Monitor 40s vs 60s vs all other speakers - AVS Forum | Home Theater Discussions And Reviews
Old 11-28-2013, 05:19 PM - Thread Starter
mttownse's Avatar
I am looking at getting a 5.1 system for a 12x13 room. Listener is 8 feet from the tv. Ht use only.
Would you recommend a cs2 center m60 fronts and m30s rears with a psw10 sub.
Would it be better to switch out the m60s for 40s and upgrade the sub? What would you go with?
Is this a bad setup for the money. What would be a better option?
mttownse is offline
Old 11-28-2013, 05:25 PM
zieglj01's Avatar
Quoted: 938 Post(s)
Liked: 846
What would be the budget?
__________________________________________
Who AM I
Speakers > Snell K7, EOS 150SP
Receiver > Tascam PAR-200
zieglj01 is offline
Old 11-28-2013, 05:32 PM
Bill Fitzmaurice's Avatar
Liked: 4631
Absolutely. Using a tower with a sub makes as much sense as a screen door on a submarine. As for the sub, PSW 10 is OK, if you get two.
Bill Fitzmaurice is offline
Old 11-28-2013, 05:36 PM - Thread Starter
mttownse's Avatar
I am looking at sub 1000 with receiver. I am no audiophile but I know decent sound when I do, or don't hear it. I have little knowledge of speaker companies and their product capabilities. I just saw newegg with m60s for 80 bucks the last two days and they have good reviews. Do you suggest a certain company for movies? I have heard good things about the energy rc minis as well. I just don't want to be too tinny.
The room has an open end and is a bit strange in shape. Considerations to make with that? Pardon the mess. Construction zone.
mttownse is offline
Old 11-28-2013, 05:44 PM
almadacr's Avatar
I would advise if you are set with Polk , 60's + CS2/CS20 surrounds 40's but a Polk sub , i would chose something like the SVS PB1000 , yes it makes a huge difference compared with the Polk sub .
almadacr is offline
Old 11-28-2013, 05:48 PM
zieglj01's Avatar
Quoted: 938 Post(s)
Liked: 846
zieglj01 is offline
Old 11-28-2013, 06:05 PM - Thread Starter
mttownse's Avatar
I am by no means stuck on polk. Just want good ht sound for a sub 1000 price
mttownse is offline
Old 11-28-2013, 06:35 PM
wronganswer's Avatar
Polk speakers are good for home theater because of the bright sound. I power the Polks with a Denon 1913 and they sound fantastic in my room. I would skip the polk sub.
wronganswer is offline
Old 11-28-2013, 06:44 PM
almadacr's Avatar
If you get a great price on the monitors go for it . The SVS it's $499 but that's one thing that you wont regret it .
almadacr is offline
Old 11-28-2013, 06:50 PM - Thread Starter
mttownse's Avatar
So would you recommend going with the tower 60s up front or the bookshelf 40s.
Do you have other bookshelves you like in said price range.
mttownse is offline
Old 11-28-2013, 07:00 PM
crazyrob425's Avatar
Quoted: 443 Post(s)
Liked: 337
he monitor 60's and cs2 up front with monitor 30's for surrounds.
As for a subwoofer something like the Bic F12 or Polk PSW505.
That is a home theater set up that has an amazing bang for buck value
crazyrob425 is offline
Old 11-28-2013, 07:15 PM
almadacr's Avatar
Depending on the configuration of your room you have the choice of Di/Bipole ones and they take less space than a book shelf ones but this i would advise you to listen to them like the Polk F/XiA4 or sometimes you can find the FXi3 , but they might be a bit higher in price than the monitor 40's .
Keeping all around the monitors i would chose the 40's they move more air than the 30's . Of course all of this is keeping in a controlled budget and great sound ( the 60's are great for music also ) . The sub has i told you is going to be a very important piece of your system and it's best to spend a bit more without having the regret that something is missing since you are the one that as to live with it . Regarding the SVS i know a lot of guys who had several low budget subs and changed for the SVS and they went WoW , but you can also enquire here on the forum for sure there are a SVS owners tread and ask around wink.gif .
almadacr is offline
Old 11-28-2013, 07:24 PM - Thread Starter
mttownse's Avatar
Sounds like a plan. With the 60s, do I have to offset them from the wall or can I keep them right against the wall? How far to either side of the tv is normal for towers
mttownse is offline
Old 11-28-2013, 07:26 PM
zieglj01's Avatar
Quoted: 938 Post(s)
Liked: 846
The Monitor 60's are sold out
Who AM I
zieglj01 is offline
Old 11-28-2013, 07:36 PM - Thread Starter
mttownse's Avatar
They will have them again tomorrow. They have sold out 3 days in a row at that price.
mttownse is offline
Old 11-28-2013, 07:41 PM
zieglj01's Avatar
Quoted: 938 Post(s)
Liked: 846
It seems like you made up your mind - however, skip the PSW10 sub.
Who AM I
zieglj01 is offline
Old 11-28-2013, 07:47 PM - Thread Starter
mttownse's Avatar
Maybe. I am good at flaking though. Probably going to research one more day so any other opinions are always welcome.
mttownse is offline
Old 11-28-2013, 08:34 PM
zieglj01's Avatar
Quoted: 938 Post(s)
Liked: 846
HTD makes nice stuff - look at the Level Three center and bookshelf
http://www.htd.com/Products/level-three-speakers
And then the sub and receiver, that I listed in post #6
Who AM I
zieglj01 is offline
Polk Audio Monitor 40 Am4025 A 2 Way Bookshelf Speakers Pair Black , Polk Audio Monitor 60 Am6025 A 2 Way Floorstanding Speaker Single Black
