What speakers will sound good together? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 19 Old 12-10-2013, 10:16 AM - Thread Starter
mow4cash's Avatar
I am finally getting around to upgrading my system.  I picked up a marantz sr6007. Hope I made the right choice over the onkyo nr818.  Now I have to figure out what speakers to use.  The pioneer  SP-BS22-LR seem good for the price. I was going to pick up 2 pairs of those and the matching center. For the sub I am leaning towards the svs PB-1000.  Should I stick with the matching pioneers for the fronts? Will I be missing spots in the sound range with that setup?
UN55JS8500/SR6007/Focal 727v/CC701/4x CBM-170 SE/FV15HP/Fusion Tribute Seats
FreeNas,Emby,Kodi,OpnSense/Nvidia Shield TV
mow4cash is offline
post #2 of 19 Old 12-10-2013, 02:33 PM
Assoc. Editor @ AVS Forum
imagic's Avatar
Quoted: 4701 Post(s)
Liked: 7845
Those Pioneer SP-BS22-LR bookshelf speakers are one of the great bargains in HiFi. They are limited in terms of maximum output, but they have good low frequency extension, enough to blend in with a sub at a reasonable crossover frequency. Matching speakers will net you a more seamless soundfield, but if you can spring for (and fit) the towers for your front L/R mains, it could be worthwhile.
Mark Henninger
imagic is offline
post #3 of 19 Old 12-10-2013, 02:42 PM
zieglj01's Avatar
Quoted: 926 Post(s)
Liked: 839
That is a lot of receiver (money spent) - your receiver to speaker ratio seems to be off balance.
The Pioneers are nice for their price. What is your max budget for speakers and sub > and also
what is your room size?
__________________________________________
Who AM I
Speakers > MB Quart VS05, Boston VS260, Snell K7, EOS 150SP
Subwoofer > Mordaunt Short Aviano 7
Receiver > Tascam PAR-200, Pioneer VSX-30
zieglj01 is offline
post #4 of 19 Old 12-10-2013, 06:17 PM - Thread Starter
mow4cash's Avatar
I wanted to make sure i had a good receiver to start with. 13x13 is the listening area and the room is 13x24. $1500 would probably be my max budget(waste not). I'd like to put more money into a good set of towers and try to save money by getting cheaper surrounds like the pioneers.  I like to play my music loud and don't think the pioneer towers will cut it.  Maybe I'm going at this the wrong way?
mow4cash is offline
post #5 of 19 Old 12-10-2013, 06:33 PM
zieglj01's Avatar
Quoted: 926 Post(s)
Liked: 839
Good prices on the Focal V series - I would recommend good bookshelves and a sub >
however, the prices on the towers are good.
Focal 717V towers
http://www.accessories4less.com/make-a-store/item/FOCAL717VHVN/FOCAL-Chorus-717V-716V-Dual-6-1/2-Tower-Speaker-PAIR-Havana/1.html
Focal CC700 center
http://www.accessories4less.com/make-a-store/item/FOCALCC701HVN/FOCAL-Chorus-CC701-CC700-Dual-6-1/2-Drivers-Center-Speaker-Havana/1.html
HSU subwoofer
http://hsuresearch.com/products/vtf-2mk4.html
Or, the SVS PB-1000 if budget is tight.
If you can not swing all of this - then hold off on the center for now
For one who likes music - a good 3.1 or 2.1 is better than a weak 5.1
Who AM I
zieglj01 is offline
post #6 of 19 Old 12-10-2013, 07:15 PM
Elihawk's Avatar
Quoted: 913 Post(s)
Liked: 777
Agree with the budget concerns! You are buying 1000 plus receiver and spending a couple hundred on speaker! That should be reversed! I would buy a more budget friendly Avr, maybe 300 dollars and spend 1200 dollars on speaker/ sub! A great receiver will sound mediocre if you have mediocre speakers (and the pioneers are not great speakers, just great for the price). Just my 2 cents, but it is your money!
Set up #1: EMP e5ti, e5Ci, and EMP e5Bi surrounds, Outlaw LFM1 Plus sub, EMP 10i10i sub
Set up #2: Def Tech SM450, CLR2002, SLS Qline surrounds and Klipsch 12wD sub
Set up #3: Philharmonics- BMR in a 2.0 system, music only
Elihawk is online now
post #7 of 19 Old 12-10-2013, 07:49 PM
Purpose's Avatar
1500 total including what you spent on the SR6007? Yes, I think you should recalibrate.
I really like my SR6007, but given what you spent on that receiver you should either: i) return the receiver and use a greater portion of your overall budget to purchase the your front l/r and center; or ii) significantly up your speaker budget. The best bang for your buck in terms of sound improvement and longevity comes from your speakers. You create a better system within your budget by not spending so much on the receiver.
I agree with saving money on the surrounds.
Purpose is offline
post #8 of 19 Old 12-10-2013, 08:06 PM - Thread Starter
mow4cash's Avatar
The receiver was $750 since there is a newer model available. Was hoping to keep it under $1500 for the speakers. I have crappy speakers already to get me by so I don't have to invest all at once.  How much should I be spending on speakers to match the receiver?
mow4cash is offline
post #9 of 19 Old 12-10-2013, 08:24 PM
Purpose's Avatar
My two cents would be as follows:
- spend approximately 300-400 on the receiver.
- spend the 1500 budget speakers (focus on the LCR - particularly if you are a music fan) and sub.
By way of example, I have a friend who is happy with these (they used to have the piano black center as well):
- Use your old speakers as surrounds.
That would save you about 300 from your current budget with the Marantz.
I should add that I am personally partial to towers (my system more focused on music). But you could also purchase bookshelf speakers, and a matching center for that amount.
In any event, I would suggest buying the best speakers possible as they will be with you for a while.
Purpose is offline
post #10 of 19 Old 12-10-2013, 08:52 PM
imagic's Avatar
Liked: 7845
Wow, I'll just play devil's advocate and say that the Pioneer bookshelf speakers should not be judged based on MSRP and that they are worth the investment in better amplification and processing, i.e. a better receiver. I know it flips conventional wisdom on its head, but that's just how it is.
Mark Henninger
imagic is offline
post #11 of 19 Old 12-10-2013, 08:57 PM
zieglj01's Avatar
Quoted: 926 Post(s)
Liked: 839
As was recommended in post #5 and #9 - The Focal 717V
Who AM I
zieglj01 is offline
post #12 of 19 Old 12-10-2013, 09:08 PM
Elihawk's Avatar
Quoted: 913 Post(s)
Liked: 777
Well, I will play devils advocate as well...in 5 years, your Avr may very well be a couple generations behind the technology...and your speakers will not! And as long as your Avr has enough power and good room correction software, your speakers will be the thing that determine the sound quality of the system! The AJ Pioneer speaker are a good budget speaker for the buck...but anyway you slice it, they are a budget speaker!
post #13 of 19 Old 12-10-2013, 09:09 PM
zieglj01's Avatar
Quoted: 926 Post(s)
Liked: 839
However, if you were interested in the BS22 Pioneer speakers - there is a modified version available, which
really does take them to a higher level - they are modified by Dennis Murphy of Philharmonic Audio > It will
cost just a little more than the list price of the speakers. My subjective review here >
http://www.avsforum.com/t/1501355/murphyblaster-pioneer-bs22-dna-speaker
He has also modified the center channel.
Look here
http://philharmonicaudio.com/folio-me/html/Phil%20Pages/AALS.html
Who AM I
zieglj01 is offline
post #14 of 19 Old 12-10-2013, 09:28 PM
zieglj01's Avatar
Quoted: 926 Post(s)
Liked: 839
And one more option, with bookshelf speakers
Focal 706V bookshelf
http://www.musicdirect.com/p-41246-focal-chorus-706v-bookshelf-speakers-pr.aspx
Focal CC700V center
http://www.musicdirect.com/p-4927-focal-chorus-cc700v-center-speaker.aspx
Pioneer stock BS22 or modified BS22-DNA speaker
Then the SVS PB-1000 subwoofer
This meets the $1500 speaker budget, and you will have a nice system
Who AM I
zieglj01 is offline
post #15 of 19 Old 12-15-2013, 06:39 PM - Thread Starter
mow4cash's Avatar
What do you think of this setup?
It's just a starting point to find a baseline.
Towers- FOCAL Chorus 717V
Center- Affordable accuracy SP-C22
Surrounds- Affordable accuracy  SP-BS22-LR
Rear surrounds- Affordable accuracy  SP-BS22-LR
Sub- HSU VTF-2 MK4
Puts me at $1650
Without adding an amp,can I drive anything more then the FOCAL Chorus 717V off of the sr6007?
Thanks for helping me guys.
mow4cash is offline
post #16 of 19 Old 12-15-2013, 07:38 PM
zieglj01's Avatar
Quoted: 926 Post(s)
Liked: 839
Towers- FOCAL
 Chorus 717V
Center- A
Sub- HSU VTF-2 MK4
Puts me at $1650
Change the center to the Focal - for timbre (voice) matching up front - a good price
The Marantz receiver will be fine for now
If budget is a challange for the Focal center, then save up for your surrounds
Who AM I
zieglj01 is offline
post #17 of 19 Old 01-04-2014, 09:39 AM - Thread Starter
mow4cash's Avatar
I'm about to buy the FOCAL Chorus 727V towers and the matching FOCAL Chorus CC701 center. Before I purchase these, I want to know what the next step up would be? I am going to try to justify spending more before I purchase the Focals.
I will save up for a Rthymik FV15HP. It looks like that is the end of the road sub before jumping up to a Seaton, which is not going to happen. I am going keep my current surrounds for now.
Thanks for your help guys. I'm getting closer.
mow4cash is offline
post #18 of 19 Old 01-04-2014, 09:55 AM
zieglj01's Avatar
Quoted: 926 Post(s)
Liked: 839
Here you go
http://www.dedicatedaudio.com/inc/sdetail/4705/38112
Who AM I
zieglj01 is offline
post #19 of 19 Old 01-10-2014, 09:51 AM - Thread Starter
mow4cash's Avatar
I settled on the Focal 727V and CC701. I'm enjoying the sound they produce in pure direct mode. The sub is next on the list.
mow4cash is offline
Reply Speakers
Pioneer Andrew Jones Designed Bookshelf Loudspeakers Sp Bs22 Lr , Onkyo Tx Nr818 , Svs Pb1000 10 Inch 300 Watt Powered Subwoofer , Marantz Sr6007 Home Theater Av Receiver , Focal Chorus 717v
