rokits would have been a better choice but atleast I've made a choice. And I want to thank both of you for helping me make a choice.
PS. Great avatar Giegar. 8 str8 m8!
post #4 of 4 Old 11-27-2013, 06:09 PM
jevans64's Avatar
Quoted: 187 Post(s)
Liked: 145
Nothing wrong with those JBL speakers. They can be networked and EQed using your computer and a microphone, which is perfect for a PC-based studio setup.
The Xonar DG is fine. Only reason I'm running a DAC is because I can't fit an audio card in my little system.
Reply Speakers
Svs Sb1000 12 Inch 300 Watt Powered Subwoofer
