Recommendation for Bookshelf speakers to replace towers... - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 12-01-2013, 08:15 AM - Thread Starter
swimman66's Avatar
Just moved into a new home and my Polk Monitor 60's that I have paired with a Yamaha A3000 will not fit into the desired space. I'm relegated to using bookshelf speakers as my mains. This room is used a the kids play room and will be the primary place for them to watch TV (and us adults when we want a good movie). I currently have the Polk 60's as the fronts paired with a Polk PSW505 sub. I plan to use the sub with whatever fronts I get. As well, I'd like to add a pair of wall mounted rears to the mix as the room is wired for these.
Any recommendations on a good quality front bookshelf and rear set would be appreciated as I'm not very up to speed on what is available although I have read some threads here and done other research.
swimman66 is offline
post #2 of 4 Old 12-01-2013, 09:05 AM
zieglj01's Avatar
Quoted: 1713 Post(s)
Liked: 1627
Look at HTD Level Three
http://www.htd.com/Products/level-three-speakers/Level-THREE-Bookshelf-Speakers
For the surrounds
HTD Flat Panel
http://www.htd.com/Products/flat-panel-speakers/flat-panel-speaker
Or, Level Two
http://www.htd.com/Products/level-two-speakers/Level-TWO-Bookshelf-Speakers
__________________________________________
Who AM I
Speakers -- Canton GLS 2 > Boston VS240
Receiver -- Integra 50.2
zieglj01 is online now
post #3 of 4 Old 12-01-2013, 11:01 AM
sdg4vfx's Avatar
Quoted: 118 Post(s)
Liked: 153
+1
sdg4vfx is offline
post #4 of 4 Old 12-01-2013, 11:05 AM - Thread Starter
swimman66's Avatar
Thanks for the info. I'll have to look into HTD as that is a brand I have not researched.
Reply Speakers
Yamaha Rx A3000 7 1 Channel Audio Video Receiver Black , Polk Audio Psw505 12 Inch Powered Subwoofer Single Black
