Mythos ST-L SuperTower - AVS Forum | Home Theater Discussions And Reviews
post #1 of 13 Old 11-30-2013, 02:35 AM - Thread Starter
Jake Kniefel's Avatar
I have setup a 11.1 system from def tech, the only thing i need are the ST-L Super towers that I preordered from a Mongolia Best Buy, but they keep telling me they have been pushed back another month. does anyone have any idea on an actual release date to come out to the public ? So far the guy at best buy said mid December.  http://www.definitivetech.com/products/mythos-st-l
I hope dropping 5k on these is really worth it. I have the New Denon  9.2 and was looking at getting a Parasound A 51 5 Channel Power Amplifier (just for the two ST-L's), I also bought a pair of Monster M2.4S Bi-wire cables to go from the receiver/amp to the ST-L's
Is there anyone else looking at getting these (ST-L) speakers ?  If so, whats your input ?
My System:
(Left & Right) - Mythos ST-L SuperTower  <--"Ordered"
(Center) - Mythos Ten
(Front Wide) - Mythos Gem XL
(Front Highs) - ProMonitor 1000
(Surround) - Mythos Gem XL
(Surround Back) - Mythos Gem XL
(Subwoofer) - BIC PL200
Additional:
-TV is a Sharp LC-80LE857U
-Monster Power HTPS 7000 SS
-Monster Power AVS 2000 SS
-Denon 4520Cl
-PS4
All Speaker Wires are MONSTER XPHP
All HDMI Cables are Monster Cable - Thx 1000HDX (12ft)
Jake Kniefel is offline
post #2 of 13 Old 11-30-2013, 09:29 AM
Dougofthenorth's Avatar
Liked: 44
IMHO I would be fairly concerned that the Mythos Ten used as a center will not ideally match the Mythos ST-L Super Tower L&R mains, given the front sound stage is most important...
Dougofthenorth
www.turtleshelltortue.org RIP
Dougofthenorth is offline
post #3 of 13 Old 12-01-2013, 05:56 AM - Thread Starter
Yea I hear ya there, if the sound quality is not to my expectations then i can always use the (ten) in another room. good looking out though:)
post #4 of 13 Old 12-01-2013, 01:13 PM
The Pup's Avatar
I asked a similar question regarding my SC8000 and Mythos 10 Center.
According to DF (Chet P.):
"~~The Mythos Ten and SuperCube 8000 are truly compatible with the Mythos ST-L loudspeakers. Since the Mythos ST-L towers have built-in powered subwoofers, you’ll want to spend some time properly adjusting the subwoofer so it integrates or blends well with the towers……As a start, I’d recommend setting the crossover on the subwoofer to the lower side of its adjustment range. Specifically, I’d recommend using a crossover of 40hz – 60hz on the subwoofer….I’d also keep the volume level on the subwoofer on the lower side of adjustment range. (While I have you, the Mythos Ten is the recommended center speaker for the Mythos ST-Ls as well.) If you need any other information, please email me at chet.pelkowski@definitivetech.com."
Jake Kniefel likes this.
The Pup is offline
post #5 of 13 Old 02-22-2014, 02:20 PM
oOOBillO0o's Avatar
Where did you find out that Mythos Ten wouldn't match the Mythos ST-L?
McIntosh Labs! What am I listening to?
oOOBillO0o is offline
post #6 of 13 Old 02-22-2014, 03:06 PM
Liked: 44
I spec'd if his mains had a matched center made model that was specifically for those L&R mainls - didn't see one, hence the post
He then agreed - he never posted back if his trial with what he had worked.
Most makers have a CC speaker in the same line to match the L&R main speakers same tweeters, woofer & cabinet tonality research is done to match in all 3
That's a perfect world scenario - if not drop down to the next in line CC & hope it works well
For example Focal models - 900, 800, 700 & etc all have 3 matched speakers.
It is most important for the 3 in the front soundstage.
Dougofthenorth
post #7 of 13 Old 02-22-2014, 03:35 PM
oOOBillO0o's Avatar
Ha, okay, we have a difference of opinion.
Therefore when I asked, where did you find out the "Mythos Ten used as a center will not ideally match the Mythos ST-L Super Tower L&R mains?"
Next you responded that you saw that there wasn't a center channel speaker that had been released with the ST-L, and thought the above?
nope. I don't agree.
What I will buy off on, is that Deftech should release an updated Mythos Center when they release a new set of Tower Speakers.
If the front stage is so important, check out the ITU, Dolby, THX, Grammy, et al spec on having 3 front matching speakers.
The best center for the Mythos ST-L is the Mythos ST-L. Yep, three of them. forget your flatscreen TV, now you need an acoustically transparent screen and projector.
Back to reality, my recommendation is to buy a Mythos 10 center and wait for an update. Then replace with a matching center. (if anything,besides the topic starter, this will serve as a place on the internet to discuss more since that is how I found your comments)
No big deal.
post #8 of 13 Old 02-22-2014, 07:13 PM
The Pup's Avatar
I am finding the Mythos 10 and ST-L a good match-up--no issues to date.  However, I have no doubt that DF will improve their designs over time.
To repeat:  This is the response I received from Definitive Technology regarding ST-L, SC8000, and Mythos Ten compatibility:
The Mythos Ten and SuperCube 8000 are truly compatible with the Mythos ST-L loudspeakers. Since the Mythos ST-L towers have built-in powered subwoofers, you’ll want to spend some time properly adjusting the subwoofer so it integrates or blends well with the towers. As a start, I’d recommend setting the crossover on the subwoofer to the lower side of its adjustment range. Specifically, I’d recommend using a crossover of 40hz – 60hz on the subwoofer. I’d also keep the volume level on the subwoofer on the lower side of adjustment range.
While I have you, the Mythos Ten is the recommended center speaker for the Mythos ST-L as well. If you need any other information, please email me at chet.pelkowski@definitivetech.com.
Chet Pelkowski Definitive Technology
The Pup is offline
post #9 of 13 Old 02-22-2014, 10:36 PM
oOOBillO0o's Avatar
Thanks Pup, Glad to hear there are no issues with your set-up. Can you please share a photo? I have a short list of Loudspeakers that I want to audition and the Triton One and ST-L are on it.
post #10 of 13 Old 02-23-2014, 08:29 AM
stef2's Avatar
Quoted: 332 Post(s)
Liked: 212
So, did you get your ST-L? some resellers have them in stock. Those are in my upgrade list...
stef2 is online now
post #11 of 13 Old 02-23-2014, 02:13 PM
The Pup's Avatar
oOOBillO0o and tlguapo like this.
The Pup is offline
post #12 of 13 Old 02-24-2014, 06:08 AM - Thread Starter
I'm sitting on my couch. (You can't see them but i have 2 supercube 8000's, 1 on each side of the couch..     Any likes  :cool:
oOOBillO0o and Maddmaster like this.
post #13 of 13 Old 02-25-2014, 12:12 PM
oOOBillO0o's Avatar
Play this..
http://youtu.be/4NjssV8UuVA
Reply Speakers
