Crossover for KEF Q300 or Q100 with sub - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 11-24-2013, 04:04 PM - Thread Starter
tongr's Avatar
For any members using either of the above speakers what crossover value are you using? Can these both be crossed over at or below 80hz?
tongr is offline
post #2 of 5 Old 11-24-2013, 04:36 PM
Knucklehead90's Avatar
Quoted: 382 Post(s)
Liked: 332
KEF lists the Q300 good to 42hz - however they do not list the roll-off numbers (+ or -) with that spec. I'd say you could safely set them to 80 or 60hz easily. Maybe even 50hz. For movies I set my large tower speakers that play down to 36hz + or - 3db to 80hz on the crossover. It sounds great but then I have 2 large subs to fill in the low end. I've experimented and find I like it that way. For music - different story. No subs - usually.
Yamaha CX-A5000 - Acurus A100x3 & Outlaw 7075 - Salk Song Towers - Custom Selah Audio Center - Oppo 103 - Marantz TT42
***GO SEAHAWKS ***
Twas a woman who drove me to drink. I never had the decency to write and thank her ~ WC Fields
Knucklehead90 is online now
post #3 of 5 Old 11-24-2013, 06:11 PM
JimWilson's Avatar
Quoted: 1263 Post(s)
Liked: 1560
Probably the best place to ask your question would be in the KEF Owners Thread. I'm sure someone there would be able to answer that for you.
If you take yourself too seriously, expect me to do the exact opposite
JimWilson is offline
post #4 of 5 Old 11-24-2013, 06:16 PM
Kal Rubinson's Avatar
Quoted: 673 Post(s)
Liked: 458
One issue to recall is that the sound, particularly of the LF, is highly dependent on the particular placement in your particular room.  Rated LF rolloff is usually assessed under anechoic or quasi-anechoic conditions and not typical rooms.  So, when you ask for recommendations from other users, try to get them to describe room size/dimensions and how the speakers and listener are situated.
Knucklehead90 likes this.
Kal Rubinson
"Music in the Round"
Kal Rubinson is online now
post #5 of 5 Old 11-25-2013, 05:19 AM - Thread Starter
tongr's Avatar
KEF lists these speakers as flat down to 49Hz for Q100 and 42Hz for Q300 (+/- 3db) so it would seem they could be easily crossed over below 80Hz but I wanted to check on other's real world experience because of the issues you mentioned... not for recommendations for setup but rather for purchase evaluation. Thanks
tongr is offline
Reply Speakers
Kef Q100bl Bookshelf Speaker , Kef Q300wa Bookshelf Speakers
