Energy classic 5.1 II vs Klipsch Quintet V - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 11-27-2013, 04:40 PM - Thread Starter
irinakhoi's Avatar
I Guys,
It's my first thread here and i'm happy to join the community :)
I live in a loft, and my "living room" is a 10 feet x 10 feet.  I have to choose between this 2 sets of speakers :
1) http://www.costco.ca/ProductDisplay?storeId=10302&catalogId=11201&productId=286157&partNumber=100073999&langId=-24
2) http://www.futureshop.ca/en-CA/product/energy-energy-take-classic-ii-5-1-speaker-system-6-speakers-take-classic-ii/10151145.aspx?path=4e77ac193099109ed134cc86edff58feen02
The second one will drop at 449$ + tx tomorrow.  I had 2 other speakers in my bathroom.  I want to connect all this on a good amp.  I know, the first one is just a 5.1 amp.
My needs it's a lot of music, good movies (bluray all the time) and Gaming on my PS3 too :)
Help me please :)
Thx a lot
irinakhoi is offline
post #2 of 10 Old 11-27-2013, 05:57 PM
jevans64's Avatar
Quoted: 187 Post(s)
Liked: 145
I'd go with #2 and pick up a receiver to go with it. Maybe a Denon E400 or something is the X series ( X2000 or X3000 ) if you have a bigger budget.
Denon AVR X7200WA, Emotiva XPR-5, Emotiva XPA-7, Sony XBR 75" 850C, Oppo UDP-203, Roku Ultra.
DefTech BP7000SC (L/R), CLR3000 (C), SM55 (FH), UIW BPZ/A (SB), UIW 75 (TM).
JBL L7 (Sur), EoSone RSR 350 (RH).
PC 2.1 setup. Emotiva Stealth 6, SVS SB16-Ultra sub, Emotiva DC-1 DAC.
jevans64 is offline
post #3 of 10 Old 11-27-2013, 06:16 PM
afrogt's Avatar
Quoted: 1053 Post(s)
Liked: 755
afrogt is offline
post #4 of 10 Old 11-27-2013, 09:10 PM - Thread Starter
irinakhoi's Avatar
Ok thanks guys.  I can't go with your option afrogt, because with the configuration of the space I can't put a tower like this.
Hey jeans64, why you choose the take classic and not the klipsch option?
Thx
post #5 of 10 Old 11-28-2013, 06:25 AM
flyng_fool's Avatar
Quoted: 182 Post(s)
Liked: 164
The Energys are much better than the cheapo Klipsch.
Processor: Emotiva UMC-200
Blu Ray: Panasonic DMP-BD655
flyng_fool is offline
post #6 of 10 Old 11-28-2013, 09:59 AM - Thread Starter
irinakhoi's Avatar
Kk smile.gif I will buy the take classic II, i need to find a good amp to mix with the speakers smile.gif probably the E400 like jevans suggest
post #7 of 10 Old 11-30-2013, 10:54 AM - Thread Starter
irinakhoi's Avatar
Finally i bought the take classic II with the denon E400.  The sound is good, but to have good sound with my game or music i need to put the volume of the amp around the 45 - 50.  When i put it at 20 I hear nothing.  The max vol. is 99. I'm so newbie sorry guys.  My connection is very simple.  I have a ps3, my amp and my TV.  Everything is connected with HDMI.  My speakers cables is a monster gauge 16.
I checked on the forum and i found nothing for configure my amp with my 2 bathroom speakers.  I don't know how to configure the multi zone.  Do you have a link for a tutorial please.
Thx a lot
post #8 of 10 Old 11-30-2013, 04:52 PM
jevans64's Avatar
Quoted: 187 Post(s)
Liked: 145
Thx a lot
How to set up Zone 2 starts on page 93 of your Denon manual.
Basically. Connect your bathroom speakers to the Surround Back L & R terminals on the back of the E400. Set your " Assign Mode " to " Zone 2. " Use the remote to select and power up Zone 2 and then select your in put device. Of course, you'll only be able to have a 5.x main zone while using zone 2. I'd just temporarily run wires along the floor first to make everything works then make the connection permanent by running the wires in wire channels at the base boards or run inside the walls and either down to crawlspace or up to attic. 16 gauge wire is easy enough to hide along the baseboard without going through the expense of CL2/CL3 wire for in-wall.
jevans64 is offline
post #9 of 10 Old 11-30-2013, 08:42 PM - Thread Starter
irinakhoi's Avatar
Ok thx a lot jevans.  I will try it tomorrow :).  I don't want to bother you with my thousand questions, but I want to know if is it possible to play my music in stereo in the 7 speakers.  Because now when I play it in the 7 speakers, I don't like the result, I have the voice in the center, a guitar in the bathroom and my song doesn't sound like usually lol.
Thx a lot
(I owe you a beer man :))
post #10 of 10 Old 12-01-2013, 01:18 AM - Thread Starter
irinakhoi's Avatar
Forget my last question, I download the denon remote app on my iPhone (free) and I found the option Multi Ch Stereo.  Wow now my system is perfect :).  I'm so happy
Reply Speakers
Denon Avr E400 , Denon Avr X3000 7 2 Channel Home Theater Receiver , Denon Avr X2000 7 1 Channel Home Theater Receiver
