Best Center Channel speakers to match BW686 bookshelf speakers? - AVS | Home Theater Discussions And Reviews
Old 11-29-2013, 03:35 PM - Thread Starter
zeeoo7's Avatar
I'm in a 1 bed room apartment. living room size 14x22.
Sony Bravia HX800 55" 240Hz 3D LCD LED
Pioneer Elite SC-71 Receiver
PS3 Slim (with Blue Ray player 3D)
Comcast Cable (Panasonic HD-DVR)
Bowers & Wilkins 686B Book Shelf Speakers (Front L and R)
BIC America F-12 12" Subwoofer
I bought the receivers and speakers couple of months ago and set up is working fine. (you can see my earlier posts).
I'm not terribly missing the center channel speakers for my small living room and happy with running this set up with F.S. Surround setting in the receiver.
But, I've been on the look out for a reasonably priced center channel speaker from other brands since the B&W center channels speakers are very expensive.
Now. that the black friday deals are on, I thought of getting one now. My preferred price range is less than $250, but might stretch up to $300 for a good speaker.
1. What's the best center channel speaker that match the B&W 686s ?
2. What's the difference between 2-way or 3-way center channel speakers? Does it matter much in relation to the price difference?
3. A Magnolia representative recommended Energy CC-10 as the best match other than B&W. Is it so?
http://www.amazon.com/Energy-CC-10-Center-Channel-Speaker/dp/B001RPXWX4/ref=sr_1_2?s=aht&ie=UTF8&qid=1385767656&sr=1-2
4. I saw other best sellers in Amazon. Are these good match for my speakers?
Polk Audio CS10 Center Channel Speaker
http://www.amazon.com/Polk-Audio-Center-Channel-Speaker/dp/B0018QROM2/ref=sr_1_2?s=aht&ie=UTF8&qid=1385766861&sr=1-2
Yamaha NS-C310BL 2-Way Bass-Reflex
http://www.amazon.com/Yamaha-NS-C310BL-Bass-Reflex-Center-Speaker/dp/B001PZ674C/ref=sr_1_3?s=aht&ie=UTF8&qid=1385766861&sr=1-3
Infinity Primus PC351 Three-way dual 5-1/4-Inch Speaker
http://www.amazon.com/Infinity-Primus-PC351-Three-way-Center-Channel/dp/B0044D1788/ref=sr_1_6?s=aht&ie=UTF8&qid=1385766861&sr=1-6
Klipsch RC-52 II Center Speaker
http://www.amazon.com/Klipsch-RC-52-II-Center-Speaker/dp/B0040QW7KQ/ref=sr_1_20?s=aht&ie=UTF8&qid=1385766861&sr=1-20
Mirage Os3-Cc Premium Omnipolar 3Way Center-Channel Speaker
http://www.amazon.com/Mirage-Premium-Omnipolar-Center-Channel-Speaker/dp/B001GI9EE8/ref=sr_1_5?s=aht&ie=UTF8&qid=1385767927&sr=1-5
4. Is Klipsch line of products better than Energy line of products?
Thanks in advance. Happy Thanksgiving!!
Cheers
Zee
Sony Bravia HX800 55" 240Hz 3D LCD EdgeLit LED
PS4 and PS3 Slim (with 3D Blue Ray player)
Comcast Cable Xfinity X1 DVR (Panasonic HD-DVR)
zeeoo7 is offline
Old 12-07-2013, 11:26 PM - Thread Starter
zeeoo7's Avatar
bumping this thread since there are no replies :-)
zeeoo7 is offline
Old 04-06-2015, 08:09 AM - Thread Starter
zeeoo7's Avatar
bump
zeeoo7 is offline
Old 04-06-2015, 09:05 AM
zibanez's Avatar
Best recommendation is B&W Htm62, same brand and type will make sound timbre match
My suggestion is you should saving more money, until you can afford it. I also doing this when bought my center speakers.
Bedroom theater
Dynaudio DM 2/6 - Dynaudio DM Center - Def tech pro monitor 600 - Def Tech Prosub 600 - Marantz NR1402 - Bantam Gold Power Amp - Clark Synthesis tst 239 - Dune H1 - PS3
zibanez is offline
Old 04-06-2015, 09:10 AM
fatbottom's Avatar
Quoted: 900 Post(s)
Liked: 340
You want the matching B&W center speaker. If possible get the one with more drive units, I had a B&W CC6 it's ok for the price but I think 4 driver speaker offers superior sound quality so I'd try out HTM61
http://www.bowers-wilkins.co.uk/Spea...ies/HTM61.html
I have a couple of speakers similar to that, Celestion A4c is pretty much the same
Pivetta Opera
Bose Jewel speakers.
fatbottom is offline
Old 04-06-2015, 10:09 AM - Thread Starter
zeeoo7's Avatar
Thank you. I've been monitoring HTM61 for some time. Recently, there have been Open Box and Clearance sale of many BW speakers in BestBuy. Just when I was coming around to buying HTM 61, there is this HTM 61 S2 version. S2 will be more expensive since it is newer. Or will I be okay with the older version of HTM61 for now?
zeeoo7 is offline
Old 04-06-2015, 01:03 PM
fatbottom's Avatar
Quoted: 900 Post(s)
Liked: 340
You want the same revision as your L/R as v2- does the v2 have different treble driver/midrange/crossover? ie you wouldn't want B&W 601 s2 L/R with CC6 S1 or S3 as different drivers.
Pivetta Opera
Pioneer Elite Sc 71 , Sony Bravia Kdl55hx800 55 Inch 1080p 240 Hz 3d Ready Led Hdtv Black , Bic America F12 12 Inch 475 Watt Front Firing Powered Subwoofer , Polk Audio Cs10 Center Channel Speaker Single Black , Yamaha Ns C310bl 2 Way Bass Reflex Center Speaker , Infinity Primus Pc351 Center Speaker , Klipsch Rc 52 Ii Reference Series Center Channel Loudspeaker Black Each , Mirage Os3 Cc Premium Omnipolar 3way Center Channel Speaker
Gear in this thread - C310bl by PriceGrabber.com
