Does the Center speaker should match or with the same manufacturere - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 12-05-2013, 10:35 PM - Thread Starter
lanciadelta's Avatar
Trying to set up a HT system. Still trying to decide on a receiver. Picked up a set of Floor standing JBL  speakers JBL ES80.
Looking for a center speaker. Do I need to look for ONLY for  a JBL? Is there any specification I should look for so that  center speaker match with JBL ES80?
Any recommendations for a center speakers?
Without a sub woofer, will this set up be good?
Product specifications JBL ES80
Frequency response (–3dB) 45Hz – 40kHz
Max. recommended amplifier power* 200W Power handling (continuous/peak) 100W/400W
Sensitivity (2.83V/1m) 90dB Nominal impedance 8 ohms Crossover frequencies 700Hz, 3.6kHz – 24dB/octave; 12kHz – 18dB/octave
Low-frequency transducer Dual (6") PolyPlas™, shielded
Midrange transducer (4") PolyPlas, shielded
High-frequency transducer (3/4") titanium-laminated dome, shielded;
EOS waveguide Ultrahigh-frequency transducer (3/4") polyester film, ring radiator, shielded;
EOS waveguide Dimensions with grille (H x W x D) 1084mm x 223mm x 330mm Weight per speaker 21kg
lanciadelta is offline
post #2 of 8 Old 12-06-2013, 01:13 AM
johnny hotsauce's Avatar
Your front speakers (center / left / right) should be of the same brand and series in order to timbre match and provide the same front soundstage. In your case, I believe the matching center to your the JBL ES80 towers would be the JBL ES25C (http://www.jblsoundgallery.com/ES25C.html#).
imagic likes this.
johnny hotsauce is offline
post #3 of 8 Old 12-06-2013, 04:42 AM
mr266's Avatar
Quoted: 117 Post(s)
Liked: 722
+1
WDTV Live SMP with WD EX4100 NAS
Polk RTI8 Front, Polk CSI5 Center, Polk RTI4 Surround
MTX SW2 12” SUB, Sharp AQUOS LC-70C6400U
URC-WR7 Universal Remote
Motorola QIP7232 (P2) FIOS DVR, Sony BDP-S590 Blu Ray Player
Marantz SR5010 AVR,Technics SL-B20 Turntable
mr266 is offline
post #4 of 8 Old 12-06-2013, 07:47 PM - Thread Starter
I saw this JBL speakers for $99 in FRY's electronics. Specs is the same as the other JBLEs25C mentioned.  This one should be compatible with my floor speakers?
btw is this good one?
JBL BALBOA CENTER 2-Way Dual 5" Center Channel Speaker
SPECIFICATIONS
•Maximum Recommended Amplifier Power 150W
•Power Handling (Continuous/Peak) 75W/300W •
Nominal Impedance 8 Ohms •Sensitivity (2.83V/1m) 90dB
•Frequency Response (-3dB) 80Hz - 20kHz
•Crossover Frequency 3500Hz •High-Frequency Transducer 19mm (3/4") Titanium
post #5 of 8 Old 12-06-2013, 11:40 PM
zieglj01's Avatar
Quoted: 938 Post(s)
Liked: 846
^^^^ NO - Use the E center with the E series JBL.
At Amazon
http://www.amazon.com/JBL-ES25CBK-Center-Channel-Speaker/dp/B00166VDKS
Also, at Harman Audio online
http://www.harmanaudio.com/search_browse/default.asp?brand=JBL&market=HOM&cat=CCS
__________________________________________
Who AM I
Speakers > Snell K7, EOS 150SP
Receiver > Tascam PAR-200
zieglj01 is offline
post #6 of 8 Old 12-08-2013, 05:51 PM - Thread Starter
Found the JBL ES150PBK 300-Watt Powered 10-Inch Subwoofer - Black in Amazon for $160. Is this I can pair up with Es80?
post #7 of 8 Old 12-08-2013, 11:00 PM
Sub doesn't have to be the same brand/series and you can go any direction you'd like, just make sure to match the C / L / R speakers.
Check out the below, it's a hell of a deal for $109 out the door including shipping and it is favored very well among lots of folks on the forum for it's price point. IMO, it will do better than the ES150. I actually have the 15" big brother to this one and love it (for the price I paid).
http://www.parts-express.com/dayton-audio-sub-1200-12-120-watt-powered-subwoofer--300-629
post #8 of 8 Old 12-09-2013, 01:44 AM
sjavs's Avatar
My opinion is timbre matching is a myth unless your Front LR are made from cloth and center's made from paper. Furthermore, check out this thread and save yourself some money:
http://www.avsforum.com/t/1449514/goodbye-center-channel
sjavs is offline
Reply Speakers
Jbl Es80bk 3 Way Dual 6 1 2 Floorstanding Speaker Black , Jbl Es25cbk 3 Way Dual 5 1 4 Center Channel Speaker Black
