Which wall mount to hang 30lb center speaker - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 11-19-2013, 02:00 PM - Thread Starter
gan222's Avatar
I have to hang my center speaker from the ceiling.
I am unable to find a wall mount that would support the 30 lb weight of the speaker
Would appreciate if any of you have a recommendation
Thanks in advance
gan222 is offline
post #2 of 7 Old 11-19-2013, 03:56 PM
Alan P's Avatar
Quoted: 4697 Post(s)
Liked: 3326
I built a shelf above my TV for mine.
Alan P is online now
post #3 of 7 Old 11-21-2013, 10:41 PM
Randall.White's Avatar
Quoted: 353 Post(s)
Liked: 89
How much weight can your wall mount hold? I found a mount that attaches to the TV wall mount and it can go above or below the TV. The mount can hold up to 50lbs if your wall mount can handle the extra weight.
Randall.White is offline
post #4 of 7 Old 11-22-2013, 04:18 AM - Thread Starter
gan222's Avatar
I have not got one yet. I am going to buy the speakers next week
I would appreciate if you can share the details of the mount you purchased
gan222 is offline
post #5 of 7 Old 11-22-2013, 11:32 AM
jevans64's Avatar
Quoted: 187 Post(s)
Liked: 145
If you have access to the joists in the ceiling, the easiest thing to do is nail a 2 x 6 brace between the joists and use that to secure your speaker mount.
I bought my speaker mounts from FourPair, but I was specifically looking for mounts that were articulating and would take DefTech SM55 bookshelf speakers. They have what looks like a ceiling mount for an LCD TV, but it looks like it could be used for speakers too. The ones I bought aren't the most attractive mounts you'll ever see but they do the job.
Denon AVR X7200WA, Emotiva XPR-5, Emotiva XPA-7, Sony XBR 75" 850C, Oppo UDP-203, Roku Ultra.
DefTech BP7000SC (L/R), CLR3000 (C), SM55 (FH), UIW BPZ/A (SB), UIW 75 (TM).
JBL L7 (Sur), EoSone RSR 350 (RH).
PC 2.1 setup. Emotiva Stealth 6, SVS SB16-Ultra sub, Emotiva DC-1 DAC.
jevans64 is offline
post #6 of 7 Old 11-22-2013, 12:31 PM - Thread Starter
gan222's Avatar
Did you have to screw the speaker to the lcd mount?
I would prefer not to put a screw into the speaker
But all the audio shelves that I see in the websites seem to be on the flimsier side and supported at the center
I have to tilt my center speaker downward so I am afraid that these av shelves with glass bottom might not hold the speaker.
and yes I have access to the ceiling joists.
gan222 is offline
post #7 of 7 Old 11-22-2013, 01:53 PM
Quoted: 353 Post(s)
Liked: 89
PM replied.
Reply Speakers
Definitive Technology Sm55 Bookshelf Speaker Black
