Does samsung TV Pass 5.1 on via ARC? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 14 Old 12-05-2013, 01:13 PM - Thread Starter
brazosdog02's Avatar
If I have a DVR hooked up to my TV via HDMI and my TV hooked up to speakers (sound bar) via HDMI (ARC), does the HDMI (ARC) pass the 5.1 signal from Dish DVR? Its a Samsung UN50F7100.
brazosdog02 is offline
post #2 of 14 Old 12-05-2013, 01:16 PM
droth406's Avatar
I'm pretty sure it does. I have my 360 and PS3 into my TV (UN46ES6150), and then a cable from the TV to the receiver. I haven't had any issue with my 5.1 sound.
droth406 is offline
post #3 of 14 Old 12-05-2013, 01:18 PM - Thread Starter
OK. Just playing with different options on my sound bar....let the TV handle everything vs. plugging everything into the sound bar.
post #4 of 14 Old 12-05-2013, 01:22 PM
droth406's Avatar
Yeah that's the most common way I've seen. All the video to the TV and then the audio via HDMI or optical from the TV to the soundbar.
droth406 is offline
post #5 of 14 Old 12-05-2013, 01:46 PM
crazyrob425's Avatar
Quoted: 443 Post(s)
Liked: 337
Its very rare that a TV will just passthrough the 5.1 signals. Most standard audio outs on TV's only output stereo even if just intaking surround sound
Best sound you can would be going from the device directly to the AV receiver and just output the video to the TV
crazyrob425 is offline
post #6 of 14 Old 12-05-2013, 02:44 PM
droth406's Avatar
I think you're right actually. I forgot that I put an optical cable straight to my receiver from my 360 and then the HDMI to the TV.
droth406 is offline
post #7 of 14 Old 12-05-2013, 02:47 PM - Thread Starter
But an HDMI WILL pass the 5.1 back to the receiver right? I know an optical won't unless its straight to the receiver.
post #8 of 14 Old 12-05-2013, 07:33 PM
Espo77's Avatar
Quoted: 179 Post(s)
Liked: 84
Both devices have to support ARC, and if the device that you are trying to send the digital TV signal to, uses an "older" HDMI version, then audio may not work. I think your post states that you do in fact have the HDMI cable hooked to the "marked" ARC HDMI "out" on the TV. My Samsung 8000 model has ARC stamped on the "HDMI 2" "out port". I could not find your TV model number in the Samsung support web site...many, many, many numbers there. Did you look for this answer in the TV section of AVS? "The official UN50F7100 thread"
Espo77's living room equipment: RECEIVER: Yamaha RX-A3030- SPEAKERS: Boston Acoustics M350, M25 center, surrounds, and front heights-
BLU-RAY: Oppo BDP103D- SUBWOOFER: HSU VTF-15H MK2- dedicated circuits for A/V- TV: Vizio P55C-1
Auralex Acoustics LENRD - Auralex Acoustics Roominator
Espo77 is offline
post #9 of 14 Old 12-05-2013, 07:43 PM - Thread Starter
Both devices support arc. Both are brand new current devices.
post #10 of 14 Old 12-05-2013, 08:08 PM
Quoted: 443 Post(s)
Liked: 337
Yes a Blu-ray player will output surround sound from its HDMI cable to the receiver
post #11 of 14 Old 12-06-2013, 08:28 PM
Espo77's Avatar
Quoted: 179 Post(s)
Liked: 84
^^^ Really??? Don't know if that is true, but he did not mention a receiver...yet.
Espo77 is offline
post #12 of 14 Old 12-06-2013, 08:32 PM
Espo77's Avatar
Quoted: 179 Post(s)
Liked: 84
Is he talking about a Blu-Ray player?
Espo77 is offline
post #13 of 14 Old 07-27-2014, 02:29 PM
dropKickMurphy's Avatar
What about the apps in the smart hub? For example, can the 7150 output 5.1 from a Netflix movie, either via optical or hdmi?
dropKickMurphy is offline
post #14 of 14 Old 07-27-2014, 09:51 PM
droth406's Avatar
Yes. They do on my 6150.
droth406 is offline
Reply Speakers
Samsung Electronics Un75f7100 75 Inch 3d Smart Led Tv
