Good receiver - Onkyo, Yamaha or Denon - AVS Forum
post #1 of 14 Old 12-06-2013, 09:28 AM - Thread Starter
rocko57's Avatar
Looking for a good receiver for my living room (24' x 18' with 8' ceilings).
I am using
  • 2 - Definitive Technology ProMonitor 1000 - front speakers
  • ProCenter 2000 - center speaker
  • Rears not sure yet.  Possibly 2 more ProMonitor 1000 or 2 SR-8040s.
  • SVS PB1000 - subwoofer
I may go with a 7.1 for possibly adding more speakers later.
I have looked at a few receivers already.  Just trying to narrow it down.
So far my list includes:
Denon AVR-X3000, Onkyo TX-NR717, Onkyo TX-NR626, Yamaha RX-V575, Yamaha RX-V675.
All receivers around $500 except the Denon around $800.  Also which of  the receivers has the best calibration for the speakers?
rocko57 is offline
post #2 of 14 Old 12-08-2013, 02:30 AM
dbleagl's Avatar
In my humble opinion, Yamaha will make you happiest.  Figure out what features you want and match them to the correct receiver.  The AVENTAGE line from Yamaha is excellent.  Crutchfield has a nice deal on the Rx-A1020 (last year's model) at 799.  Again, my opinion only, I'd be interested in reading feedback from some of the more advanced bloggers...
dbleagl is offline
post #3 of 14 Old 12-08-2013, 08:47 AM
Scarriere's Avatar
^ That's great advice!!
Scarriere is offline
post #4 of 14 Old 12-08-2013, 11:40 AM
commsysman's Avatar
Quoted: 60 Post(s)
Liked: 239
I would suggest that you consider the Harman-Kardon 3650 and 2650, which IMO tend to sound better with most speakers than Yamaha or Onkyo.
Both Yamaha and Onkyo tend to sound thin and have poor sonic definition to me compared to the more realistic richer sound quality of the H-K.
commsysman is offline
post #5 of 14 Old 12-08-2013, 12:03 PM
psychobrew's Avatar
Liked: 29
Have you considered Marantz?
Samsung PN50C7000
Yamaha RX-V775WA
BIC Venturi DV64 Towers
BIC Venturi DV62 CLRs Center
Still building but sounds amazing so far
psychobrew is offline
post #6 of 14 Old 12-17-2013, 11:37 AM - Thread Starter
rocko57's Avatar
Yes it is one of my options.
Now, I am narrowing down the receivers because of the type of calibration they have.  I am no audiophile, so I will need all the help I can to set up my speakers.
Most of the forums I read suggest using "Audessey" for calibration over the others out there.  So I am narrowing down to Denon, Onkyo or Marantz.
rocko57 is offline
post #7 of 14 Old 12-17-2013, 03:00 PM
gtgray's Avatar
Liked: 44
And you will probably find that while Onkyo has many advocates and is often less expensive they run hot and seem to have more reported failures than Denon and Marantz which are really just two different brand offerings from the same company. HDMI boards have been one of the most common reports with Onkyo. I have a couple of Denons 591, 2112ci and an older Pioneer Elite. The Elite is a tank while it doesn't really get too hot it consumes prodigious amounts of electricity. It also has a firmware bug with LFE volume. If your budget will allow it get a receiver with XT32 and the extra calibration which is not on Onkyo either from what I understand. Dual sub support in calibration can make life much simpler.
Just another blank signature.
gtgray is offline
post #8 of 14 Old 12-18-2013, 01:54 AM
Chevypower's Avatar
Liked: 38
+1 for Yamaha. I like the price, functionality, and performance. I've had reliability issues with Onkyo, never tried Denon. Marantz makes great receivers, but you pay more for them. I'm all about bang for buck.
Chevypower is offline
post #9 of 14 Old 12-18-2013, 04:08 AM
Yankees24's Avatar
+1 Yamaha....most of the mid priced models have been well reviewed. I've had mine for almost 8 years. Disregard the old myths of yamaha sounding "thin"...there AVR's offer a good balance in HT and Music.
jcwhammie likes this.
Think before you speak....
Yankees24 is offline
post #10 of 14 Old 12-18-2013, 05:48 AM
dbleagl's Avatar
Thank you Yankees24!  I've had no issues with anything sounding 'thin'.  Reliability, performance and ease of set up are all important, especially if you're less experienced.  The Audessey is certainly highly rated, but, imho should not be the highest priority.  Let's face it, once you get it set to where your ears like it, you probably won't be messing with the set up much.  I'll be setting up a new Yamaha RX-A1030 in the next couple days.  I'll let you know how Yamaha's YPAO utility performs.
dbleagl is offline
post #11 of 14 Old 12-18-2013, 07:01 AM
Liberty76's Avatar
If you don't want to pay full price on a receiver, I would suggest Accessories4less.com
Most things are refurbished and you can save a lot! I purchased a Denon 2313 for $450 and it has worked great! Some things in life you just gotta have new, like a toothbrush or underwear! A factory refurbished receiver just seemed like a logical place to save some money! They carry the brands you are interested in too!
Liberty76 is offline
post #12 of 14 Old 12-18-2013, 07:16 AM
jcwhammie's Avatar
+1
The AVENTAGE line is well built.  I've never thought of the sound as being "thin" as stated by someone in this thread.
Panasonic 60GT50Yamaha RX-A2020Panasonic Bluray DMP-BDT220Fronts: Focal Chorus 726VCenter: Focal Chorus cc700VSurrounds: Focal Chorus 705V(2) Outlaw LFM-1 Plus
jcwhammie is offline
post #13 of 14 Old 12-18-2013, 08:05 AM
zieglj01's Avatar
Quoted: 85 Post(s)
Liked: 369
Yamaha A820 - refurb at AC4L
http://www.accessories4less.com/make-a-store/item/YAMRXA820BL/YAMAHA-RX-A820-7.2-Channel-Network-AVENTAGE-AV-Receiver/1.html
Also, I do not listen to receivers - I listen to the speakers - however, Yamaha does not sound thin.
__________________________________________
Who and Where - is the Way, the Truth and the Life?
Speakers > MB Quart VS05, Boston VS260, Snell K7
Subwoofer > Mordaunt Short Aviano 7
Receiver > Tascam PA-R200, Pioneer VSX-30
zieglj01 is offline
post #14 of 14 Old 12-18-2013, 02:14 PM
commsysman's Avatar
Quoted: 60 Post(s)
Liked: 239
The NAD T748 is the best value and sounds best for $600 IMO.
Do a direct listening comparison against any Yamaha or Onkyo and I think that you will decide that the NAD sounds better.
Reply Speakers
Definitive Technology Promonitor 1000 Bookshelf Speaker Single Black , Definitive Technology Procenter 2000 Compact Center Speaker Single Black , Svs Pb1000 10 Inch 300 Watt Powered Subwoofer , Definitive Technology Sr 8040bp Ea Bipolar Surround Speaker , Denon Avr X3000 7 2 Channel Home Theater Receiver , Onkyo Tx Nr717 , Yamaha Rx V575 7 1 Channel Network Av Receiver , Yamaha Rx V675 7 2 Channel Network Av Receiver
