Htd level twos vs nht superzero 2.1 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 48 Old 11-30-2013, 07:05 PM - Thread Starter
mttownse's Avatar
Alright folks, I have utilized several peoples opinions on other threads to bring my setup down to 2 options. 5.1 system. Mainly movies. 12x 13 room. Seating distance 8 feet.
1. Nht superzeros 2.1 (5 bookshelf speakers and matching sub) $639.
2. Htd level two setup. (4 bookshelf speakers and a matching center. Need to determine sub) $529 plus sub.
I can't pick. Any experiences or information would be great. If you like the level 2s, what sub would you suggest?
mttownse is offline
post #2 of 48 Old 11-30-2013, 07:30 PM
Kini62's Avatar
Quoted: 1410 Post(s)
Liked: 1293
I had 5 of the SZ 2.0s in a slightly larger room on they were really nice. They have a wonderful voicing, on the warm side, especially with female vocals. I upgraded only because I wanted more oomph for movies and some types of music.
IMO they are a really nice speaker. And they are finished very nice. They have to be used with a sub though.
If you're going to be doing much movie watching get the biggest sub you can afford.
Def Tech SC8000
Harman Kardon AVR 1600
PS3, Apple TV, Sharp 70" Qattron
Kini62 is online now
post #3 of 48 Old 11-30-2013, 07:50 PM
losservatore's Avatar
Quoted: 2298 Post(s)
Liked: 2045
1+ NHT
Living Room :Oled 65" B6 / Marantz SR7010 / Xbox One S / PS4 Pro / HTPC / 2 PSA XS30 / Revel Performa3 F206 / Revel Performa3 C205 / Revel Surrounds / Sonos Connect / Roku 4 Ultra /Amazon Fire tv /
losservatore is offline
post #4 of 48 Old 11-30-2013, 08:59 PM - Thread Starter
mttownse's Avatar
When you say oomph, do you mean that you felt you couldn't get the volume desired out of the speakers? I don't want to run out of power. If I get the nht's, I will get the super 8 sub. I guess it makes the system.
mttownse is offline
post #5 of 48 Old 11-30-2013, 09:21 PM
zieglj01's Avatar
Quoted: 938 Post(s)
Liked: 846
HTD Level Two
Sub choice
HSU STF-2
http://www.hsuresearch.com/products/stf-2.html
For tight budget
Outlaw M8
http://www.outlawaudio.com/products/m8.html
__________________________________________
Who AM I
Speakers > Snell K7, EOS 150SP
Receiver > Tascam PAR-200
zieglj01 is offline
post #6 of 48 Old 11-30-2013, 10:35 PM
charmerci's Avatar
Quoted: 310 Post(s)
Liked: 195
Originally Posted by zieglj01 View Post
Sub choice
HSU STF-2
I'd wait till this (Cyber) Monday. The price might go down a few bucks.
charmerci is offline
post #7 of 48 Old 12-01-2013, 07:14 AM - Thread Starter
mttownse's Avatar
HTD Level Two
Sub choice
HSU STF-2
For tight budget
Outlaw M8
My main issue with these is size. How far off the wall do the mains have to be? Can that be in front of the tv plane?
Obviously these are too large to wall mount surrounds. Do you have an alternate surround that would match that I can mount?
mttownse is offline
post #8 of 48 Old 12-01-2013, 08:30 AM
zieglj01's Avatar
Quoted: 938 Post(s)
Liked: 846
For the best sound, you want the front 3 speakers to be on an even plane - I prefer that the speakers be at least,
slightly ahead of the TV - and at the front edge of the cabinet. The HTD speakers can be wall mounted - however
if off the wall, I prefer at least 3 or more inches from the wall if you can.
If you do surround sound music, then it is better to timbre match the speakers - if mostly Movies/TV and games,
then a different company surround can work.
For surrounds, look at:
Boston SoundWare
http://www.accessories4less.com/make-a-store/item/BOSSOUNDWARESLVA/BOSTON-ACOUSTICS-SoundWare-4.5-Indoor/Outdoor-Speaker-EA-Silver-NEW/1.html
http://www.accessories4less.com/make-a-store/item/BOSSOUNDWAREWHT/BOSTON-ACOUSTICS-SoundWare-4.5-in-Indoor/Outdoor-Speaker-Each/1.html
NXG Pro 4.1
http://www.amazon.com/Nxg-Pro-4-1-Satellite-Speaker/dp/B0044UHVOK/ref=cm_cr_pr_product_top
For closer timbre matching and small - HTD Middy
http://www.htd.com/cabinet-speakers/flat-panel-speakers/middy-compact-speaker
Who AM I
zieglj01 is offline
post #9 of 48 Old 12-01-2013, 11:35 AM
sdg4vfx's Avatar
Quoted: 81 Post(s)
Liked: 140
HTD Level Two
Sub choice
HSU STF-2
For tight budget
Outlaw M8
+1 the HTD Level Two's.
The NHT SZ 2's are very good (excellent highs and detail), But after auditioning them I tend to think of them as really good satellite speakers, because they have no low end and really even taper off quite a bit in the mids (like most satellite speakers). Because of this the crossover with the sub needs to be higher than normal so you need a very good sub (i.e not an entry level sub) to get the most out of them.
sdg4vfx is offline
post #10 of 48 Old 12-01-2013, 02:00 PM - Thread Starter
mttownse's Avatar
Did you audition them with their matching sub, the super 8? That is what I would buy.
mttownse is offline
post #11 of 48 Old 12-01-2013, 05:50 PM
Kini62's Avatar
Liked: 1293
The SZ will sound great with that sub. Just be advised that sub doesn't go much below the upper 30hz range.
Def Tech SC8000
post #12 of 48 Old 12-01-2013, 06:09 PM - Thread Starter
mttownse's Avatar
What would you consider to be an acceptable range? I am looking for HT only
mttownse is offline
post #13 of 48 Old 12-01-2013, 06:17 PM
zieglj01's Avatar
Quoted: 938 Post(s)
Liked: 846
Here are your measurements
The sub is -3 db at 38hz and -6 db at 34 hz
http://www.soundandvision.com/content/nht-superzero-20-speaker-system-ht-labs-measures
The SuperZero does not have much bass
However for what they can do, the system is nice.
Who AM I
zieglj01 is offline
post #14 of 48 Old 12-01-2013, 06:27 PM
Kini62's Avatar
Liked: 1293
Acceptable range would be at least down to the lower 20hz range.
Preferable range would be in the mid teens. Anything lower than that usually requires a lot more money. But in your size room you could get into the mid teens for around $1000 or so.
Def Tech SC8000
post #15 of 48 Old 12-01-2013, 06:27 PM - Thread Starter
mttownse's Avatar
As stated before, I am a bit of a newb and the graphs and stats at given measurement levels mean nothing to me.
Looks like the graph has a good crossover area between the two speakers in my eye. If you say 30 hertz is bad bass, what value is good. That level two bass has very similar numbers.
Second, all stats you have given me are for the 2.0s. I am looking at the newer 2.1s. They have a little more bass response.
Why do I care if the satellites can't reach as low, if the bass can pick it up in my small space, and the satellites sound fantastic in their range?
mttownse is offline
post #16 of 48 Old 12-01-2013, 06:30 PM
sdg4vfx's Avatar
Quoted: 81 Post(s)
Liked: 140
I would imagine that 8" sub would handle a higher crossover well. But as others mentioned it's more of a low woofer than a real subwoofer, HT digs down into the sub 30Hz range regularly.
The other issue (with any satellite speaker setup) is that sound starts becoming localized at 100Hz, so even though the frequencies would covered by the sub they would all becoming from that source, not from the other speaker locations.
Don't get me wrong ... I'm not anti the SZ 2 speakers, I think they are very good speakers. My discussion/comments are along the lines of comparing any satellite vs bookshelf speaker system for HT. Sound isn't the only consideration, what fits better in your space, budget, etc. are equally substantial reasons for selecting speakers.
In that price range ($350) there are other subs that dig more into the "sub" range, but their high end might be suspect (lack clarity, etc.) for use with satellite speakers. SVS, Outlaw and Rhythmik have subs in the $500-$600 range that would cover both the low and high well. The SVS PB-1000 (for $500) comes to mind first.
sdg4vfx is offline
post #17 of 48 Old 12-01-2013, 06:37 PM
zieglj01's Avatar
Quoted: 938 Post(s)
Liked: 846
If you want a sub that can go down for a nice price - it is the HSU STF-2
Who AM I
zieglj01 is offline
post #18 of 48 Old 12-01-2013, 06:48 PM - Thread Starter
mttownse's Avatar
What if I got a 7.2 receiver and dual sub'd at a later date-once I have more money. I can get a sub , either the super 8 or level 2 sub, for low 200s.
mttownse is offline
post #19 of 48 Old 12-01-2013, 06:49 PM - Thread Starter
mttownse's Avatar
I ask this since the level 2s you recommend also reach the same low range of 30 hertz
mttownse is offline
post #20 of 48 Old 12-01-2013, 06:50 PM
sdg4vfx's Avatar
Quoted: 81 Post(s)
Liked: 140
Forgot about that one! A very good sub for $320. I would probably recommend it over the NHT or HTD Level 2 subs.
sdg4vfx is offline
post #21 of 48 Old 12-01-2013, 06:51 PM
jdcrox's Avatar
Quoted: 78 Post(s)
Liked: 102
Nice thought, but unless you have a very small room, you are talking $1k worth of subs to get into the low 20's. The teens even more $$$$$
jdcrox is offline
post #22 of 48 Old 12-01-2013, 06:54 PM
Kini62's Avatar
Liked: 1293
The op's room is small. He could hit upper teens no problem for less than 1K.
Def Tech SC8000
post #23 of 48 Old 12-01-2013, 06:55 PM
Yankees24's Avatar
Quoted: 92 Post(s)
Liked: 38
Consider also the boston acoustics A25 or A26. You can them use a cheaper sub. They go down to about 50hz. Also a +1 on the BA soundware 4.5.
Think before you speak....
Yankees24 is offline
post #24 of 48 Old 12-01-2013, 07:25 PM - Thread Starter
mttownse's Avatar
I would love to get a sub for 1000 but my total budget for speakers is about 750. This is where I am hitting my feasibility limit.
mttownse is offline
post #25 of 48 Old 12-01-2013, 07:27 PM - Thread Starter
mttownse's Avatar
In addition, my "room" is an end of a 40x13 room. The area being used as a theatre is 12x13. One end if the room opens into the remainder of the 40 ft.
mttownse is offline
post #26 of 48 Old 12-01-2013, 07:41 PM
gonzotrucker's Avatar
I prefer that the speakers be at least,slightly ahead of the TV - and at the front edge of the cabinet. The HTD speakers can be wall mounted - howeverif off the wall, I prefer at least 3 or more inches from the wall if you can.
wOriWS
gonzotrucker is offline
post #27 of 48 Old 12-01-2013, 10:02 PM
zieglj01's Avatar
Quoted: 938 Post(s)
Liked: 846
No, most of us look for a crossover lower - like around 80 hz, for a better overall response.
Most will crossover NHT around 120 hz
The 2.1 does not really go any lower than the 2.0 - however the midrange tends to measure better
Satellites that tend to go lower, helps to avoid localization of the sub - and keeps male voices out of the sub.
NHT 2.1 SuperZero
http://forums.audioholics.com/forums/attachments/loudspeakers/9992d1330123776-upgrade-nht-super-1-snag-033.png
The bottom line seems to be, that you want the NHT - so go for it, and enjoy it.
Who AM I
zieglj01 is offline
post #28 of 48 Old 12-01-2013, 10:51 PM
zieglj01's Avatar
Quoted: 938 Post(s)
Liked: 846
in addition, my "room" is an end of a 40x13 room. The area being used as a theatre is 12x13.
I am recommending the Level Two speakers - however, I recommend the HSU sub over the Level
Two subwoofer - you do not have to brand match subs to the speakers.
The NHT doesn't have much below 34 hz - however, it may be enough for you
For your expanded listening area - it would be better to place your sub by your seating position.
I do not have measurements for the Level Two sub - however, it has a bigger woofer and a good box,
and I expect the sound pressure level to be higher than NHT.
Here is a subjective short take on the Level Two sub
http://www.hometheatershack.com/forums/home-audio-subwoofers/69406-htd-level-2-subwoofers.html
Depending on the room, the HSU STF-2 can hit around 23 hz
You can dual sub at a later date if you desire - however, try to get a decent sub for now.
Who AM I
zieglj01 is offline
post #29 of 48 Old 12-02-2013, 12:05 AM
D Bone's Avatar
Quoted: 294 Post(s)
Liked: 376
I had 5 NHT SZ 2.0s with a Cadence CSX-12 II subwoofer, powered by an Onkyo 709 in my 23x16x8 room and they sounded great. My wife didn't care for the gloss black finish, but not because of the looks but rather the upkeep. I now have Klipsch WB14s and a different sub, and I have to say, I believe the SZ 2.0s sounded better. If I were you, I would buy 5 NHT SZ 2.1s and a SVS PB-1000 sub.
To throw a monkey wrench into your options, you could go with 3 pairs of Micca MB42Xs for $240 and the SVS PB-100 for $500 and be money ahead..........Check out the Micca reviews, you will be surprised.
Samsung UN60D6420 ~ DirecTV HR-44 ~ Sony S5100 BD ~ Roku 3 ~ Denon AVR-X3200W ~ SVS Prime Bookshelf L/R ~ SVS Prime Satellite Surrounds ~ MultEQ XT L/R Bypass ~ Power Sound Audio XV15
D Bone is offline
post #30 of 48 Old 12-02-2013, 02:08 AM
sdg4vfx's Avatar
Quoted: 81 Post(s)
Liked: 140
Most will crossover NHT around 120 hz...
The THX recommended crossover for HT/surround is 80Hz, I believe that's where the number comes from. And with that crossover all the localized sound is still coming from the speakers.
...The bottom line seems to be, that you want the NHT - so go for it, and enjoy it.
...You can dual sub at a later date if you desire - however, try to get a decent sub for now.
+1 (again!)
sdg4vfx is offline
Reply Speakers
