Bad Definitive ProSub 800? - AVS Forum | Home Theater Discussions And Reviews
Old 11-23-2013, 03:41 PM - Thread Starter
balpers's Avatar
I have an all Definitive system:
ProMonitor 800 x4
ProCenter 2000 x1
ProSub 800 x1
All powered by a Denon 3312ci
It has performed flawlessly since I bought it about two years ago and it has been the source of much satisfaction.
I think my ProSub 800 has just died. Here are the symptoms:
  1. About a week ago, we were awakened by a hum from the system which came and went through the night. None of the components in the system was powered on.
  2. Through the past week, the hum kept coming back intermittently independently of whether the system was powered on.
  3. Since the hum seemed to come from the ProSub, I figured I probably had a bad RCA cable. I exchanged it for a new one. With the new cable, there seems to be no response from the ProSub.
  4. The red LED does not come on when the rest of the system is turned on. If I pull the AC power plug then plug it back in, the LED comes on, but there is no sound from the ProSub.
  5. I tried running the system through the Audessey setup. Audessey does not see a subwoofer and no sound comes from it during setup.
  6. I tried running an old CD player through the RCA input to the ProSub to see if I could get any response. No joy.
Does my diagnosis seem correct?
Can anyone think of anything else to try?
I just checked my original documentation and it says that I am covered on electronics for three years and any other defect for five years. Has anyone had experience with Definitive warranty service?
Suggestions would be much appreciated.
Burt
The Consultant's Creed:
I can do it right.
I can do it cheap.
I can do it fast.
You get to choose any two.
balpers is online now
Old 11-23-2013, 04:33 PM
UGAd13's Avatar
Quoted: 100 Post(s)
Liked: 121
Call them...
From the DefTech threads their customer service is great.
/thread
My living room budget build: Samsung PN51E530 / Denon AVR1613 / DefTech PC1000 / DefTech PM60 / DefTech ProSub 60 / Dayton Sub1200
UGAd13 is offline
Old 11-23-2013, 06:49 PM - Thread Starter
balpers's Avatar
Originally Posted by UGAd13 View Post
Call them...
/thread
That's reassuring. Thanks.
I'll give them a call during the week.
Burt
I can do it right.
I can do it cheap.
I can do it fast.
Old 11-25-2013, 02:55 PM - Thread Starter
balpers's Avatar
Call them...
/thread
You were right! I got a response from Definitive about two hours after my email. They are sending out a new amplifier. The swap sounds like a simple job. Many thanks.
Burt
I can do it right.
I can do it cheap.
I can do it fast.
Denon Avr3312ci Receiver , Definitive Technology Prosub 800 120v Speaker Single Black , Definitive Technology Procenter 2000 Compact Center Speaker Single Black , Definitive Technology Promonitor 800 Bookshelf Speaker
