Help testing crossover! - AVS Forum
post #1 of 3 Old 11-25-2013, 08:59 AM - Thread Starter
Barney1's Avatar
Just realized over the weekend I have two blown tweeters in my Paradigm Studio 60s (v3). Called Paradigm and they are sending me out two new replacement ones. My question then is there a simple way to test my crossovers at the speaker level where I removed the tweeters just to make sure they are OK?
Can I just attached a voltage meter to the pos and neg wires that the tweeter was connected to and then test that way? Thanks in advance!
Barney1 is offline
post #2 of 3 Old 11-25-2013, 12:11 PM - Thread Starter
Barney1's Avatar
bump anybody?
Barney1 is offline
post #3 of 3 Old 11-25-2013, 03:13 PM
Gooddoc's Avatar
Quoted: 71 Post(s)
Liked: 175
The chances are your crossover is fine. Testing the crossover like that without a tweeter is not going to tell you much of anything. I would suggest testing it with the new tweeter.
JTR Noesis 212HT x 3 (LCR) powered by Lab Gruppen 10000Q amp
CHT SHO-10 x 4 (sides and rear) powered by Denon 4311
JTR S2 x 2
CHT 18.1 x2
Oppo BDP103D bluray player/Sonos/PS3
Gooddoc is offline
Reply Speakers
User Tag List
