Cabasse speaker cable - which side is positive? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 11-17-2013, 07:07 PM - Thread Starter
VintageBandO's Avatar
I just connected some Cabasse twin wire speaker cable to my B&O speakers. Unfortunately, I didn't realize they comprized positive and negative wires, as I could not see that they were identified thus anywhere,(both wires inside the outer casing are black)  and I assumed they could could be connected either way round, even though the terminals are neg/pos!
On looking at them again, I now realize one side of the casing has has a groove in it.  I assume this is the positive side.  Can anyone confirm this?
Thank you in advance.
VintageBandO is offline
post #2 of 6 Old 11-17-2013, 07:13 PM
JerryLove's Avatar
Liked: 79
The positive side is which ever side you attach to the positive post on the amp. You can pick arbitrarily if it will be the grooved or ungrooved side. It makes no difference.
JerryLove is offline
post #3 of 6 Old 11-18-2013, 03:50 PM - Thread Starter
Thanks again Jerry.  I have one more issue.  Are you familiar with the male 2-pin plugs used on B&O cables?  There is a flat pin - about 5 mm wide - and a round one.  Can you tell me which one is the positive?  (I assume the flat one, but need to be certain.)
Cheers,
David
post #4 of 6 Old 11-18-2013, 05:13 PM
JerryLove's Avatar
Liked: 79
I am afraid I do not know.
post #5 of 6 Old 11-18-2013, 06:13 PM
DaJoJo's Avatar
Quoted: 355 Post(s)
Liked: 783
the flat one is ground and the round one is positive
Klipsch fronts 2xRF-82-II 150W 33Hz-24KHz , center RC-64-II 200W 59Hz-24KHz , sides 2xRS-62-II 150W 50Hz-24KHz , rears 2xRB-81-II 150W 44Hz-24KHz , heights 2x Salora T25i
Yamaha RX-A3040, SVS PB13-Ultra 1000W 14-200hz
4 mm el cheapo wire / Samsung UE-ES8000S TV+evo 2014 / Optoma DH-1015 Sony PS3
DaJoJo is offline
post #6 of 6 Old 11-19-2013, 03:43 PM - Thread Starter
Thanks DaJoJo.
Reply Speakers
