car components for bookshelfs in a ht setup, anyone ever try? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 11-29-2013, 02:28 PM - Thread Starter
diceman1000's Avatar
Quoted: 35 Post(s)
so,i have a set of CDT CL61 mids and aset od SEAS aluminum neo tweeters that i recently pulled from my car. i've been contemplating gettin a set of bookshelfs to replace my front speakers and thought that i may be able to use these in conjunction with a 4 or 2 ohm dummy resistor to make a set of bookshelf... what do ou guys think?
these are the mids
1 pr 6.5” mid-woofer
Frequency response 55Hz-5.000Hz
Power handling: 80watt (110Watt Pk)
Impedance 4 Ohm Sensitivity: 91.7dB
Mounting depth: 2.75”
Cut out diameter: 5.75”
Cast frame: OD 6.7
Cone: Reinforced carbon paper cone
Magnet weight 20 Oz
Cone surround Buytal rubber
Impedance: 4Ohm
Voice coil: 1.0” (26mm)
Fs: 70Hz
and these are the tweeters
my biggest question is, will these make a better bookshelf than what i can buy for $50 to $150
diceman1000 is offline
post #2 of 6 Old 11-30-2013, 12:28 PM - Thread Starter
Quoted: 35 Post(s)
Anyone?
Sent from my SCH-R760X using Xparent Skyblue Tapatalk 2
post #3 of 6 Old 11-30-2013, 08:56 PM
Christian's Avatar
You may get better responses from the hobbyist's that frequent diyaudio.com and diymobileaudio.com.
I did it awhile back (probably dating myself). Dropped a Clarion coax into a self-made box, and the results were "meh".
Are you using the included crossover? They are typically designed for car installations where the woofer and tweeter are further apart. The woofers are normally optimized for free-air/infinite baffle applications, and you'll need a box of suitable size. Not to mention the box you build (or get pre-made) needs to be of sufficient quality to ensure nice, inert home for your comps.
I'd think what you build would be better than a $50 pair of bookshelf speaks, but depending on the time your want to invest will determine how good it ultimately is.
Christian is offline
post #4 of 6 Old 12-01-2013, 08:49 AM - Thread Starter
Quoted: 35 Post(s)
Yeah, using the included crossover networks with a 4ohm dummy resistor wired I series was my plan.
post #5 of 6 Old 12-01-2013, 01:56 PM
Bill Fitzmaurice's Avatar
Liked: 5684
Bad plan. Half your power will be burned off as heat in the resistor, and the power capacity of the resistor must be at least equal to, if not greater than, that of the speaker.
Bill Fitzmaurice is offline
post #6 of 6 Old 12-01-2013, 05:03 PM - Thread Starter
Quoted: 35 Post(s)
What would you suggest then?
Sent from my SCH-R760X using Tapatalk
Reply Speakers
