Help: Surround Sound placement / Bipole v Direct - AVS Forum | Home Theater Discussions And Reviews
post #1 of 21 Old 11-26-2013, 05:18 PM - Thread Starter
TheZaha's Avatar
Hey all,
I am finalizing my selections for speakers and am a bit stuck as to getting direct surrounds vs bipole (or perhaps dipole even). Given that I don't have the option to audition bipole/dipole speakers, I was wondering if my decision should be based on where I can actually put the surrounds given my oddly shaped room:
The only 3 options I can really see are:
1. Bottom left corner on the long wall facing the length of the sectional
2a. above the door on the short wall on the top - pro is that is will be on the opposite of 1. surrounding all listening positions, but downside is that it is pretty far away from listening positions (chair and sectional)
2b. on the middle wall that forms the aisle with the sectional - pro is that it forms and even position with the sectional but now it would be on the wrong side of the chair
Note that the "wall" between the chair and the staircase is just an open space (railing).
The surrounds will need to be near the ceiling, so I was leaning direct so I can easily angle them down with brackets, and that given the research I've done my room just isn't made for good use of bipole speakers, but curious to hear your thoughts.
As always I really appreciate everyone's feedback and advice! Thanks!
TheZaha is offline
post #2 of 21 Old 11-26-2013, 07:11 PM
Hopinater's Avatar
Quoted: 2339 Post(s)
Liked: 5877
My surrounds are a bipole/dipole setup and they work great if you have the wall space to use them but I can't imagine of a way I could use the speakers mounted near the ceiling. So speaking strictly from my own experiences I agree with your conclusion, I think you would have to go with the directionals.
Subwoofers: dual PSA V3601's with a PSA XV15se nearfield
Speakers: PSA MTM-210T L/R - PSA MTM-210 Center- PSA 110sr Surrounds
Video: Samsung UN65KS9000 4K SUHD - Oppo UDP-203
Denon X4200 - Panamax M4300 - Apple TV - Xbox360 - Crowson Motion Actuator's
Hopinater is online now
post #3 of 21 Old 11-27-2013, 03:35 AM - Thread Starter
TheZaha's Avatar
Thanks Hopi. How far down the wall are yours? Or at what level in reference to listening position?
TheZaha is offline
post #4 of 21 Old 11-27-2013, 04:21 AM
Johan81's Avatar
Quoted: 31 Post(s)
Liked: 33
I would go with bipole/dipole switchables, the reason manufacturers recommend direct radiators in such situations is that the real power of bipole/dipole will show its true colors when reflected on the walls. Though when you place them less perfectly, this effect gets diminished, but still more than with direct radiators. They recommend direct radiators because you might not be as wowed with the bipole/dipole speakers as you expected and they normally are quite a bit more expensive. Though using them as bipoles will at least get you the same quality as direct radiators and if you are lucky enough even better.
I would also like you to point to this thread:
http://www.avsforum.com/t/874378/surround-speakers-bipole-dipole-quadpole-omnipole-which-one/570
Very good thread with a lot of knowledgeable and less knowledgeable people.
Denon AVR-X3300W Receiver used as 5.1.2, Samsung UBD-K8500, Chario Hiper 2000T fronts, Chario Hiper Dialogue Center, Monitor Audio RXFX Side Surrounds, Dual Rel Quake 200E Subwoofers, JBL Control One Middle Top Atmos Ceiling Speakers, Optoma UHD65 4K Projector
Johan81 is offline
post #5 of 21 Old 11-27-2013, 05:31 AM - Thread Starter
TheZaha's Avatar
Thanks Johan. I did visit that thread before I started this one but I thought given the unique layout of the room (no symmetry, surrounds have to be high up on the wall) so wasn't sure if that would change the decision. It seems like having them very wide is actually a good thing - not so sure about the height. As pointed out they are much more expensive, particularly switchables, so I'll have to think about that.
TheZaha is offline
post #6 of 21 Old 11-27-2013, 06:50 AM
Johan81's Avatar
Quoted: 31 Post(s)
Liked: 33
I don't know what you think of as expenisve, but I bought some MA RXFX speakers which are switchables and I am glad I did. I thought I would have like bipolar better, but I am a complete convert to the dipole team now I have tested them out some more. I never want to go back, that means I would have had to buy new speakers if I wouldn't have done that.... So it is a wise extra investment if you ask me.
Johan81 is offline
post #7 of 21 Old 11-27-2013, 07:40 AM - Thread Starter
TheZaha's Avatar
Oh non not saying it's not a wise investment. If it works and you like the sound then awesome. I'm just concerned that my set up really doesn't allow for it right now. Also given that I'm looking at psb at the moment, their switchables are $1300 which was more than I had budgeted for surrounds. Perhaps going off brand on those isn't a bad decision.
TheZaha is offline
post #8 of 21 Old 11-27-2013, 10:27 AM
Espo77's Avatar
Quoted: 183 Post(s)
Liked: 85
Hey all,
I like the idea of sitting in the "null" of the surround speakers...where you are hearing most everything but a direct sound. Because of the information provided to those channels by movie makers, and the fact that I am hearing non localized information, makes the experience more convincable to me, with movies and Video concerts. The bi-pole or di-pole would be my choice. I would place the surrounds to the rearmost location behind or in the corners of the sofa. Yeah, the single chair might not be in the ideal spot this way, but the sofa sure would.
Espo77's living room equipment: RECEIVER: Yamaha RX-A3030- SPEAKERS: Boston Acoustics M350, M25 center, surrounds, and front heights-
BLU-RAY: Oppo BDP103D- SUBWOOFER: HSU VTF-15H MK2- dedicated circuits for A/V- TV: Vizio P55C-1
Auralex Acoustics LENRD - Auralex Acoustics Roominator
Espo77 is offline
post #9 of 21 Old 11-27-2013, 10:36 AM - Thread Starter
TheZaha's Avatar
Thanks Espo. Would your opinion change if the speakers had to be near the ceiling (i.e. way above the listening position).?
TheZaha is offline
post #10 of 21 Old 11-27-2013, 10:48 AM
Hopinater's Avatar
Liked: 5877
My speakers are at eat level on the side walls. I agree with the other posters that the bipole/dipole are a great way to go and if you could pull it off with your current setup then I would do it. I just realized that you were asking about near the ceiling not hanging hanging from the ceiling like some people do with direct surrounds. I have considered doing this and I think it would work with the bipole/dipole design.
post #11 of 21 Old 11-27-2013, 11:02 AM
Johan81's Avatar
Quoted: 31 Post(s)
Liked: 33
OK, that is indeed a pretty steep investment, though I remember when I went for direct radiators back in the day and having gone for dipoles now, I am so glad I did! So glad, that I really am a bit disappointed in the fact I put it off that long. Yes, your room is not completely ideal for dipoles or bipoles, but it is even less ideal for direct radiators. If you are still doubting to go with dipoles or bipoles, this is pretty easy if you ask me. Can you place the speakers almost precisely at the sides of the couch? If yes, I think that dipoles will do a terrific job, plenty room for reflection.
Johan81 is offline
post #12 of 21 Old 11-27-2013, 11:20 AM - Thread Starter
TheZaha's Avatar
Thanks everyone.
Because of doors and closets (and waf) i would have to hang the speakers on the wall right under the ceiling. The plan was to get adjustable speaker mounts so I can angle the direct speakers downward. In general the diffused idea sounds good to me but if they are so high up and not symmetric not sure if it makes sense. Does that change anyone's opinion on the choice? Ideally I could try both but would need to find a dealer who is ok with that
TheZaha is offline
post #13 of 21 Old 11-27-2013, 11:25 AM
Hopinater's Avatar
Liked: 5877
Another option would be to go with a cheaper set of bi/dipoles. If were were talking front channels I would never say go with a different companies but surrounds play content that really adds to the experience but not something we consciously think about how pristine it sounded, especially considering that dipole diffuses the sound. There are certainly cheaper options than the PSBs. You may want to check into a good set of more affordable speakers from another company.
post #14 of 21 Old 11-27-2013, 11:30 AM
Hopinater's Avatar
Liked: 5877
Thanks everyone.
Check out Crutchfield. They have a 60 day return policy with phenomenal customer service. I have returned items to them with no hassle. One time it was a set of speakers I had for 50+ days. No problem.
post #15 of 21 Old 11-27-2013, 12:46 PM
Espo77's Avatar
Quoted: 183 Post(s)
Liked: 85
"My speakers are at eat level"...I'm getting hungry
Espo77 is offline
post #16 of 21 Old 11-27-2013, 12:54 PM
Hopinater's Avatar
Liked: 5877
LOL. at first I even missed the typo in your post. I was reading it going "Why's he hungry with ear level speakers?" It took me about 20 seconds to finally see it. I must be going blind.
post #17 of 21 Old 11-27-2013, 01:12 PM
Johan81's Avatar
Quoted: 31 Post(s)
Liked: 33
Thanks everyone.
I would also go with cheaper switchables and if you really do not want to go that way, go for bipoles as they are way easier to implement and I liked bipoles better than direct radiators and not a little. Though in my case I can sit in the null and dipole mode is even better, but I wouldn't go with directs. How high will they hang above ear level? It is not really a huge problem hanging them high though, just not ideal, but at ear level is even less ideal, they are supposed to hang at least 2'-3' above ear level.
Johan81 is offline
post #18 of 21 Old 11-27-2013, 01:28 PM
Hopinater's Avatar
Liked: 5877
Good point and I should point out that mine are actually a few inches above ear level as well. I should have been more accurate.
post #19 of 21 Old 11-27-2013, 04:50 PM - Thread Starter
TheZaha's Avatar
They would be maybe 3-4 ft above ear level. I went to a hifi store tonight and they had some cheaper paradigm bipoloes about 2 ft above ear level and I thought they were great.
The salesmen (owner) recommended same as you guys - go dipole or bipole and go symmetric around the couch as that will be primary listening position
TheZaha is offline
post #20 of 21 Old 11-27-2013, 06:58 PM
Espo77's Avatar
Quoted: 183 Post(s)
Liked: 85
"Hang 'Em High"
Espo77 is offline
post #21 of 21 Old 11-28-2013, 01:34 AM
Johan81's Avatar
Quoted: 31 Post(s)
Liked: 33
If you can do 3' it would even be ideal, so I would try to go with that plan to your spouse wink.gif if she doesn't agree, 4' would still be considered pretty darn close to ideal! So you know what to go for I guess tongue.gif
Johan81 is offline
Reply Speakers
