Help deciding on a subwoofer - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 12-06-2013, 08:02 PM - Thread Starter
stubbornboy's Avatar
Hi,
I posted this is the subwoofer forum, but I didnt get any response. Maybe I am in the wrong forum or asking the wrong question.
But if anyone can point me in the right direction, it will be helpful.
I recently Bought a pair of Kef Fivetwo Series model7 speakers from NewEgg.  I also got a Denon X1000 Receiver.
The Kef speakers have a Frequency response 100Hz - 30kHz.
I am confused on what Sub I need to buy for this. I ran out of Budget and so cannot buy an expensive Sub. I am considering between a Polk Audio PSW10  (100W , 35 to 200Hz)  Vs a used Klipsch Sub 10 Powered Subwoofer (200W , 28 to 120Hz).
I am a newbie and am not really sure what would be my best choice.  If there is some other option that you recommend, please feel free to suggest
Any help would be greatly appreciated.
G
stubbornboy is offline
post #2 of 6 Old 12-06-2013, 09:12 PM
grasshoppers's Avatar
Quoted: 803 Post(s)
Liked: 506
I would go with the Klipsch as long as it is in good working condition.
Anthem MRX-300-Outlaw Audio M2200
Rythmik F12 subs
Paradigm Signature S6,C1,S1
Harman Kardon DMC1000 (music)
Assassin HTPC (movies)
grasshoppers is offline
post #3 of 6 Old 12-06-2013, 09:21 PM - Thread Starter
So the upper limit frequency of 120Hz would work fine with my Kef (100 to 30Khz)? If so what do you recommend the crossover should be set to?
post #4 of 6 Old 12-06-2013, 09:25 PM
Quoted: 803 Post(s)
Liked: 506
Start with 100hz, move up to 120 hz if it doesn't sound right.
Rythmik F12 subs
post #5 of 6 Old 12-06-2013, 09:26 PM - Thread Starter
Thanks for the help
post #6 of 6 Old 12-07-2013, 01:07 PM
sdg4vfx's Avatar
Quoted: 81 Post(s)
Liked: 140
sdg4vfx is offline
Reply Speakers
Polk Audio Psw10 10 Inch Monitor Series Powered Subwoofer Single Black
