Definitive Technology SR-8040BP Speaker Stand - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 12-01-2013, 03:24 PM - Thread Starter
myavsaccount's Avatar
Just bought the Definitive Technology SR-8040BP speakers yesterday. Can someone please recommend a stand for the speakers? Thanks in advance!
myavsaccount is offline
post #2 of 4 Old 12-26-2013, 06:49 PM
Rockasama's Avatar
I'm in same situation, can't mount them on wall for 'now' so looking for 6 ft stand option, did you find something? Anyone have any ideas? I see a lot of 'pro' type monitor 6f stands, but they seem to be bottom/pole mounted.
Any help would be great, thx.
Rock
Rockasama is offline
post #3 of 4 Old 01-21-2014, 04:33 AM
Rockasama's Avatar
I bought these: http://www.amazon.com/gp/product/B004DYTG7M/ref=oh_details_o07_s00_i00?ie=UTF8&psc=1
Very substantial/hefty. Cable hides in the pole going up (comes out the back to connect). Be sure to put your banana plugs on after you run speaker wire through the tube. I have the stand set to about 5ft.
post #4 of 4 Old 10-17-2015, 01:22 PM
Liked: 0
Rockasama, how do you have the speakers mounted on the stand, are they able to be secured with the supplied hardware?
Big Alhole is offline
Reply Speakers
Definitive Technology Sr 8040bp Ea Bipolar Surround Speaker
