In-wall surround: Klipsch or Polk? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 11-30-2013, 12:32 PM - Thread Starter
smoka's Avatar
Quoted: 30 Post(s)
I am trying to add in-wall surround to my setup and I've decided to stay on a budget (below $200 for both speakers). My current setup is a Klipsch Reference/Icon with a Sony receiver (see "Living Room" setup my sig). I initially wanted to high-end Klipsch reference surrounds, but they are way too pricey.
My current options are:
1. Polk RC85i
2. Klipsch Reference R-1650-W
Any suggestions on which is better or any other recommendations in this price range?
FAMILY ROOM: Samsung UN65KS8000, Sonos Playbar + Sub, PS4
A/V ROOM: Sony KDL-55HX820, Harmon Kardon AVR2650, Klipsh Premiere 5.1 (RP-280F, RP-450C, RW-12D, RS-52 II), PS3, Shuttle HTPC
GARAGE: Samsung UN46EH5300, XBOX 360 + Kinect
OFFICE: Plex Server w/ 10TB Media
smoka is offline
post #2 of 3 Old 12-01-2013, 08:25 AM
Mark Henninger
imagic's Avatar
Quoted: 6600 Post(s)
Liked: 11371
The Polks have higher sensitivity as well as higher power handling. Taking a cursory glance, the only reason I see to go with the Klipsch units is if—big if—they are a closer timbre match for your mains. However if you plan to use auto-EQ with your receiver, that might not really matter.
Mark Henninger, Senior Editor at AVS Forum
imagic is offline
post #3 of 3 Old 12-01-2013, 08:55 AM
zieglj01's Avatar
Quoted: 1714 Post(s)
Liked: 1631
Look at HTD High Definition
http://www.htd.com/Products/high-definition
__________________________________________
Who AM I
Speakers -- Canton GLS 2 > Boston VS240
Receiver -- Integra 50.2
zieglj01 is offline
Reply Speakers
Polk Audio Rc85i 2 Way In Wall Speakers Pair White , Klipsch Reference Series R 1650 C In Wall In Ceiling Architectural Speaker 35 Watt 2 Way Coaxial
