Recommendations for my Small Home Theater - AVS Forum | Home Theater Discussions And Reviews
Old 12-07-2013, 04:43 PM - Thread Starter
Claybe's Avatar
Quoted: 213 Post(s)
Liked: 81
I am planning on building a small theater in my home and need speaker recommendations. The room will only be 1320 cubic feet. I do plan to sound proof it. What would you recommend for this small space? I currently have a pioneer vx30 elite receiver that I am running 5.1 with. I want to run 7.1 but don't know if that amp will do it or not. Where should I start???
Claybe is online now
Old 12-07-2013, 05:02 PM
bladerunner6's Avatar
Quoted: 20 Post(s)
Liked: 59
My first thought is that in that small of a space you might have a time placing seven speakers.
My next thought is what is your budget and what will be your listening preferences.
bladerunner6 is offline
Old 12-07-2013, 05:08 PM
mr266's Avatar
Quoted: 117 Post(s)
Liked: 722
Did you mean the vsx30? If so, you can do 7.1. First, start by telling everyone what your budget is. Second, don't scrimp on a sub. Look for one at least in the $500 range. If you go on to the subwoofer forum and put best sub for $500, you'll get lots of stuff back. I'd also go listen to different types of speakers and you can at least tell people the brands you seem to like. That will help them give you advice on some that you may not get a chance to hear. Everyone has certain brands that they like, but only you can tell what makes you happy in the end. Happy hunting.
WDTV Live SMP with WD EX4100 NAS
Polk RTI8 Front, Polk CSI5 Center, Polk RTI4 Surround
MTX SW2 12” SUB, Sharp AQUOS LC-70C6400U
URC-WR7 Universal Remote
Motorola QIP7232 (P2) FIOS DVR, Sony BDP-S590 Blu Ray Player
Marantz SR5010 AVR,Technics SL-B20 Turntable
mr266 is offline
Old 12-07-2013, 09:57 PM - Thread Starter
Claybe's Avatar
Quoted: 213 Post(s)
Liked: 81
I am imagining my budget is around $1500 per year and the project will take 3-4 years.
Is the vsx30 a respectable enough receiver????
Old 12-07-2013, 10:05 PM
zieglj01's Avatar
Quoted: 938 Post(s)
Liked: 846
Yes the Pioneer receiver is nice - I own one
__________________________________________
Who AM I
Speakers > Snell K7, EOS 150SP
Receiver > Tascam PAR-200
zieglj01 is offline
Old 12-07-2013, 10:17 PM
jbrown15's Avatar
Quoted: 2523 Post(s)
Liked: 1993
Do you plan on having one to two rows of seating?
If its one, IMO you're better off sticking to 5.1 instead of 7.1 and use the money saved from not having to buy two extra rear speakers and get a better 5 channel setup.
jbrown15 is offline
Old 12-07-2013, 10:32 PM - Thread Starter
Claybe's Avatar
Quoted: 213 Post(s)
Liked: 81
Never thought about that! Just thought more is better. Most likely there will be a 90 degree sectional. So maybe 5.1 is okay???
Old 12-07-2013, 10:59 PM
jbrown15's Avatar
Liked: 1993
If you only have one row of seating and the rear speakers are close to the seating IMO you don't really get the full benefits of the extra rears.
jbrown15 is offline
Old 12-08-2013, 01:02 PM - Thread Starter
Claybe's Avatar
Quoted: 213 Post(s)
Liked: 81
Great! That will save some money! Now what are some recommended speakers for the 5.1 set up in a small space?!?
Old 12-08-2013, 01:08 PM
jbrown15's Avatar
Liked: 1993
Well what's your total budget for 5 speakers? And a sub?
jbrown15 is offline
Old 12-08-2013, 01:17 PM
zieglj01's Avatar
Quoted: 938 Post(s)
Liked: 846
Look at the HSU Hybrid package
http://www.hsuresearch.com/products/hybrid3pkg.html
Who AM I
zieglj01 is offline
Old 12-08-2013, 01:24 PM
jbrown15's Avatar
Liked: 1993
Chase has their new Theater-10 speakers coming out soon at $300per speaker, they could turn out to be a amazing performance to dollar value.
jbrown15 is offline
Old 12-19-2013, 09:31 PM - Thread Starter
Claybe's Avatar
Quoted: 213 Post(s)
Liked: 81
Things have changed and now I will have the theater in a larger room and will most likely have two rows. Still looking at the HSU package with the VTF-15H sub. But some have said that two subs will be better than one. Any other recommendations? Budget will be $1500-$2000 for everything. I would like to do in wall speakers but it is looking like that would be too expensive.
Old 12-19-2013, 10:01 PM
jbrown15's Avatar
Liked: 1993
What are the dimensions of the larger room?
jbrown15 is offline
Old 12-19-2013, 10:14 PM
lespurgeon's Avatar
Quoted: 31 Post(s)
Liked: 52
HSU package is a decent option. NHT either super zero or absolute line in a bigger room, with appropriate sub (I'd probably still suggest an HSU sub). By 1.5-2k for all, that is speakers adn wires only, not other electronics, projector, etc. I hope (we could do that too, with several compromises).
lespurgeon is offline
Old 12-20-2013, 08:01 AM - Thread Starter
Claybe's Avatar
Quoted: 213 Post(s)
Liked: 81
The room is not too much bigger. It is 14' wide by 19'6" deep by 7'6" tall. So still a modest space.
If going with the HSU package how could I mount the LCR speakers behind the AT screen?
Old 12-20-2013, 08:36 AM
zieglj01's Avatar
Quoted: 938 Post(s)
Liked: 846
Depending on the space behind the screen
http://www.amazon.com/VideoSecu-Clamping-Mounting-Surrounding-MS56B/dp/B000X9O8SI
Who AM I
zieglj01 is offline
Old 12-20-2013, 06:21 PM - Thread Starter
Claybe's Avatar
Quoted: 213 Post(s)
Liked: 81
Yes $1500 ish for just the speakers. I will look at the NHTs too. Thanks.
Old 01-09-2014, 10:46 AM
Buckeye10's Avatar
Have you thought about DIY subs and speakers?  You could probably build a great set for the space you have.
Buckeye10 is offline
Old 01-09-2014, 10:54 AM - Thread Starter
Claybe's Avatar
Quoted: 213 Post(s)
Liked: 81
Yes, thanks!  I am all over it right now trying to learn everything to try to build my own for an affordable cost, but just like anything the DIY can easily get out of control as well (I am learning!).
Old 01-09-2014, 11:08 AM
Buckeye10's Avatar
I know what you mean!  I've been checking out the diysoundgroup and reading the reviews on here.  My first project is going to be a DIY sub just to get the hang of speaker building, seems like the best bang for the buck.
