AVS Forum | Home Theater Discussions And Reviews
AVS Forum | Home Theater Discussions And Reviews (http://www.avsforum.com/forum/)
-   Speakers (http://www.avsforum.com/forum/89-speakers/)
-   -   Identify positive and negative on Bang and Olufsen male speaker plugs (http://www.avsforum.com/forum/89-speakers/1500447-identify-positive-negative-bang-olufsen-male-speaker-plugs.html)
VintageBandO 11-19-2013 03:23 AM
I have vintage Bang and Olufsen passive speakers, 2X S45-2 and 2 x P45.  Can anyone assist me to figure out which pin of the 2-pin male speaker cable plug is the positive?  Is it the flat pin or the round pin?
Bill Fitzmaurice 11-19-2013 06:27 AM
So long as you wire both speakers the same way to the receiver it doesn't matter. Technically there is no positive or negative, as the signal sent on the cable is AC. The positive/negative markings are there so that you'll wire both speakers with the same polarity, but what that polarity is doesn't matter.
VintageBandO 11-19-2013 02:42 PM
Thanks Bill.
Powered by vBulletin® Copyright ©2000 - 2017, Jelsoft Enterprises Ltd.
vBulletin Security provided by vBSecurity (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
